Results 1 to 11 of 11
    Junior Member Two Rings
    Jul 18 2019
    Europe
    Quick question about the vacuum pump gasket
    Good evening people,
    I will be happy if someone could reply to my weird question.
    I bought a new vacuum pump gasket from the dealer and changed it, however, the next day (today) I had to take off the pump again, and to put it back, meanwhile I've noticed the two blue lines between the holes for the bolts fell off. I assume this is kind of sealant or something like that, but they peeled off easily.
    Should I worry about them, and to buy a new one, or to take it off, and to put silicone, or to leave it like this?
    I realize the question might be stupid, however, I prefer to ask, and to do something while the car is disassembled instead of putting back together everything, and to strip it off again.
    Thanks in advance!
    Stay healthy everyone!
    Emil
    Established Member Two Rings thatauditech34's Avatar
    Aug 31 2018
    Subaru Forester, 1968 Chevy Nova, 2016 Kawasaki Ninja 650, 2001 Yamaha YZF R6
    Ohio
    That seals the split between the cam cover cylinder head. I’ve only had one success in putting a tiny bead of RTV over a used gasket. It’s just easier to get a new one.
    Jul 16 2018
    Atlanta
    The repair manual says "Note: Replace the seal." as one of the dismounting notes. So Audi intends for that seal to be replaced anytime the pump is dismounted.
    Jul 18 2019
    Europe
    I understand, but the seal is brand new, I didn't even start the car.
    Jul 16 2018
    Atlanta
    But you compressed it and uncompressed it. The amount of look at it and you have to replace it seals and fasteners on this car is absurd. At least the thing is less than $10.
    Jul 18 2019
    Europe
    It's not about the money, it is about the quarantine. Everything is closed, nothing works here - I cannot go to Audi (the price is 21 EUR btw, but still is ok), I cannot order online because even the courier companies don't work. Anyway, I will put silicone just two small lines there, just to start the car, and once the quarantine is over, I will buy new one.
    Feb 15 2016
    Cambridge,Ontario
    It will.be fine..put a couple of dabs on and move on.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 18 2019
    Europe
    Thanks for the support guys!
    Nov 21 2019
    09 A4 Quattro 03 VW GTI
    Erie,PA
    Quote Originally Posted by EMark View Post
    i understand what you're going through man,
    sometimes we are here asking for advice, not for the advice itself, but to hear somebody say what we wanted to hear.
    Treat me as a fool for im still learning...
    Oct 24 2015
    Perth, WA
    this, just be clean and careful
    My respray thread
    Jul 18 2019
    Europe
    Quote Originally Posted by Ejad View Post
    Hahaha, you are 100% right man. I was hoping someone to say ... hey dude, this is bullshit, don't worry, put it as it is.
    Anyway, I took it off, but decided it to put a new one. Actually I was having a new one, but not original (I screwed up original one). A month ago I bought a refurbishment kit which was including all sealants, however the metal one I didn't like it, it was thin and single layer, not as the original one threefold layer. So, in the end I mounted the aftermarket one. Hopefully will not be leaking.
    PS: Just in case I kept the original one, the new one, if this (the aftermarket gasket) is not good, I will put the original with silicone.
