Also, from a manufacturability standpoint. (
https://en.wikipedia.org/wiki/Design...ufacturability) I believe the cast product is being made from a cost standpoint. Cast products are much cheaper to produce in the long run.
One thing to keep in mind, temp resistant silicone will reject more heat than a cast aluminum product. Aluminum retains heat, silicone does not. Here is a little calculator for you:
https://www.engineeringtoolbox.com/o...ent-d_434.html
Thermal conductivity for Silicone is around 0.2 W/mK (sorry im a thermo engineer nerd)
For aluminum it's around 237 W/mK
What this means is, the aluminum cast product absorbs roughly 1000x more heat then aluminum... 237/0.2 = 1185
There could also thought from the cast aluminum that you could be minimizing potential for collapsing. That would make sense, but we tested the silicone (which is also a steel belted product on the inside) and it held up just fine.
