My 2012 A7
What surprises me is what little work has been done on it.
Previous owner maintained it through the local Audi dealer. We purchased it at 142K. Outside of routine maintenance it hasn't been in the shop a lot. Normal 10K interval maintenance stuff. Front right and back right wheel bearings. Fuel pump recall, normal brake replacement work. Recently I replaced the trans cooler coolant bypass solenoid. I am probably going to replace the tensioners this spring and maybe timing chains but otherwise its in good shape. Carbon cleaning was done around 100K, coolant around 115K. Still has the original trans and diff fluids but I plan to change those this summer.
Motor mounts are original, possibly has the original water pump, original vehicle battery, original PCV. I found in the maintenance log that they replaced the water pump gasket but the pump itself was not listed in the parts replaced list which I found odd.
Driven daily regardless of weather.
