Results 1 to 12 of 12
    Oct 14 2012
    Empty...for now...
    SE PA
    Fault Codes after Throttle Body Adaptation attempt - B8.5 S4
    Hopefully you all can help me diagnose what's going on with my B8.5 S4 6MT
    Short version: I used VCDS (19.6.2) to run the Throttle Body Adaptation function, but the adaptation failed and VDCS showed a message along the lines of "...Aborted | Safety Reasons...", then the car threw a lot of seemingly unrelated fault codes shown in the auto-scan log below. The car went into limp mode, with rough fluctuating idle and barely any throttle response. Note, I excluded all items from the auto-scan where no faults were found.
    Long version:
    I've been chasing an issue with seemingly lousy throttle response when trying to start out in 1st gear. I am in a B8.5 S4 running EPL Stage 1 tune (although the issue exists when I'm on the stock tune as well). Thinking it may be related to the anti-stall feature that exists on the B8.5 6MT where the car automatically adds throttle to keep the engine from stalling if the driver isn't giving enough gas while trying to engage the clutch, I went into VCDS (19.6.2) Select Control Module > 53-Parking Brake > 10 Adaptation and played around with the settings for 'Drive Away Assist'. I was able to change the settings and went for a test drive and didn't notice any driveability issues or alarms/fault codes. Changing these settings did not seem to affect the laggy throttle response issue either.
    Then on a whim I thought to go into the 01-Engine control module and look at the Throttle Valve Adaptation section. Before running the 'Test of Throttle Valve Adaptation', I clicked on 'Show Measuring Data' and selected Throttle Position and Accelerator Pedal Position to see what it was reading before running the test. With my foot off the gas pedal, it was showing throttle position around 14%, and then with the pedal pushed all the way to the floor it was showing around 85%. This seemed unusual to me so I proceeded with running the throttle valve adaptation test. [Can someone please comment on what values I should be seeing here?]
    When I ran the test it immediately returned an error message. I did not get a screenshot of it but it was in red font and along the lines of "...Test Aborted | Safety Concerns..." or something like that. At this time the dashboard lit up with traction control system fault, sport differential fault, TPMS fault and MIL light. I ran an auto-scan in VCDS which returned all of the fault codes shown in the log below. Then I turned the ignition to the Off position, let it sit for ~10 seconds, and started the engine. Immediately the car was idling very rough, fluctuating, with barely any throttle response. TPMS, stability control, sport diff and TPMS warning lights were still illuminated and alarms beeping.
    I turned the car off, ran the auto-scan again (which found all those fault codes again) and this time cleared all the fault codes. Then I started the car up again. This time the engine rev'd to ~1500 rpm and hung there for a moment, then dropped to its normal ~700 rpm but it was fluctuating/cycling a bit. I turned the car off, let it sit for a few minutes, and started it again. That time it did the initial high rev and hang thing again, but seemed to settle out at a more normal and steady idle. The stability control, sport diff, TPMS warnings did not come on this time.
    I went into the 01-Engine module and looked at the fault codes section which showed the two fault codes shown at the bottom of this post. When I would clear them they would come right back. And oddly enough, when I would go into the 03-ABS module, the stability control, sport diff and TPMS warning alarms would trigger again as soon as I clicked into the module, whereas they would not come on otherwise.
