2011 Audi A5 Quattro
While trying to put lowering springs in today the top pinch bolt would not come out no matter what? tried pb blast, air hammer, heat from a propane torch, cut the head iff thru the slit with a cutting wheel and tried to pull the bolt out with the nut. that didnt work either i cracked the ear slit of the spindle on that side.
Ok so... figured id give the other side a go and be more gentle, well the bolt will not budge, cut the head off and tried the pull method with the nut but not as hard this time. It wont come out.
Sooooooooooo... Anyone have any videos on how to remove the Spindle itself? I need to replace the drivers side and take the passenger side off to get the spindle on the bench to get that bolt out.
Im afraid the pinch bolt on the bottom of the spindle wont come out now....
