Results 1 to 30 of 30
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    2017 Audi Q7 CREC Project is ACTIVE !
    My name is Oleg and I'm officially open new project with my 2017 Audi Q7. At this moment car is 100% Stock and ready for APR Goodies. Thanks to APR for support this project and specially thanks to Arin for helping me with my Q7 Ok here is base data : 1/4 mile by Dragy device … Dyno by EFI Logics and some logs to compare with later with stage 2 and stage 2+ . Car will get lot's of modifications : APR Dual Pulley / APR Flash / APR Ultra Charger / Ported blower / Custom PCV System / My cooling system for Supercharger " Svarog Chiller " hoping to hit 11sec at 1/4 who know it might able to do that. Stay tuned and a lot more to come
    https://youtu.be/QI4p8ZMosTE
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Established Member Two Rings joserod92's Avatar
    Jan 31 2019
    Dominican Republic.
    Awesome!
    C7.5 S7
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Can't wait to see the progression on the Q7, Oleg. So long as you still have the S5 in the stable, I can sleep at night knowing you didn't make a full transition from a coupe to an SUV.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Any updates on the S5? Any crazy plans to swap in an ls or a twin turbo v10?
    If I had a crazy build idea, I'd convert the s4/s5 to rwd, perhaps bolt up a tremec t5 or tr6060, remove the false firewall and make custom engine mounts to move the engine as far back as possible. As for my choice of the engine, either lsa or an inline 5 from the rs3/ttrs.
    Established Member Two Rings cadguy77's Avatar
    Jun 07 2019
    London, UK
    Any plans to lock the supercharger clutch?
    Sent from my SM-G965F using Tapatalk
    '15 CREC SB | Black/White Napa | Sports Diff | Dynamic Steering
    TVS ECU/TCU | Intake Mods | 82mm TB | Ported SC | 034 SC Clutch Delete | KI 206mm Crank Pulley (3.26PR) | Merc Racing HE | Bilstein B16 PSS10 | Front 4-Pot Brembos | EBC Turbo Groove and Yellow stuff | HEL Lines | 15mm Spacers | 034 X-Brace | DK Tuning B8 Front Strut Brace | 034 Rear ARB | 034 Trans Mount Insert | Profusion Custom Exhaust | Xenonz Rear Diffuser |
    Account Terminated Two Rings
    Jun 05 2018
    magimmeMVE
    Usa
    I'm have a UK CREC S5 with APR stage 2 drive pulley. Can't wait to see how this dual pulley set up holds. Subbed!
    Jun 07 2019
    London, UK
    Will you consider larger crank (circa 210mm)/std SC pulley?
    Standard UK CREC S5 with sports diff here. Following this closely to guide my efforts
    Nice wheels by the way
    Jan 09 2010
    New York
    Quote Originally Posted by Envy187 View Post
    Thanks buddy !
    Quote Originally Posted by fastboatster View Post
    I picked up 2016 Audi RS7 engine with some internal damage and going to build bottom to top ! Still trying to make choose where this 4.0T will go😉 ether Q7 or S5 but I like the way V6 perform in S5 and I might swap CREC 6 and build with forged internals in to S5 and build 4.0T into Q7 I’m not sure yet .
    Quote Originally Posted by cadguy77 View Post
    I might have couple ideas let’s see first how will hold on APR Stage 2 forts 👍🏻
    Quote Originally Posted by stevephilp View Post
    Very soon buddy
    First I’ll test APR 187mm and then we will see what APR team can do for me .
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Nice Oleg, I'm intrigued by this motor DI/PI capabilities. Can you adapt the old charger snout to remove clutch?
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Jan 09 2010
    New York
    Quote Originally Posted by RWD2quattro View Post
    I tried before and everything is bolt on but to make this work correctly is required tuning to disable supercharger speed sensor and magnetic mechanisms to code it out
    Jan 09 2010
    New York
    APR Pulley installed 57.7/187mm
    Nov 27 2015
    UK, West Berks
    Thanks for this post, its very interesting. I have just watched your video carefully and I have finally had a clear view of why no post grinding is needed on the CREC. My tuner told me that he didn't need to do it but I have always wondered about it.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Jun 07 2019
    London, UK
    Are you not concerned the OEM crank pulley will fail?
    Jan 09 2010
    New York
    Always inspect when you do this kind work ! I mention this in video as well I had low miles pulley in my garage so I replaced
    Jun 05 2018
    magimmeMVE
    Usa
    Can't wait to see this tuned!
