2012 A6 Prestige here. As the title says, having issues with my rear inner tail lights. Started with the left where the top LED strip intermittently stopped working. I got a new one for cheap and swapped it out which fixed the problem. Fast forward 3 months and the right inner tail light is doing the same exact thing. Turning off the car and turning it back on removes the warning in the mmi but it keeps intermittently coming back. I plan on swapping out the right one now, but just seeing if anyone else had this issue and it’s just parts coincidently failing a few months apart, or I have bigger issues. FWIW, when I removed the left it had quite a bit of condensation in the housing. Scan of VCDS just shows an intermittent fault for the turn signal and nothing more.
