Results 1 to 9 of 9
    Established Member Two Rings swbca's Avatar
    Jul 30 2015
    Minnesota
    Is there a trick for centering wheels when using spacers without hub-centering
    I needed spacers to clear some large calipers. 6mm would be enough, but APR does not make hub-centric spacers small than 10mm. The 6mm caused wheel balance shake. I also had some APR 10mm with hub centering and they run smooth - no balance problem, but I wanted to use the thinnest spacers needed for the calipers.
    When I called APR to return some other 6mm that I had ordered but not opened, they said that I should just "center them carefully". Sounded like a smart-ass remark to me. I didn't bother to ask how to do that. I had tried tightening the lug bolts in small increments to permit the acorn taper in the bolts to help center before clamp-force against the hub took over, but it didn't help.
    Mar 31 2008
    eS-4
    CAL*SO
    You should return them. You need hubcentric to keep the wheel from shaking.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Centering them carefully is not the answer. The small spacers generally are not hubcentric because they are thin enough that there is usually a small amount of the hub ring that still protrudes past the spacer for the wheel to sit on, but as you found out that is usually not enough to prevent vibrations etc. because you still end up with more of a lug-centric set-up instead of a true hubcentric set-up.
    Can I ask why you want to just use the smallest spacers to clear the caliper instead of going with say 10mm? Do you have clearance issues with the fender otherwise with 10mm spacers due to your wheel offset? You might be able to find 8mm Hubcentric spacers but I can't recall seeing 5mm hubcentric spacers before (even though lots advertise them as such, you only have to look at a picture to see they are not, in terms of them having a lip for the wheel).
    Jul 30 2015
    Minnesota
    Quote Originally Posted by Fresh.S4 View Post
    I am returning them. APR is a quality brand, making me wonder why the sell the thinner spacers.
    Jul 30 2015
    Minnesota
    Quote Originally Posted by MacFady View Post
    Can I ask why you want to just use the smallest spacers to clear the caliper instead of going with say 10mm? .
    No good reason, except keeping the offset as close to stock as possible. I track the car with big brakes and track tires . . a lot of braking at around 1.3 G and I read an article on the keeping the braking forces centered on the steering pivot axis (don't remember the precise terminology) to minimize the tow-out forces that happen when the tires are moved out. But its no big problem going 4mm thicker to solve the problem, now that I know the 6mm shake.
    Aug 07 2012
    Vancouver
    Are you using aftermarket rims? Many of the smaller spacers only work with factory rings, because they have an integrated chamfer that’s works with the wheel design to assist with centering. Most aftermarket wheels have a significantly large chamfer, since they assume you will use a hub centric ring - they don’t want the rings to interfere with the chamfer.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    You might be able to find rings. But I'd just use hub centric spacers, and longer bolts.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Senior Member Two Rings thaifoodninja's Avatar
    Feb 09 2012
    Bostonish
    Some cars are only lug-centric. meaning the seat (this is where spherical vs conical) of the lug nut/bolt centers the wheel. There is a way to center a wheel by progressively tightening the wheels down with your lug nuts/bolts in the proper pattern. It's more work, but doable.
    2013 S4 DSG
    IG: @isaacdoescarstuff
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    I've run 6mm shim-style spacers without any vibration issues. With the spacer on the hub, is there any play if you try to move the spacer radially? You may just have a set of spacers with poor tolerances allowing too much play and causing vibrations.
    2007 Porsche Cayman | 5MT