    Can anyone give me any guidance as to what could be happening here? Does it seem like I have an issue pertaining to the throttle body? And if so, could a throttle body issue cause all of these other fault codes to pop up? Some of them seem completely unrelated, like
    Auto Scan
    Monday,09,March,2020,18:51:51:05930
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
    VCDS Version: 19.6.2.2 (x64)
    Data version: 20200210 DS308.0
    www.Ross-Tech.com
    VIN: WAUDGAFL0FA045640 License Plate:
    Mileage: 105570km-65598mi Repair Order:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
    62 6C 72 A9
    VIN: WAUDGAFL0FA045640 Mileage: 105570km-65598miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
    Part No SW: 8K5 907 551 F HW: 4G0 907 551 A
    Component: 3.0l V6 TFSIH07 0001
    Revision: --H07---
    Coding: 0A190034052608060000
    Shop #: WSC 06208 000 00000
    ASAM Dataset: EV_ECM30TFS0218K5907551F 001001
    ROD: EV_ECM30TFS0218K5907551F.rod
    VCID: 3979098BB84EB887A2-806C
    2 Faults Found:
    6515 - Throttle Valve Controller
    P1545 00 [165] - Malfunction
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 105570 km
    Date: 2020.03.09
    Time: 18:40:17
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 101 °C
    Intake air temperature: 63 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.780 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 0 /min
    MAF_ENVD: 0.00000 mg/stroke
    Coolant temperature (unfiltered): 95.25 °C
    Engine: operating status: ES
    Engine load: 0.000000 %
    Vehicle speed: actual: 0 km/h
    6536 - Throttle Actuator (J338)
    P1579 00 [037] - Adaptation Not Started
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 105570 km
    Date: 2020.03.09
    Time: 18:40:39
    Voltage terminal 30: 11.984 V
    V_TPS_1_ENVD: 0.72266 V
    V_TPS_2_ENVD: 4.25781 V
    Coolant temperature (unfiltered): 94.50 °C
    TIA_AM_SCHA: 67.50 °C
    Battery voltage: 12.492188 V
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
    Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
    Component: ESP8 quattro H09 0020
    Revision: -------- Serial number: --------------
    Coding: 281D1A01
    Shop #: WSC 06325 000 00000
    VCID: 0919B94BA02E6807F2-805C
    3 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 72
    Mileage: 101473 km
    Time Indication: 0
    Date: 2019.12.26
    Time: 11:00:44
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x07A2
    Hex Value: 0x0015
    Hex Value: 0x1096
    Hex Value: 0x0000
    01314 - Engine Control Module
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 105570 km
    Time Indication: 0
    Date: 2020.03.09
    Time: 18:44:50
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0022
    Hex Value: 0x000B
    Hex Value: 0x468C
    Hex Value: 0x0000
    01324 - Control Module for All Wheel Drive (J492)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 105570 km
    Time Indication: 0
    Date: 2020.03.09
    Time: 18:44:51
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2222
    Hex Value: 0x000E
    Hex Value: 0x5090
    Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 KM HW: 8K0 907 064 KM
    Component: BCM2 2.0 H15 0711
    Revision: 00002001
    Coding: 0F814040000000000000
    VCID: 0501B57B8C360C6796-8050
    Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Serial number: 0214000154224016
    1 Fault Found:
    00955 - Key 1
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 178
    Mileage: 101473 km
    Time Indication: 0
    Date: 2019.12.26
    Time: 11:01:08
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
    Component: KLIMA 3 ZONEN H04 0122
    Revision: C1000000 Serial number: 01160920140140
    Coding: 6618228000
    Shop #: WSC 06325 123 12345
    VCID: 77FDCFB3C6DA6EF794-8022
    1 Fault Found:
    01207 - Control Module for Auxiliary Heater (J364)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 101
    Mileage: 101473 km
    Time Indication: 0
    Date: 2019.12.26
    Time: 11:01:06
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
    Component: 4 Wheel Drive H15 0100
    Serial number: 000209140001024
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 2F6D37D3760A66370C-807A
    1 Fault Found:
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
    U1017 00 [137] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 32
    Mileage: 105570 km
    Date: 2020.03.09
    Time: 18:44:51
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0345358635
    Coding: 0106063A00FA404580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0080
    Serial number: 00000000000000880401
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS050 H08 0043
    1 Fault Found:
    01565 - Luggage Compartment Light (W3)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 27
    Mileage: 101473 km
    Time Indication: 0
    Date: 2019.12.26
    Time: 11:01:22
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
    Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
    Component: DSP Prem H05 0030
    Revision: 00005001 Serial number: 94813034205706
    VCID: 2D512DDB740614273E-8078
    1 Fault Found:
    03029 - Subwoofer (R157)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 107
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.00 V
    Temperature: 21.0°C
    Temperature: 23.0°C
    Bin. Bits: 00000100
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
    Component: EPB-4 H02 0005
    Revision: -------- Serial number: 00000001540196
    ASAM Dataset: EV_ParkiBrake 001028
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 3A7B1687BD48B39FAB-806E
    1 Fault Found:
    464384 - Function Restriction due to Faults in Other Modules
    U1113 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 105570 km
