Results 1 to 18 of 18
    Senior Member Four Rings
    Mar 05 2020
    NewYork
    My first Audi today. Need help getting rid of ABS, TPMS, Parking break malfunction.
    2011 A5 2.0t, bought it today.
    I bought the car today with these error.
    traction control light? ABS, TPMS and Parking break malfunction. Stabilization program and abs fault.
    I searched and searched google and forums. All I ever see is people saying go to the dealer. Doesn't anyone with audi's work on their own cars? lol.
    Anyone have any ideas? :(
    My screen on the dash also says Service due, but I cant figure out where to find what service.
    I went outside to mess with it and when I started it it sputtered for a few seconds before evening out idle.... That is the first cold start after buying it. I didnt see when he started it.
    Thanks for any help, going to a dealer isnt an option for me.
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    Do you have access to a OBD scanner? Scan the codes to see what they are. Lots of good reference to look.up the codes available online or here in the community.
    A flakey battery can cause a lot of these error lights you have. There are a ton of other things that it could be but I would start by checking the battery.
    As to the service, the car won't tell you that. If you know the prior servicing dealer you can contact them. You will usually need to provide proof that you bought the car before they will provide the service history.
    Sent from my Pixel 4 XL using Tapatalk
    Mar 05 2020
    NewYork
    I scanned it with a scanner before buying it, it has no error or stored codes, all monitors were ready for inspection. I dont have a scanner that scans abs and stuff tho.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Could very easily be a battery voltage issue. Your first mod should be a purchase of the Ross-Tech VCDS cable. You'll need a Windows laptop too. If there are no stored codes, then there should not be any errors so that's a bit of a conundrum. How do you know of those errors if no codes are stored?
    On the service issue, you may need to purchase a Carfax or similar to see where the service was left off. Otherwise, yes, a visit to your closest Audi dealer will clear that up. There are plenty of dealers in NY so why isn't that an option?
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Mar 05 2020
    NewYork
    Its not an option because they are a complete rip off. $125 just to hook it to their tester. Im not rich and it should be able to be figured out wthout them.
    I know of these errors because the lights on the dash and the service screen says them.
    Veteran Member Four Rings dbtong's Avatar
    San Jose, CA
    Are you able to find a local Audi enthusiasts group or maybe post up in the regional forums here on AZ to see if someone with a VAG Com will help you out? Seems there are always some nice people out there willing to lend a hand.
    Congrats on the new car and good luck.
    D a v e
    1996 A4 2.8 QM (SOLD)
    2016 S5
    Jun 30 2013
    San Jose, CA
    +1 on getting a VCDS cable it will help you figure this out. It will provide you with a lot more detail on the manufacturer only codes. I have had the TPMS and ABS error come up after changing tires without resetting the system. Can you reset that in the cars menus or are there actual TPMS sensors in the wheels? Also have had ABS light come on from bad ABS module. Fixable but a pain. Lastly rough idle at cold startup could be normal, secondary air injection warm up cycle or could be bad combi valve PCV and or crankcase ventilation routing or check valve. Again all fixable and if you’re doing it yourself can be relatively cheap on parts.
    Get VCDS though this will easily pay for itself
    Welcome!
    Mar 05 2020
    NewYork
    Quote Originally Posted by Overbias View Post
    Thanks for the suggestions, I know I can fix things myself Ive been working on cars my whole life. Ill have to look into this VCDS. It would tell me like if it had a bad wheel sensor and which one? Read and reset codes? Stuff like that?
    I drive a 2011 Audi A5
    Mar 05 2020
    NewYork
    Jun 30 2013
    San Jose, CA
    Quote Originally Posted by NitroViper View Post
    Could be ideal, check on the Ross-tech site for compatibility and if it works that’s a great deal. Provided it’s got a VIN license left of course!
    Mar 05 2020
    NewYork
    What is that box thing? Do I need that if I buy just the cable?
    Mar 05 2020
    NewYork
    Looks like you can buy it brand new with 3 vins for 199, im guessing ill probably need this thing as long as I own the car so it might be worth the purchase?
    VAG model year coverage: 1995 – Current model year*
    Senior Member Two Rings T_Glass_27's Avatar
    Jan 21 2013
    1988 Porsche 944S
    Mooresville, NC
    Mine had the same thing and a new battery solved it!
    Mar 05 2020
    NewYork
    Quote Originally Posted by T_Glass_27 View Post
    Hmmm, maybe I should try that. The battery seems strong tho?
    Dec 20 2012
    In our local Audi Club, we had a guy with virtually the same issues. Changed the battery and that cleared it up. I was also have weird codes being thrown on my B8.5 S5. Had the battery tested and it failed. Changed it and my weird issues have not happened since.
    Feb 11 2019
    Check. your abs sensor. This usually comes on together if your abs sensor is unplugged or maybe damaged.
    Mar 05 2020
    NewYork
    Quote Originally Posted by whipsfromjapan View Post
    isnt there 4? I guess i need to figure out where they are on the car.
    I will have the battery tested tho as well.
    Jan 21 2013
    1988 Porsche 944S
    Mooresville, NC
    Yes, car ran and drove fine other than those codes. The only indicator was the battery showing like 30 percent on the Car setting screen.
