Results 1 to 24 of 24
    Established Member Two Rings saleen8927's Avatar
    Jul 16 2019
    Looking for just a bit of supercharger whine
    It seems there are many differing opinions on whether any of the aftermarket intakes add any power, reduce power, or do basically nothing, so I’m not inclined to spend hundreds of dollars on something that would at best add a negligible gain, and more likely add nothing. However, I would like to hear a bit of supercharger whine at moderate or full throttle, mostly for my own enjoyment. I read that someone used a silicone 034 motorsports tube on an A7 and that it made a huge difference in sound when using the stock air box, so I tried that along with a simple K&N cone filter. I hear no difference in the supercharger whine. I hear ever so slightly more “growl” at moderate throttle, but light driving or WOT both sound no different from stock as far as I can tell. The growl at moderate throttle isn’t enough to be noticeable. 2016 A6 3.0T / Stage 2. Was I misreading that just the tube could enhance the sound? Is there anything else inexpensive/easy I could add to the mix that wouldn’t hurt performance?
    2016 Audi A6 3.0T - APR Stage II / P3U TCU Tune
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    Toss in an RKX Silicone intake hose and a venturi/velocity stack with a cone filter around it. Done and all for around $120
    Jul 16 2019
    Quote Originally Posted by 430hps4 View Post
    I haven’t heard of a Venturi/velocity stack, what is it and where can I get one? Also, since I already have the 034 intake hose, I don’t think I’d need the RKX, unless there’s something different about the RKX model?
    Junior Member Two Rings FoxyFez's Avatar
    Jan 03 2020
    Track Prepped NB MX-5
    Austin, TX
    I've had a Injen intake on two C7s. Looks and sounds great. Fits into stock airbox and is super easy to install. Some places have them for around $220, but sometimes you can find one for cheaper. Can hear the supercharger on most applications of throttle.
    And from MY personal experience, my usual trip out of town mpg improved about 2.5mpg.
    Sent from my yeeyee cellphone
    2017 Audi TTS
    APR Intake & Intercooler, StopTech caliper kit w/ 2 pc. rotors, 034 sways, 034 Res-X delete, Avant-Garde M610 Wheels
    Emerald Mica 1999 MX-5 Track Car
    949 Racing NB Build, 2094lbs, Faster than what its worth
    Aug 27 2018
    C7.5 A6 3.0T Prestige
    WA
    Hopefully other C7.5 owners will chime in but, I have had a C7 A6 and now a C7.5, and my C7.5 in stock form produces no whine? For the first month I seriously thought my supercharger was broken or something, though that clutch may be prone to odd behavior or even failure.
    Jul 16 2019
    Quote Originally Posted by FoxyFez View Post
    That sounds reasonable - I was under the impression that most intakes were $400 up to $1000+. I’m thinking though that in the stock air box, it shouldn’t be much different than the hose and K&N I have now, as far as sound goes. I have to think the air box is the “silencing point” since right now there’s really nothing else blocking the sound.
    Quote Originally Posted by xanmato View Post
    Yes, there is close to no whine stock. I can sometimes hear a hint of it at moderate throttle when it’s just enough to wind it up but not enough to overwhelm it with engine noise, but unless you’re really paying attention you won’t hear it. I assume for most A6 owners that’s a plus, since it does make for a quiet, refined experience.
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    Take the stock air box out... cut out the entire bottom half of it that faces away from the engine. Reinstall...
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Remove the sound dampening pad from the top. (in the middle)
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 03 2020
    Austin, TX
    Quote Originally Posted by saleen8927 View Post
    It doesn't completely seal off the air box like the stock fitting, it leaves about 1.5" around the piping allowing more noise to get out. Unfortunately gaps in the air box or no air box can heat soak your engine in warm climates. I haven't noticed any heating issues with my 2+ years running my Injen in Texas though, but I also dont care for drag times.
