I have a video I need to finish but I just used this product on my RS5.
The short answer is this does NOT replace a manual cleaning like JHM posted (or walnut blasting) by any means.
With that said...I used the CRC cleaner 10,000 miles after walnut blasting my intake valves. It did work and reduced the carbon. I do not see it reducing the carbon enough to replace a manual cleaning however. I pulled my intake manifold before, took photos/video and then after I used the CRC valve cleaner.
On top of that and most importantly, you're likely moving small deposits from the intake valves, through the combustion chamber, out the exhaust, only to be embedded in your catalytic converters. Not good.
I do think the carbon cleaner tends to produce a "waste" product similar to thick varnish which probably burns in the combustion cycle. I don't have a real handle on the size of the particulates produced though. So it's sort of a crap shoot.
I talked to CRC about it and they basically said to wait at least 1,000 miles in between cleaning sessions. Just keep in mind it may be clogging your cats with carbon.
