Results 1 to 40 of 51
    May 24 2018
    San Francisco ca
    265/35s on S5 rotors on S4
    Read a lot of threads of good and bad experiences with 265s on s4s...I have a 13 s4 that I’m gonna put s5 et33 rotors on soon..looking at lowering the car 1 inch and running 265/35/19s...anyone running a similar setup or have pics..?
    Thanks
    Paul
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    I run 265/35 on 19x9 Et 34 on a stock suspension, rubs on large bumps.
    May 24 2018
    San Francisco ca
    Thanks, any pics of your car setup
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    Quote Originally Posted by B18b1ex View Post
    It runs on stock suspension?
    What did the s4 came with for OEM wheel and tires?
    I have an s5. 2015 with black optics or whatever they called it back than, it came with 255/35 on 19s
    Sent from my SM-G965U1 using Tapatalk
    Jul 02 2004
    FL
    My wheels are 19x9 Et 34. 265/35/19
    Stock S4 is 255/35/19.
    I have s5 rotors but currently stripping those to repaint.
    Feb 02 2014
    Focus RS, Audi S4 & S5
    Knoxville, TN
    It "could" work but depends on tire choice. The B8.5 had a higher rear suspension/ride height than earlier version. The S5 wheel is 10mm further out than S4. A 265 tire adds another 5mm so total is +15mm. On my 2015 S4 lowered with stock wheels and Michelin AS/3, I have very little clearance at the lower rear edge of back wheel opening. I don't think I could get a et 35 and 265 not to rub. A Continental or other brands that have a "rounder" sidewall could work....but I think it would be tight.
    Feb 16 2019
    Waltham
    Here’s my setup with 265/35/19
    Wheels are 19x9.5 et 40
    Lowered on oe H&R springs
    Love the meaty setup
    Jul 02 2004
    FL
    Quote Originally Posted by Ecinka87 View Post
    Does that rub?
    Feb 16 2019
    Waltham
    Only on big bumps
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    how low is that? 1"?
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Feb 16 2019
    Waltham
    Not that low enough to fill in the wheel gaps. Pretty stock feeling ride too
    Jan 25 2015
    VA
    what wheels are those? I like it.
    Feb 16 2019
    Waltham
    Fastco fc04a
    Feb 16 2019
    Waltham
    But ya it’s a 1” drop
    Jun 02 2019
    serenity valley
    I'm looking to getting some lowering springs. Just cant decide on the OE or the sport
    Senior Member Two Rings Arctic Silver's Avatar
    Jun 26 2015
    2011 Audi S4, 2013 Audi S4, 2018 Honda Odyssey
    Indianapolis, IN
    Quote Originally Posted by whts4 View Post
    It’s actually more complicated than that. Since the width of the wheels is also different the amount the setup moves out is more than +10mm. Between a 19x8.5 et43 stock S4 wheel and a 19x9 et33 S5 wheel the wheel alone accounts for a 16mm more aggressive setup. Adding a wider tire will further add to the problem. Many people have rubbing with a 255 on the S5 wheels and a lowered suspension. I would say stick with the 255 especially if you plan to run a historically wide or square shoulder tire like a Michelin PS4S.
    2011 Audi S4 - 6MT, Sprint Blue, Titanium Package, GIAC Stage 2, APR CPS, Bilstein PSS10, B9 RS5 380mm Front BBK, 356mm Voshmod Big Baller Rear BBK, 034 RSB, EC AK, CR-15, Trans & Diff Inserts, AWE Touring w/Res DPs, Sachs XTend, Strat Short Shifter w/BFI Knob, JXB Gated Kit, P3 Vent Gauge, E-Codes, CREE LED Fogs, Ziza LED Interior, RSNav, Fly Designs Flat Bottom Wheel
    2018 Honda Odyssey Elite - 10AT, White Diamond Pearl
    May 24 2018
    San Francisco ca
    Ecinka87, thanks...your setup is pretty much where I want to be...figuring 19 x 9 s5 et33 rotors with a 265/35 tire should work well. Going coilovers soon I’ll probably do the tires at the same time, thinking Firestone Firehawks
    Jul 02 2004
    FL
    Quote Originally Posted by Sfbimmerman View Post
    It’s going to rub on large bumps or with back seat passengers.
    May 24 2018
    San Francisco ca
    Thanks Artic Silver, I see your point...gonna throw the S5 rotors for a little and burn through the tires...I figure that’ll give me a good eyeball at what a bigger tire could look like...
    Feb 16 2019
    Waltham
    Go with the OEs good drop stock feel
    Oct 25 2013
    DFW
    Quote Originally Posted by 2by2handsofblue View Post
    Sports. Too much wheel gap with OE
    Feb 16 2019
    Waltham
    Choose wisely on tires. All tires are different specs. Like tread width and sectional width. So if your planning on 265s just pick out the smallest spec. That’s what I ended up doing. Just FYI
    Jan 25 2015
    VA
    Fastco fc04a
    are you running hub adaptor? 72.6mm hub bore? point me to the right direction.
