Results 1 to 24 of 24
    Dec 07 2017
    Spruce Grove Ab Canada
    Pinch bolt/stuck punch probllem
    Long story short, in battling with one of the upper pinch bolts, i got the 3/8 punch stuck, and i mean stuck. I snuck a cutoff saw inbetween the slits in the spindle and cut through it there, got the one half of the punch out, but figure i have 1/2"+ still stuck in there, along with half of the pinch bolt ( with a hole drilled through it). Just went and bought some cobalt drill bits, and can barely even make a dent in it with a 1/4" bit. Tried heating it and hitting the other side with an air hammer but not a chance, laid on it for a solid hour. Ideas?
    Senior Member Three Rings KAMP's Avatar
    Sep 18 2018
    2004 Nissan Murano SE AWD
    Have you used something like PB blaster? You’ll need to soak and re-soak the bolts. Try overnight if possible... I would have started with that before doing the additional steps you did, only to prevent any damage to the metal housing.
    I’m in Cali and have a lower mileage 2016 but still soaked them before doing my coilovers. Yes, they came out like butter but the lack of rust is the factor. Otherwise, I’ve had plenty of rust headaches in the past when living in the rust belt.
    Instagram: @kamp_s4
    2016 AUDI S4 🕹 6MT (B8.5)
    Glacier White | Magma Red
    Sport Diff | B&O | Tech | Blk Opt
    Dec 07 2017
    Appreciate it but yea its been soaking in pb blaster for a week now. The bolt itself i was dealing with about 1mm at a time, but its the screwing myself getting the punch stuck in there thats killing me, that has to be the hardest steel known to man. I may literally try borrowing a jackhammer from work and finding a punch long enough i csn use with that
    Mar 31 2008
    eS-4
    CAL*SO
    i found using a jack to help relieve the tension helps a lot.... like a lot!
    Sep 18 2018
    Quote Originally Posted by Fresh.S4 View Post
    Yeah, I was thinking the same thing but the fact that the punch is stuck inside there now, that will have to be taken out first.
    Instagram: @kamp_s4
    Veteran Member Three Rings Allan691's Avatar
    Jul 23 2018
    Vicenza, Italy
    I read this as: “I found using a jack hammer to help relieve the tension..”
    2009 Euro-spec Black Optics S4 Avant APR Stage 2 APR SC pulley + JHM187 with APR Open Air Intake • CR-15 + AK + Eurocode USS + Diff + Trans inserts • P3
    Jul 23 2018
    Vicenza, Italy
    Quote Originally Posted by Tjtubbs View Post
    That sucks. I just spent my whole weekend fighting with control arm bolts.. so I feel your pain. How much is a new knuckle/suspension assembly..? Dare I ask..? At some point time/pain equals money.
    Apr 16 2019
    Would a carbide dremmel burr fit to grind it out? Can also try freezing the punch with A/C refrigirant or heating the metal around.
    Senior Member Three Rings hmc2261's Avatar
    Nov 25 2019
    Charlotte, NC
    I had a similar issue when I replaced my upper control arms, the pinch bolt was "S"'d from the previous owner over tightening and reusing hardware.
    I had to use an impact hammer on the bolt head to work it out. If you have access to that, try that.
    for the punch, once the bolt is out, come from the other side with a smaller punch and knock out the stuck punch.
    EDIT: Didnt see the part on trying the air hammer already. My bad.
    Feb 05 2007
    Portland, OR
    I’ve had to replace the upright and it was like $900 about 4 years ago just for the part.
    I’d recommend big channel locks and compressing the upper control arm mount and the upright together as hard as you can and then try to punch out the remainder. Also a jack under the rotor can’t hurt to relieve more tension while compressing the joint.
    Best of luck!
    Dec 07 2017
    Thanks for all the advice, got a harder hitting air hammer from the shop ill try, everything ive seen about carbide stuff is its so brittle basically if its not set up in a machine shop you'll just keep snapping bits but ill have to look into the dremel thing
    Jul 20 2011
    C8 Z06 Soon.
    Raleigh, NC
    Isn’t there a spreader tool used to remove the pinch bolts?
    Harry P
    IE 80mm Throttle Body kit, IE TB and Crackle Tune, Jokerz Perfromance full S/C Port, APR 57mm SC Pulley, JHM 187mm OD Pulley, APR CPSv1 and Pierburg CWA 100-3, AWE Touring, GESi downstream cats, JHM Short Shifter, Southbound Stage 3 Clutch (600 tq), ECS Stage II Big Brake Kit, USP Metal Slave and SS Clutch Lines, Vorsteiner VFF-103 w/ H&R 5mm spacers.
    Apr 16 2019
    Quote Originally Posted by hgparrish View Post
    Maybe this one?
    https://www.youtube.com/watch?v=p5BLDNAepbs
    Dec 07 2017
    Yea i saw a post where someone looked into that and it was like 1500 bucks, but id almost pay that just to assert my dominance
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    Is the control arm removed from the car? If it is aluminum and the punch is steel, you can let it sit in an acidic Alum (pickling spice) solution for a while and it will dissolve the steel chemically.
    https://www.youtube.com/watch?v=hHN0v2wYjXQ
    2013 Phantom Black S4, 6MT, APR Stage 1, Carbon Intake, Canyon Run CR-15, aFe Pro 5R, Sport Diff, B&O, Nav
    Jul 20 2011
    C8 Z06 Soon.
    Raleigh, NC
    Here is a great DIY video for this job. Very well done and documents the pinch bolt struggle.
    https://youtu.be/1Yc-y3o_kR4
    Harry P
    Jul 20 2011
    C8 Z06 Soon.
    Raleigh, NC
    Heres another decent video.
    https://youtu.be/_NySIblxcB4
    Harry P
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    You're likely going to have to pull the upright and press the piece out. There's limited space to get in there and do a whole lot with the upright in situ. I just went through this with my pinch bolt when I bagged my car. We tried every trick in the book (and then some), and that was what we had to resort to.
    2007 Porsche Cayman | 5MT
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    i used ball joint press c-clamp like this
    2014 Audi S4 DSG
    Sep 18 2018
    ^^^^^ not a bad idea.
    Instagram: @kamp_s4
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Not that this will help you at this point...but every VW and Audi I have ever bought (that has this 4-link front suspension), the first thing I do is to remove, grease/anti-seize, and then reinstall the pinch bolt, to save me the inevitable hassle when the upper control arms eventually need replacing....
    I learned my lesson with a 1999 A4...
    Dec 07 2017
    Soo i ended up pulling the spindle out to get a machine shop to deal with it, figured id get the upper control arms off while it was out. Looked like i had cut enough of the punch off it cleared the groove in the control arm, so started cranking on it with the ball joint seperator. Just when i was thinking hmm that seems pretty tight, bang, the spindle broke in half. Maybe a mm of the punch caught the groove of the ball joint and forced it sideways when i was pressing it up. Luckily i found another for cheap at a wrecker, which also still had the pinch bolt in lol but was lucky enough to draw it out with the threads and putting wrenches behind the nut to turn against. Just have to finish torquing the right side and shes done finally, 1 week later. Dealer quoted me 3300 to do all the control arms so still in well under that thank god
    Apr 16 2019
    Yay! Thanks for the update, glad it worked out. Sort of, lol :)
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Thanks for the update on the resolution. There’s a valuable lesson here for all of us from the school of hard knocks.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
