Results 1 to 17 of 17
    May 08 2012
    Little Rock/St Louis
    9.6 1/4 mile and sub 5 sec 60-130
    Hey guys, been doing lots of research and talking to several people about a hybrid turbo build for my 2018 TT RS. Everyone has different opinions and makes good points, so I thought I would ask here as well to get more opinions 😁
    I’m not as set on having certain wheel horsepower goal, but I would like to run 9.6s or better in the quarter and have a sub 5 second 60-130. I live about 300 feet above sea level, and DAs are normally pretty good. Best DA I’ve seen lately is -1680
    I’m currently APR stage 2 E85. The 3 choices I’ve been considering are the IMS710HS/780HS, Pure850, or GTX3582.
    I’m wanting to do rods/pistons (I’ve been told to do IE rods/Manley pistons). And I know I’ll need a LPFP and injectors (850 cc). And Syvecs is really cool, but really expensive, so I am thinking about doing a Unitronic ecu/tcu tune. I’ve heard Syvecs is the only way to run the IMS710HS/780HS currently. Meaning more 💵💵 ha
    What route would you go or what would you change and why!?
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    So it sounds like you and I are in similar boats. I’m in a 2019 and am in the process of doing research and gearing up for my motor build which will have an end goal of probably around 900whp. Performance wise, I want about the same. Full weight on street tires I want 9.5 seconds or better in the quarter mile, 180mph+ trap in the 1/2 mile, 4.0 second or less 60-130, and as close to a 2.2 second 0-60.
    Initially, my thought was rock the stock turbo for a while after the motor build and then go hybrid. After doing some research and talking to some people, I’m thinking about skipping the hybrid and doing a big turbo build. It sounds like the hybrid turbos aren’t gonna have the longevity/reliability I’m going to be looking for.
    Your piston rod combo sounds good. From the builders I’ve talked to I’ve seen these combinations: Mahle/Carrillo, Mahle/IE, and Manley/Carrillo. All have proven to be reliable.
    I’m still up in the air about which turbo to buy. Xona has some really cool stuff, but then again, Garrett is a billion dollar company. I’ve got some time so I’m gonna sit back and watch what happens with everybody else kits and go from there. I want performance, but not at the sacrifice of reliability.
    Injectors I’ll be going with ID 1050x which is good for my goals. If you’re going past that, then the 1300x2 might be warranted.
    I was told fuel pumps aren’t necessary for my goals and that the brushless ones on the market suck for the most part because they don’t have a check valve. Some of them don’t pull from both sides of the tank and you get to the point of needing to never get below 1/4 tank or even a 1/2 tank with some. My tuner has a 933whp daily driver that’s running on a stock fuel pump.
    That’s about where I’m at right now.
    Jun 24 2008
    Alexandria,Va
    Get some slicks smaller wheels take out all seats and ur at 9.6-9.8 or very close in stock turbo. 1/4 mile wise your gonna get kicked out of any track you run close to that anyway lol.
    May 08 2012
    Quote Originally Posted by mtwallace85 View Post
    Thanks for the info, man!
    Sounds like your goals are much more ambitious than mine, haha. So you’re thinking we only need injectors and won’t need a LPFP? That would be awesome! I’m going to be running E85 only, so I don’t know if that changes things.
    Jun 11 2012
    Corona, CA
    Quote Originally Posted by EyeWin View Post
    That’s what I’ve been told. I’m planning on running e85 as well.
    Nov 21 2012
    tx
    Quote Originally Posted by VAGking View Post
    Yes sir, you are correct! I was kicked out for going 10.1 @ 144mph. I’m only running the IMS710H with stock block (full weight stock 20” wheels). Now I have no where to enjoy the car except the streets & Dragy.
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    hit up brian saxon about the unitronic ecu tune for ims 710h and being of the lucky beta testers (there's actually a handful of them already on it) syvvecs is not worth 7k extra
    2018 TTRS
    May 08 2012
    Quote Originally Posted by sirsycott View Post
    I actually just messaged him. He gave me some good advice!
    Thanks man
    Jun 11 2012
    Corona, CA
    Thanks man
    Do share, please.
    May 08 2012
    Do share, please.
    We are going to need a LPFP to run E85 with our new setups. He went with the Iroz pump. Uni only has files currently for the TTE700, SRM, Pure800, and 710H. And our stock clutches should be good as long as we are limiting the tq...
    Jun 11 2012
    Corona, CA
    Thanks for the information. I’ll be interested to hear your thoughts on it after you get it installed.
    Apr 10 2019
    2018 TTRS Stage 3, 2016 TT Roadster Stage 2+, X5 35d Stage 2, 335d Stage 2
    Harrisburg, NC
    The TTRS will put down these type of numbers with TTE700 running a Unitronic Stage 3 tune. This is also on the stock lpfp.
    Junior Member Two Rings
    Jan 04 2020
    azoth
    Quote Originally Posted by lamboworld View Post
    On 91/93 Octane? Sub 5 second 60-130?
    I was under the impression you need the upgraded LPFP (Optional HPFP) in order to run E85 with Unitronic or APR Stage 3.
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    Quote Originally Posted by sankarea View Post
    TTE700 stock block files will not require a lpfp for any fuel types
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Nov 03 2014
    BMW i3, Golf 1.4T, TT RS 8S
    Mexico
    Quote Originally Posted by Brian@Unitronic View Post
    Brian,
    Could you be so kind and upload a graphic of the results of your tune with a TTE700 turbo.
    What do you need for this upgrade? Turbo, injectors, LPFP. Something else?
    Thanks
    Jan 11 2019
    PA
    Quote Originally Posted by BeTTo RS View Post
    Brian,
    Thanks
    We should be launching this very shortly and when we do the graph wiil be uploaded.
    Simon @TTE also has some examples of customers results if you'd like to discuss with him.
    it will need:
    4" inlet with corresponding adapter
    Full intake
    tte700
    downpipe
    fmic
    injectors
    ethanol sensor if you want to run e85
    no need for lpfp with stock motor.
    Brian
    Nov 03 2014
    Mexico
    it will need:
    Full intake
    tte700
    downpipe
    fmic
    injectors
    Brian
    Hi Brian,
    Thank you very much, I highly appreciate it!
