Unfortunately I don't know much about the specifics of the sport exhaust, and I'm not sure anyone has cut one open to get specifics.
Based on readings I feel I understand how the standard exhaust works. If the sport exhaust is the same just with the valve re-located I don't know for sure.
The standard exhaust comes into the muffler like seen here.
During MOST operations on the standard exhaust the valves are OPEN. (They basically only close for 4-cylinder operation.) and most of the extra "performance" noise is created by the soundaktor.
You can see the exhaust comes in one pipe and has two options to flow out. The long skinny pipe which is open all the time or the fatter short pipe with the valve on it. So that is fine and perhaps understandable. MOST of the time in V8 operation the valve is open and exhaust flows out all pipes, then in 4-cylinder mode the valves close altering the sound characteristic in a way to avoid (Audi term) "buzzy" noises from 4-cylinder operations. Coupled with ANC and active motor mounts to eliminate any unwanted noises/vibrations.
Now on the sport exhaust as you know the one valve is moved so if it is closed it blocks the entire driver's side muffler. If the valve is closed exhaust gasses for that bank would have to cross-over in the suitcase resonator to the passenger's side. (I honestly don't know what would happen if you remove the suitcase for straight-pipes without putting in a suitable crossover. Probably not good.) IIRC the valve is closed at idle on the sport exhaust as some I have read some say steam only comes out the passenger's side on cold days. This contradicts the standard exhaust operation as the valves are open at idle on the standard exhaust.
Standard exhaust operation from testing by another member:
4 Cylinder Mode - Exhaust flaps are always closed when the engine is running in the 4 cylinder mode, regardless of whether the exhaust is set to comfort or dynamic.
Parked/Low Speed - Exhaust flaps are always open when the car is stopped or the car is running slow, regardless of whether the exhaust setting is comfort or dynamic.
Dynamic Mode - While I did not do complete testing in every possible situation, it seems like the exhaust flaps are always open when in the dynamic mode, unless the engine is in the 4 cylinder mode.
Comfort Mode - The exhaust flaps move to the closed position at around 65 to 77 Km/hour. When the flaps are closed and the car is coasting to a stop, the flaps open around 25 Km/hour. [Vag-Com displays the units in Km/hour, not mph]
So question still remains, how exactly does the sport exhaust operate?
Safe to say in V8 mode under acceleration both valves would be open. (Does one or both close briefly on upshift to give the fart noise?)
In 4-cylinder mode is just the driver's side valve closed? I doubt so as I think they are not interdependently controlled valves. Either both are open or both are closed. (I could be wrong.) But any way you slice it at least one of the valves has to close in 4-cylinder mode.
Are the muffler internals of the sport exhaust the same as the standard exhaust?
AFAIK the pops and crackles of the sport exhaust are actually programmed into the ECU and have nothing to do with the sport exhaust itself.
Hoping someone else can chime in with more info.