    Jun 02 2019
    serenity valley
    Quote Originally Posted by v36sedan View Post
    I was thinking of going sport. Just wondering if it will be too low and having issues with rubbing or going over bumps
    May 24 2018
    San Francisco ca
    Ecinka87, what tires are u running...I want to run 265s but with my 4 cars, I gotta keep the budget at $200 a tire or below...
    Jul 02 2004
    FL
    The only tire worth using in that range is the Firehawk Indy.
    Oct 14 2012
    Empty...for now...
    SE PA
    At ~25.5” fender-to-ground front and rear I had some rubbing with 255/35-19 on my 19x9 et33 S5 spec wheels. I think 265 would be problematic.
    SOLD 2015 Daytona Gray S4
    Feb 16 2019
    Waltham
    Yes 72.6 to 66 hub adapter
    Feb 16 2019
    Waltham
    Yokohama advan apex actually is the smallest 265 tire you could use. I have checked all of them or the Michelin pss mo spec.
    May 24 2018
    San Francisco ca
    Wow, SteveYem, I know the s5 rotors stick out a little more, guess the 265 will be too much plus I want to do coilovers in bit too, but just an inch drop...255s will be fine....I’ve ran Hankook v12s before, might go back to those or the Firestone Firehawks Indy 500 I’ve heard good things about..
    Oct 14 2012
    Empty...for now...
    SE PA
    The face of the 19x9 et33 S5 spec wheel sits farther outboard than the stock 19x8.5 et43 wheel by approx. 16.3 mm, which is the difference in offset (+10 mm) plus half the increase in width (12.7mm (half inch) divided by two, or +6.35 mm). The position of the tire is determined solely by the offset (since the tire is centered on the wheel), so relative to the stock 19" setup the tire will sit 10mm farther outboard. The 9" wide S5 wheel will induce relatively more stretch on a given tire than the 8.5" wide S4 wheel which can help with fender clearance. This is especially evident on 9.5" wide aftermarket wheels with stock size 255/35-19 tires, and the stretch on the sidewall provides more clearance to allow that size tire to clear the fenders at lower offset applications.
    Anyway, all of that said - pictures tell a thousand words. For reference, here is a set of S5 19x9 et33 rotors with Michelin PS4S 255/35-19 tires. Ride height is around 25-3/4" fender to ground front and rear. I had some rubbing at the rear passenger side but not the rear driver. [This is because the rear subframe is not centered relative to the body/fenders, a common issue with B8/B8.5 cars which only because obvious when running more aggressive wheel+tire setups that get close to the fender.] IMO, 255/35-19 is the 'right' size tire for this wheel. Depending on the tire brand and type, there is just a little bit of sidewall stretch but the tires fill out the wheel wells nicely.
    Oct 25 2013
    DFW
    I’ve never had an issue getting anywhere. There’s about a half finger gap in the front and one in the rear. Looks great rolling
    Veteran Member Three Rings Allan691's Avatar
    Jul 23 2018
    Vicenza, Italy
    Quote Originally Posted by Arctic Silver View Post
    Is there any problem running 265s on stock S4 19” Peelers with stock suspension?
    I just want a little more visual width..
    2009 Euro-spec Black Optics S4 Avant APR Stage 2 APR SC pulley + JHM187 with APR Open Air Intake • CR-15 + AK + Eurocode USS + Diff + Trans inserts • P3
    Senior Member Two Rings kevinz's Avatar
    Aug 17 2016
    2015 S4::2010 Q7 3.6
    Quote Originally Posted by Allan691 View Post
    Stock S4 peelers are 8.5 width. I ran Pilot Super Sport 255/35/19 on stock peelers and the sidewall sits pretty square. (i have heard the PSSs are a tad squarer than some though) I think a wider tire on the S4 peelers would look weird.
    I wanted a fuller appearance with the S4 peelers and got the ECS spacer set (8mm front, 12mm back) and I thought it looked a lot better. I would do that first before getting a wider tire on the 8.5s. Are you lowered?
    2015 S4 6MT Sepang | EPL stg2 | aFe Pro 5R | ported air box | 034 intake hose | RS grille | AG590 19x9.5ET40 | PS4S 265/35/19
    Jul 23 2018
    Vicenza, Italy
    Quote Originally Posted by kevinz View Post
    Thanks. Not lowered. I like my suspension for the moment (while it functions)..
    I have 5mm and 10mm spacers currently. Even those improved the stance. I did not want to go crazy but am now wondering if 8/12 would have been better. Are the ECS 8s concentric..? My 034 5s are not and I have slight balancing issues that I need to try to work out.. Or I buythe ECS 8s.
    But really I am now looking for a wider TIRE look. I think S5 Peelers are probably the answer..
    Mar 05 2016
    I need to change tires this summer, want to go 265/35R19 (Indy 500) to get a wider look but don't want any rubbing. I have S5 5 double spoke wheel 19x8.5 ET32 with stock suspension. Is it a good idea?
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Jul 02 2004
    FL
    Quote Originally Posted by TC_S4 View Post
    Im stock and only rub on big bumps, 265 Indy 9” and et34. I think you should be okay.
    Mar 05 2016
    How much off is the speedometer?
    Jul 02 2004
    FL
    Jul 23 2018
    Vicenza, Italy
    What app is this?