    Jan 09 2010
    New York
    This Saturday Stage 2 flash! Only did APR Dual Pulley 57.7/187mm that's it for now! Cooling system is stock … I would like to see how bad it is on stock cooling system and only after that combined my own second cooling system that should drop at list 25-40c down this is a lot ! I'm more pumped to try ported blower with APR UC System and race gas or E40-70 might be even more because CREC engine is dual fuel injection
    Nov 27 2015
    UK, West Berks
    FYI my ratio is 2.99 on 99 RON (93 AKI) fuel and I have never had a heat problem (I monitor with FIS-Control MMI). The CREC does have better intercoolers than the previous model.
    Talking about the dual injection - you are aware of the recall?
    Jun 07 2019
    London, UK
    FYI dippy
    Had mine done before purchase collection
    Jan 09 2010
    New York
    I think audi replaced MPI fuel rail by warranty
    Jun 05 2018
    magimmeMVE
    Usa
    Quote Originally Posted by Dippy View Post
    Dippy, have you monitored the supercharger bypass flap on yours taking into account the MRC stage 2 is designed for a 179mm crank? I wonder if they increased boost request in the map.
    Jun 05 2018
    magimmeMVE
    Usa
    I've looked through an A2L and there is a supercharger ratio value that is set at 2.5 on the stock file so they would have had to have changed that I'm thinking but overall map calibrations I doubt they touched. I'm wondering if the car bleeds boost as a result.
    Jan 09 2010
    New York
    Ok car is flashed APR Stage 2! Dyno numbers is 320whp/310wtq with opened bypass valve and low timing on 93Oct … I send logs to APR so they can take look what needs to be tweak on file for my car. Even with opened bypass and 6300rpms redline car makes some gain and better result at 1/4 mile also feels awesome and smooth on street. Tomorrow Q7 getting new TCU file by **** IG: melen_tcu **** Q7 will have 7500rpms redline this is another 20wph+ just because higher rpms and faster supercharger spin means more boost. Soon as APR tweak stage 2 I will start work on adaptation of UC kit and then back to EFI Logics for flash!
    So with bypass shut off + better timing 19-20* + 7500rpms I think I should pick up another 50-70whp easy on 93Oct. Thank guys and more to come
    Jun 07 2019
    London, UK
    Interesting numbers for the SUV
    I've not heard of this platform being pushed to 7500rpm. Would that TCU file work on UK spec cars?
    Very intrigued to see how stock HX and your chiller hold up
    Jun 05 2018
    magimmeMVE
    Usa
    You sure that was the dual pulley file they flashed? Single pulley boosts to about 1 bar with flap closed. That looks low.
    Jan 09 2010
    New York
    We scanned all info from TCU and sendt to HP Tuners so they can release file for us! I'll let you know guys...
    I can't confirm that but they should do stage 2 Dual Pulley flash... I'm waiting on APR all the logs send. Also logged fuel parameters and secondary fuel at wot only 5% active that means it's a lot more fuel in CREC platform but APR Not support this in their tune I really want to run Full E85 that would insane
    Nov 27 2015
    UK, West Berks
    FYI mine peaks around 2.25 to 2.3 bar.
    @stevephilp - I am fairly sure that I have the "standard" MRC tune, with a few adjustments to allow for the difference in pulley size. Unfortunately the difference is due to MRC mis-communicating the size I needed to buy. However I am quite happy with the performance it gives on the standard tune.
    Jan 09 2010
    New York
    Guys I upload wrong Dragy result of stock Q7 vs tuned one sorry my bad ! Here is Tuned vs stock
    Jun 05 2018
    magimmeMVE
    Usa
    That's relative pressure not absolute. So 1.25 to 1.3 bar at sea level. So it looks like you're not bleeding boost to me. As wrong as it sounds - you'd need to log the supercharger 'regulator flap'.
    Jun 05 2018
    magimmeMVE
    Usa
    @dippy I followed your thread before I bought mine. Would love to compare your MRC 189 to mine. Exeter.
    Nov 27 2015
    UK, West Berks
    Yes, that is the ECU reading which measures boost pressure on top of atmospheric. There's not an easy way to just show the boost pressure. But I can view the atmospheric pressure if I need to - but it doesn't change much around here so I don't care. I can also view the regulating flap - it definitely opens to "bleed" boost.