    Date: 2020.03.09
    Time: 18:44:49
    Voltage terminal 30: 10.3 V
    Internal Fault ID: 188
    Network management state: normal
    Function light in parking brake button: On
    Red operating lamp: On
    Red warning lamp: OFF
    Green operating lamp: OFF
    Yellow warning lamp: OFF
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: Not operated
    Status ParkingBrake left: Set
    Status ParkingBrake right: Set
    End-------------------------(Elapsed Time: 03:53)--------------------------
    Fault Codes found in 01-Engine Module
    Monday,09,March,2020,18:53:49:05930
    www.Ross-Tech.com
    Address 01: Engine Labels: 06E-907-551-CGW.clb
    Control Module Part Number: 8K5 907 551 F HW: 4G0 907 551 A
    Component and/or Version: 3.0l V6 TFSIH07 0001
    Software Coding: 0A190034052608060000
    Work Shop Code: WSC 06208 000 00000
    ASAM Dataset: EV_ECM30TFS0218K5907551F 001001 (AU48)
    2 Faults Found:
    P1545 00 [036] - Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 105570 km
    Date: 2020.03.09
    Time: 18:40:17
    P1579 00 [047] - Adaptation Not Started
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 105570 km
    Date: 2020.03.09
    Time: 18:40:39
    Coolant temperature (unfiltered): 96.75 °C
    TIA_AM_SCHA: 69.00 °C
    Battery voltage: 9.953125 V
    Monday,09,March,2020,19:01:51:05930
    www.Ross-Tech.com
    Mode 07: Pending emission related fault codes
    Address 7E8: 1 Fault Found:
    P2101 - Throttle Valve Actuator Control System: Malfunction
    Monday,09,March,2020,19:12:33:05930
    www.Ross-Tech.com
    Address 03: ABS Brakes Labels: 8K0-907-379-V2.clb
    Control Module Part Number: 8K0 907 379 CP HW: 8K0 907 379 CP
    Component and/or Version: ESP8 quattro H09 0020
    Software Coding: 281D1A01
    Work Shop Code: WSC 06325 000 00000
    3 Faults Found:
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 105570 km
    Time Indication: 0
    Date: 2020.03.09
    Time: 19:08:19
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2222
    Hex Value: 0x000B
    Hex Value: 0x4691
    Hex Value: 0x0000
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 105570 km
    Time Indication: 0
    Date: 2020.03.09
    Time: 19:08:19
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2222
    Hex Value: 0x000E
    Hex Value: 0x5091
    Hex Value: 0x0000
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 105570 km
    Time Indication: 0
    Date: 2020.03.09
    Time: 19:08:33
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0022
    Hex Value: 0x0015
    Hex Value: 0x108A
    Hex Value: 0x0000
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Not sure what your issue is, on the B6 all you had to do for adaptation was turn the key to position 2, put the gas pedal to the floor for 3s, turn the key off, and wait 2min.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by MacFady View Post
    It's a similar procedure for the B8:
    Manual throttle body adaptation:
    The Throttle is "Drive By Wire" and adapts to your particular driving style. Do a TBA (Throttle body adaption).
    1. Get in your car, it doesn't matter if you close the door or not.
    2. Turn the key to the on position, the position just before the starter turns over.
    3. Press the gas pedal to the floor with the key in the "on" position.
    4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position(don't remove the key), then release the gas pedal.
    5. Wait 2 mins. for a full alignment. During this time you may hear very faint noises and clicks. I
    only heard one sitting in my car, if I got out and popped the hood I might hear more.
    6. Drive the car as you always do.
    Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so
    I noticed a big change after erasing my history. It is not hard to do this, just follow the
    instructions - Key on, pedal down, 5 sec, key off pedal up, wait 2 minutes.
    Keep the key in for the entire thing.
    http://www.audizine.com/forum/showth...681#post193681
    Jul 31 2016
    PA
    How is your battery? Lots of people get a bunch of random electrical problems when it starts to go.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by djn876 View Post
    That’s a good question. The car is now 5.5 years old so maybe the battery is starting to show signs of failure. I haven’t had any other symptoms though. I’ll have to plug in vcds again and see if I can find where to check battery health.
    Aug 10 2011
    330i ZHP
    Quote Originally Posted by SteveYem View Post
    Or just use a multi-meter.
    Oct 14 2012
    Empty...for now...
    SE PA
    True haha
    Oct 14 2012
    Empty...for now...
    SE PA
    For anyone who has checked throttle position in VCDS, what is the expected range in terms of % open position? I was finding ~14% when not touching the peal and 85% with the pedal to the floor, but I was expecting more like ~5% when not touching the pedal to 100% with pedal to the floor.
    Jul 18 2019
    France/paris
    Your findings are right (from 15 to almost 79/85), it's ok like this !
    Veteran Member Three Rings street2gen's Avatar
    Oct 13 2013
    Whitewater, WI
    I would clear faults and then run the adaption immediately after that, dont start the car in between.
    It can have problems with stored and active faults while trying to do the adaption.
    '11 S4 | 034 E40 | 034 TCU | 3.315PR-Ported | iABED 75 | MercRacing HX | AutoTech HPFP | ECS Intake | JHM Test Pipes | AWE Resonated |
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Antea View Post
    Thanks for your reply. Why does it not go all the way to 100%?
    Oct 13 2013
    Whitewater, WI
    it will when you get a successful adaption, otherwise its "learned" throttle response.
