Results 1 to 14 of 14
    Jan 08 2020
    Arlington, VA
    Negative Battery Terminal -- Really $300 to replace?
    Morning, a friend accidentally stripped (actually over- loosend) the terminal tightener bolt on the negative battery terminal in my RS7 and now we can't get it to re-tighten. I think the square end stripped out Looked online about replacing the terminal, as well as inspecting the terminal itself and it seems its a custom terminal that allows for a number of wires to feed onto the negative terminal.
    Also it looks like Audi wants like $300 for a replacement!?!
    https://www.audipartsnationwide.com/...VkIFByb2R1Y3Rz
    Can't say I'm surprised, but WTF this seems needlessly expensive.
    Anyone have any experience with different / aftermarket terminals? Same friend seems to think these will work:
    https://www.amazon.com/gp/product/B07N1G7KG7/
    but before I go and dig a deeper hole trying to replace with this I wanted to check with the community as to the necessity of the genuine Audi vs any aftermarket part as well as see if there are any unforeseen hidden gotchas when swapping out this for a new one.
    TIA!
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Welcome to German auto parts. A replacement terminal isn't a critical mechanical moving part, it's a fixed metal object. I see no reason why an aftermarket part wouldn't suffice.
    18 S6
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    You are sourcing Audi original parts for a 6 figure car, of course they will be expensive. Audi did not make the part, someone else made the part and then stamped the 4 rings on it to give it a $250 upcharge.
    If you want to stay all original then get the OEM parts. If you want to fix it and not worry about OEM then there are plenty of options on the market that you can probably find at Advance Auto. You need a new cable end that you can connect a cable to and then secure to the battery. I would bet that Advance will have even cheaper options on the shelf.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Because I am not exactly sure what the "square end" is, I'm going to ask a few general questions. One is can you re die the thread and change the nut size. The other is can you remove a bolt and nut and put another in or if it isn't removable drill a hole and convert it to nut and bolt.
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    A similar thing happened to my SQ5. I was able to back out the bolt entirely and replace it with a metric bolt and nut that I had laying around. At that point I would have used whatever I had laying around to get the car running.
    Jan 08 2020
    Arlington, VA
    Thanks for the tips. I'm not planning on reselling the car anytime, so I'm not particularly concerned with OEM, vs aftermarket - especially if there is no mechanical difference. I'll try to get some pics today and maybe take a drive over to Advance (wish there was an Oreilly close) and see what options might avail.
    May 02 2017
    C7 S6
    Chesapeake, VA
    Quote Originally Posted by bajan01 View Post
    This is what I would do.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    It seems the black box contains the battery control module, which is the expensive bit. Why they decided to mold the battery terminal right into that is beyond me, but it is what it is. If it is the just the clamping bolt you are having an issue with I'd carefully replace it with anything that would work.
    Here you can see the control module with electrical connector.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    Quote Originally Posted by gk1 View Post
    Thiss.
    It’s like a control module in that cable.
    Nov 16 2019
    Dallas
    Home depot. Get a stainless steel bolt and nut and call it a day.
    Junior Member Two Rings kbailey2003's Avatar
    Mar 15 2019
    Ohio
    Stumbled upon this today. May help you out if you're still looking for one: https://www.ebay.com/itm/BATTERY-NEG...8AAOSwJWddUnWk
    Jan 08 2020
    Arlington, VA
    Quote Originally Posted by kbailey2003 View Post
    Thanks - this is a good backup plan! Thanks everyone for your advice!
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    agreed with others who said replace with Metric bolt...problem solved $2.00
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Mar 07 2018
    Pacific NW
    Many of the German cars have an explosive charge that blows the cable close to battery in case of a collision to prevent fires. Not sure if this is the case here however.
