I purchased a memory module which remembers the last input of the auto start/stop function. Ebay seller aa.cars2012. Item shipped from Australia. Shipping took approximately 3 weeks and with today’s conversion rates, this will cost approximately $60 U.S. Dollars.
Installation:
1. The seller ships the module along with 2 metal keys. These slide into hidden slots on the control panel enabling the panel to pull straight out.
2. Disconnect harness from rear of control panel.
3. You will notice the female end of the supplied harness does not match up perfectly with the male end on the car.
4. I used a razor blade and cut two of the top corners out of the supplied harness (female end). This allowed the supplied harness to connect to the car harness.
5. Push and slide the control panel back into place and you are done.
I have had this installed for about 1 month and has worked flawlessly. I no longer need to push the auto start/stop button every time I start the car or have the A/C running if using VCDS mods.
