Results 1 to 13 of 13
    Jan 29 2019
    Markham
    Q5 Brake Calipers on a S4
    Was wondering if a set of 2018 Q5 Brembo's would be a direct fit on a B8.5 S4. I did some googling and saw that generally it should fit, but the year of the Q5 brakes were never specified. I want to confirm before I make the purchase off somebody.
    Also wanna know if I need to switch pads for the new Q5 calipers or my existing S4 ones are good.
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    Quote Originally Posted by kaii View Post
    If it's the bbk, if I'm not mistaken, is it a 4 piston caliper? If so, than u need a different pads. Since the b8.5 only had single piston. But those single piston calipers were pretty large from what I read.
    I know it will fit an S5
    Sent from my SM-G965U1 using Tapatalk
    May 09 2012
    Virginia
    2018 and on do not fit. They are speced to accommodate a max diameter of 340mm. Starting in 2018 there was only 1 size rotor on the Q5 and it was 338mm. The caliper was made to fit just that.
    Jun 02 2019
    serenity valley
    Quote Originally Posted by jbain2 View Post
    I thought it was 345mm for the front?
    That's what the b8.5 rotors size are.
    So for the 2018 mode they went with smaller brakes?
    May 09 2012
    Virginia
    Quote Originally Posted by 2by2handsofblue View Post
    No more 3.0 motor from 2018 on (not including the SQ). All models run the same caliper.
    I’m speaking from first hand experience. Couldn’t make the work.
    https://audiparts.audiwilmingtonde.c...yABEgI44vD_BwE
    Jun 02 2019
    serenity valley
    Lol dang I was confused. I thought op wanted to use q5 brakes from a b8.5 model lol.
    That's interesting audi went smaller on the brakes.
    If I'm not mistaken the q5 b8.5 used brembo 4 piston 345mm size brakes
    Jan 29 2019
    Markham
    Thanks. Saved me the trouble of finding out myself. Audizine
    May 09 2012
    Virginia
    Up until 2018 and with the introduction of the 3.0 motor in the Q5, there were different size calipers used. The 2.0 motors with brembo accommodated 320mm rotors. Those with the 3.0 motor had 345mm rotors thus the calipers were different. After 2018 the style changed entirely.
    First picture is a set of Q5 brembos from the earlier models on my allroad.
    Next are the calipers in question from a 2018. I purchased these unknowingly thinking the same thing. You can see the difference in design.
    Jun 02 2019
    serenity valley
    Oh its curved more. Is it the same size rotors of 345? It's still a 4 piston system.
    May 09 2012
    Virginia
    It’s for a 338mm rotor. The 345 don’t fit. You could probably modify them to fit, but I didn’t want to go that route. Yes. Still 4 piston. You can see the piston housings in the second picture. 2 each side.
    Jun 02 2019
    serenity valley
    I c. That's so odd they would go smaller and a weird size.
    May 09 2012
    Virginia
    They actually went bigger. Up until then all the Q5’s with 2.0 motors had 320mm rotors.
