Originally Posted by
catchupmustard
So I just replaced the tstat and housing and leak is instill leaking.
If I do the water pump, can I just order the water pump and re use my tensioner? I only ask bc my timing belt kit was just done 30K miles ago and the belt and everything else looks good to go, so I guess what I’m asking is why do a complete $300 timing kit? If I can just reuse the tensioner, and just order a new WP? How’s that sound to you guys?
The timing belt has a mileage limit, but also a time limit which I think may be 5 years, so I'm not sure how long ago you changed the timing belt, but would be good to do everything. Personally, I had changed the timing belt on my A6 2.7T due to a leak from the thermostat housing, and the housing was plastic, so I replaced it with a metal one. After say 8K miles, I had a slight coolant leak start, and when I took everything apart, I found that the leak was from the thermostat gasket, and that rubber gasket was squarish in shape vs the round shape of the new gasket. This time, I also put a little sealant on the thermostat gasket, in addition to the slight amount on the water pump gasket.
PS - if needed, there is install info on ECS like
http://bd8ba3c866c8cbc330ab-7b26c6f3...elt_DIY_r2.pdf plus on videos like JHM at
https://youtu.be/0LnpfiG1XzY
- Jim