    2017 Audi TTS
    Jul 15 2016
    Michigan
    I have had the RKX inlet and RS7 air box installed for a little over a week now. I had the RKX inlet installed on the stock air box for a week while I waited on the RS7 box. Currently this is my only mod to the car.
    Some of my impressions on this combo.
    - Throttle response is noticeably improved. I give more credit to the improved flow of the inlet hose.
    - A hint of s/c whine but nothing near what the injen or roc intake sound levels. Under WOT you can really only hear the S/C at the top end. Part throttle low and mid range RPM the whine is more noticeable.
    - My butt dyno says there may be a slight power increase low and midrange. ( I don't have any data to back this up so it may be a placebo effect.)
    - OEM+ look and still a sealed intake capable of 500+hp
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    Can do it for less is you buy my RKX Silicone intake hose I'm selling :)
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Jun 16 2018
    nh
    Quote Originally Posted by ANMS4 View Post
    How much? I'm in nh
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by charrigan View Post
    Where did you end up sourcing the RS7 air box? Do you have a part number by chance?
    2024 M3 Comp xDrive
    Jul 15 2016
    Michigan
    Quote Originally Posted by christianb5s4 View Post
    Part number: 4G0133836AF
    I purchased mine from Audi of New Orleans but the price has recently gone up to $270.07. I paid $252 shipped a couple weeks ago. Use coupon code "FREESHIP" for free shipping.
    https://parts.audineworleans.com/p/A...AaAjaNEALw_wcB
    There is someone selling one for $259.32 on ebay.
    https://www.ebay.com/itm/Audi-A7-RS7...cAAOSwSe1dKIPa
    Aug 06 2014
    NJ->CO
    Audiusaparts has a pretty good price too. $272
    https://www.audiusaparts.com/oem-par...gaAguBEALw_wcB
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 10 2020
    1985 Monte Carlo SS (race car) 2015 Dodge Charger Scat Pack (sold) 2015 dodge challenger Scat (sold)
    Ridge, New York< United States
    i have a c7.5 (2017 a6 3.0t) didn't want the injen cheesy intake with no heat shield so i went HPS route and i just installed it today, sounds great, fit great, has a heat shield which was one of my main needs, and didnt cost that much from the injen, and looks great in the red to match the coil packs, they also have different colors if you dont prefer red
    here is the link
    https://hpsperformanceproducts.com/p...31765927559265
    Aug 24 2014
    Newport Beach, CA
    Does this also work on the 2016+ CREC motor? Some intakes that work on the 2012-2015 don't have 2016+ listed as compatible.
    2024 M3 Comp xDrive
    Jul 16 2019
    Quote Originally Posted by ferrara42 View Post
    here is the link
    I guess I should update that I sucked it up and got a CTS intake (with heat shield) for I think around $250. It sounds great, looks great, and I haven’t noticed any power loss (or gain) yet. I’m happy with it! It’s definitely loud at some points, but I got used to it quickly and grew to love that whine.
    Jul 15 2016
    Michigan
    My car is a 2016 CREC A6
    Established Member Two Rings Cbest101's Avatar
    Mar 08 2019
    Quote Originally Posted by gk1 View Post
    Does this work? First time hearing of it...
    Sent from my SM-N975U using Audizine mobile app
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Cbest101 View Post
    Really?
    I heard of it long ago maybe even in the B8 S4 days.
    It's not something I have done, but makes perfect sense since that is the pads only function... to quiet the supercharger.
    Probably not as dramatic as an intake, but still something, and free, if that is your cup of tea.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Switch to Rs7 intake it fits right in, has more sound and flows better
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Mar 08 2019
    Sounds like its an easy experiment to try. Thx
    Really?
    May 03 2011
    El Paso, TX
    I am going the Rs7 airbox route. I am stationed in Germany so can order parts from German warehouses and dealerships. Got the whole assembly fro 180 bucks shipped to my door. One advantage to being over here, get the parts closer to the source.
    2012 A6 Prestige| Brilliant Black| APR Stage 1 | Bilstein B12 | Eurocode Sways
