Results 1 to 19 of 19
    Feb 27 2020
    Midwest
    What Oil Are You Using in your A5 (B9)?
    Looking to do my oil changes on my 2018 A5. I notice the manual states that I can use THREE different weights?
    0W30
    5W30
    5W40
    Which do you use? I am living in the midwest - cold winters, hot summers.
    It mentions using Castrol OE performance which appears to be discontinued or near impossible to find?
    What oils are you using? Ravenol? Pentosin? Mobil 1?
    Mar 27 2014
    Medford, NJ USA
    Check the sticker under the hood. It's probably more accurate than the manual. You also need an oil that meets the VW/Audi spec listed on that same sticker.
    Oct 02 2006
    Wadsworth,OH
    Most users are going to fall into the operating temperature range that will use 5w-40.
    As for brand, my personal preference is MolyGen from Liqui Moly.
    link to oil service kits for your car - https://www.ecstuning.com/Audi-B9_A5...e/Oil_Service/
    Mar 26 2010
    US
    Quote Originally Posted by davewg View Post
    +1,
    Check under the hood oil sticker, this A5 2.0T may require VW 504 specification (which is generally 5W-30 or 0w-30 weight).
    Apparently the A4 2.0T (B-cycle) engine requires VW 508 oil.
    Your sticker may have different numbers, but should look like this (this is what it shows on on my RS5 2.9T):
    From MY 2019 Maintenance Intervals - USA:
    "502 00 / 505 00 / 505 01
    – Castrol EDGE® Professional® 5W40
    508 00 / 509 00
    – Castrol EDGE® Professional® 0W20 Long Life IV
    504 00 / 507 00 Diesel Oil
    – Castrol EDGE® Professional® 5W30 LL03"
    BMW M3 Competition X-drive
    Stage 2 Banner Advertiser Four Rings Sean@TAG's Avatar
    Jun 27 2014
    Seafox Boat, Jetta, F150, Travel trailer
    San Diego
    We are Motul 8100 Xcess guys here at TAG :)
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    Feb 27 2020
    Midwest
    Thanks everybody. I grabbed the last of Castrol Edge OEM Professional I could find on the whole internet...
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    $65 for 6 quarts. Doubt it is worth it. I think I am going to switch to Mobile 1 after this. I even called the Audi dealer and they said VW/Audi switched over to an oil made by Mobile 1.
    https://www.shopdap.com/ge555401qdsp-vw-audi.html
    They recommended I use 5w40 (I'm in Cleveland).
    I've always been a GM guy so my go-tos were always Mobile 1 or Amsoil (not gonna lie, I never buy Amsoil just too expensive and I honestly don't want to go that long between oil changes). I am new to the euro oils. Are they that much better than american oils? How would you guys rate the following oils?
    1. Pentosin
    2. LiquMolly
    3. Ravenol
    4. Castrol
    5. Motul
    Any other good oils you would recommend?
    Mar 26 2010
    US
    Quote Originally Posted by Manual2018A5 View Post
    ... Any other good oils you would recommend?
    The Audi dealers sometimes chose different brands for price. I recently checked at two Audi dealers. One Audi dealer used Castrol, the other Audi dealer used Pennzoil (they previously used Castrol, but Pennzoil is cheaper). As long as the oil meets the specification of the sticker under the hood you should be fine.
    example...VW504: Pennzoil Platinum Euro
    Here is the oil an Audi dealer supplied for my 2019 RS5: Castrol EDGE Professional 0W30 Long Life (LL III)
    Feb 27 2020
    Midwest
    Quote Originally Posted by wwhan View Post
    Oh cool. Maybe I'll switch to that (if they have a 5w30, 5w40 variant) on the next oil change as I will not be able to purchase more of the OE Professional 5w40. Kind of neat that it glows when you put a black light to it - I'm assuming it's to locate leaks?
    Veteran Member Three Rings chrisdazzo's Avatar
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    FWIW, the local Audi dealer used 0W20 Synthetic (G-E52-577-S0) on my B9 A5 recently when I brought it in for an oil change.
    '21 Ultra Blue x Black Nappa ▉SQ5
    Prem+ : S Sport : Black Optics : Carbon Atlas
    21" Black Optic Wheels : B&O Audio : S Beam
    034 Res-X Res Delete + X-Pipe : IE Polymer Intake
    12.5/15mm Spacers : 034 Trans Mount Insert
    35% Ceramic Tint : 3M Front PPF
    [_SQZME] : Previously: MKV Jetta 2.5, B8.5 A5, 8V S3, B9 A5 SB
    Mar 26 2010
    US
    Quote Originally Posted by chrisdazzo View Post
    What oil type / grade does your under hood sticker on your 2.0T A5 say to use. Does it say VW 504 0W-20 or VW 508 0W-20?
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    Just says VW 50400 or VW 50200 spec. After some research it seems I may need to go back to my dealer and have a talk with whoever did my oil change.
    Mar 26 2010
    US
    The sticker does not show the weight of the oil??
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    Newp. Owner's manual even names Castrol Edge long-life as the recommendation, but provides no further info except "see under-hood sticker".
    Mar 27 2014
    Medford, NJ USA
    2018 MY didn't specify an oil weight under the hood, but 2019 MY do. Same thing on the VW Golf R.
    I think the stickers were purposely changed for 2019 because there was so much confusion on the 2018s as to the correct oil weight. When I took my R for its first oil change the advisor had to look up the correct oil. I'm happy the 2019 sticker lists both (spec and weight), so there should be no confusion.
    The oil weight spec also changed between 2018 and 2019 leading to yet more confusion.
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    Feb 27 2020
    Midwest
    LOL I guess if Audi doesn't care, we shouldn't...
    Next it will just say "OIL" as the recommended type...
    Feb 27 2020
    Midwest
    Quote Originally Posted by Sean@TAG View Post
    I'm hearing good things about Motul: been around for a long time, less oil consumption from reviews, not overpriced.
    Ravenol seems overpriced and oil analysis shows it varies greatly from batch to batch as far as chemical consistency.
    Pentosin, a few have stated, makes their Audis seem to run and idle much quieter. Still about $50 for 5 quarts in US.
    Can we use LOW ASH motor oil in non-diesels? Is low ash just for the diesel Audis? I m liking this LiquiMoly:
    https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
    Mar 26 2010
    US
    ...Can we use LOW ASH motor oil in non-diesels? Is low ash just for the diesel Audis? I m liking this LiquiMoly:
    That oil covers VW 502 /505 spec only.
    Jan 25 2007
    Junk
    San Francisco
    Always go with Oil Approval 1st, before weight. The approval means there are specific additives that VAG specify for that engine type. Also keep in mind that certain specs i.e. 504/507 are/were only available in 5W30. The new spec 508/509 seems to only be available in 0W20. The last resort with the exception of diesels. 502 spec'd product if 507/508 arent available.
    2018 RS3 STG II
