Results 1 to 4 of 4
    Sep 10 2017
    Brunei Darussalam
    Reverting to IS12 from IS20
    So I have a B8.5 1.8T A4 ( CVT ) Then I drove it this morning the EPC warning came on + a warning of Max. engine speed 4000rpm. Sent it to my local Audi dealer they told me the turbo's toast ( I have an IS20 on it ) with a fault code: 14914 P029900 Turbo/Super Charger Underboost (0110100 passive/sporadic ) Upon clearing the fault codes, the car wouldn't idle properly and the engine would occasionally stall out ( not to mention there's absolutely zero power as well ) So I just thought to install back the original IS12 turbo I had lying around.
    I'm wondering does reverting back to IS12 need a retune ( or reprogram of sorts ) to run the car properly and what do I need to use back on the IS12 from the IS20?
    Veteran Member Four Rings Traptalk's Avatar
    Oct 14 2018
    Buffalo, NY
    If you needed a tune to go from the is12 to the is20 then you will probably need to revert the tune back as well
    ig: @wastegate_warriors
    i like meth
    Junior Member Two Rings
    Aug 23 2018
    bagged and modded 1969 VW Beetle
    Durban/KwaZuluNatal/SA
    Quote Originally Posted by ahmodity View Post
    What vehicle did you source the is20 from if I may ask?
    I have an Is20 from a mk7 GTi but it's so different compared to the B8.5 is12 because of the longitudinal engine that I didn't even attempt to convert it
    "I am the warranty" - Tavarish
    Daily drive an '15 Audi B8.5 A4 1.8T FSI 125KW stocky
    Show drive a '69 bagged VW Beetle which has probably costed me more than the Audi did
    Jul 16 2018
    Atlanta
    longitudinal IS12 would be from the longitudinal EA888 Gen 3 1.8T, engine code CJEB.
    longitudinal IS20 would be from the longitudinal EA888 Gen 3 2.0T, engine code CNCD.
    So anything with a CNCD in it, which would be from B8.5 A4/A5/Q5 in relevant markets (certainly not North America).
