Hello all,
Hope you have been all well. My car is a 2010 A5 1.8 T gasoline (118KW) with currently 64000 miles
Due to the oil consumption of 1 lt oil every 2000 kms I decided to replace my PCV and switch the oil from Mobil 1 ESP 5w30 to Liqui Moly 4200 5w30 and will see how things go.
As you know the PCV valve has been updated recently as it now has a significant clear plastic top instead of black top as before.
The new PCV part number is 06H103495AK... The old version's part number was 06H103495AH. The one on my car is still the old version.
Can I just change the PCV valve to the new updated version ? Or should I also get the software updated as well?
I dont want just to change the PCV with the same one and expect the oil issue to be resolved.
I also dont want to replace the part with an incompatible one.
I also dont want to have more consumption risk after the software update if necessary.
Look forward to seeing your suggestions.
Many thanks in advance.
