Results 1 to 9 of 9
    Junior Member Two Rings
    Mar 03 2019
    Boston
    2010 A6 3.0T Secondary Air Pump Relay and Fuse Location Please
    Code: P0492
    The Secondary Air Injection pump is not turned on during the start up. A cold start up. I tested the pump is fine, but no power to it. that leads me to its relay and fuse, but I can not find them. I checked some online diagrams, they are not match with my car.
    Can anyone let me know the location of relay and fuse for this pump? I checked the E Box in both sides under the hood. The biggest fuse I can find are 20 A and 80 A. The fuse should be 40A or 50 A?
    Aug 23 2018
    Yorkshire England
    If you find out can you post it up.
    I Also have a secondary air supply issue
    Don't know whether its not working, staying on or just blocked with crap.
    Regards
    Brad
    Sent from my SM-G973F using Audizine mobile app
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Fuse and relay should be in the Ebox on the right in the plenum chamber. The fuse is 50A. The fuse is in pos. B in the picture. The relay is in pos. 3
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Mar 03 2019
    Boston
    Quote Originally Posted by AudiNike12 View Post
    I think the above picture is from below link: When I opened it, I see the ECU computer and one relay and one 80A relay. The layout is different. Do you have a picture from the actual vehicle?
    https://fusesdiagram.com/audi/fuses-...udi-a6-c6.html
    Oct 10 2017
    Sweden
    I don't have a pic from the actual vehicle. I could take a picture of mine tomorrow. It's a 2005 but should be the same location.
    It's the same in this pic:
    Audi TT 1.8T -99
    Mar 03 2019
    Boston
    Thanks for sharing. I will open the box again and take some pictures. Yesterday I did see the 80A fuse (OK), and a computer ECU, and a relay (OK as well. not sure what it is, I checked anyway. it looks like the SAI relay based on the diagram). That is all I see. I don't see any 50A or any other fuses as shown in your diagram.
    Mar 03 2019
    Boston
    Quote Originally Posted by PullItCross View Post
    It has been raining all day here today, I am afraid to open the hood. Car parks outside. Dying to find out, Damn!
    Mar 03 2019
    Boston
    One relay, one 80A, one 60A. All fuses are fine. The relay is good too. Not sure if I am looking at the right stuff. Can you take a pic of your car for comparison?
    Mar 03 2019
    Boston
    Never mind. I think the layout matches your diagram. AudiNike. Thank you! I was just surprised by the 80A fuse because I expected to see a 40A or 50A fuse. BTW, where did you get the diagram from? I need to get a book or manual like this. Thank you again.
