Results 1 to 9 of 9
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    P0606 - ECM/PCM processor and EPC
    Looking for some feedback as I have been consistently throwing the car into limp mode under high throttle driving, especially shifting from 3-4. I can’t tell if it happens during throttle or when I left off and shift again but it is very consistent. I haven’t been able to grab a data log yet so I’m going to do that but I don’t believe this is related to my misfire issues that I was seeing earlier throwing the EPC. Those cases also tripped a CEL and a misfire code. This doesn’t consistently signal a CEL.
    Any ideas? I will be reaching out to 034 as well for feedback but I’m curious if anyone had come across this?
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Is this reproduce easily ? If so maybe we could log . There’s hundreds of possibilities that cause limp .
    Is it only when shifting gears ? Or does this occur at WOT?
    IF that’s the only code popping up then it’s seems like your ECU it’s self if the issues
    Mar 28 2017
    Quote Originally Posted by Rodizzle View Post
    Yeah very easy to reproduce. I believe it has happened both when shifting gears AND above 7k rpm at WOT. I’ll try to get some logs to better see what’s going on.
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by JACKAL View Post
    Is it only during 3-4 change or in lower gear under launch conditions? Log LPFP and HPFP data as well.
    Jun 17 2015
    Bayarea
    Quote Originally Posted by bajan01 View Post
    Yes there is a possibility of the pumps taking a shit . I was thinking more of a clogged Cat but then again he has test pipes
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    You're on 034 e40 tune right? Message Nate it's a known issue and 100% tune related.
    This is the fault you're getting
    6372 - Control Module Malfunction - DBW Throttle Monitoring
    P1388 00 [167] - -
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Mar 28 2017
    Thanks all for the feedback. I’ll see what 034 comes back with. It’s definitely frustrating as any time I start getting on it and rolling the gears I hit the EPC. I’ll try to get more information though and go from there.
    Mar 28 2017
    Quote Originally Posted by Morritse View Post
    P1388 00 [167] - -
    Yes I’ve seen this come up as well. Any idea why? It sucks because every time I try to through the gears and have a spirited run I end up in limp mode. My friend with an M550i kept up with me today because of it so naturally I’m frustrated lol
    Mar 28 2017
    I was in touch with 034 today and they did indicate that they had seen this with another user. I flashed a different revision, and now I am back to normal with no issues. I appreciate everyone’s advice, and of course 034 for putting out a fix.
