Results 1 to 11 of 11
    Established Member Two Rings yanni6556's Avatar
    Jul 03 2016
    Sydney Australia
    Camshaft Position Sensor v6 3.0
    Hey all,
    So have been getting a Camshaft Position Sensor BANK 2 (G163) 17800 code showing up on my 3.0.
    Just wondering which side of the motor is BANK 2?
    Cheers
    Aug 27 2013
    Philly
    Quote Originally Posted by yanni6556 View Post
    Hey all,
    Cheers
    Bank 2 is the drivers side on our motor.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Bank 2 is driver's side in the U.S., passenger side in Australia I believe. Facing the front of the car, bank 2 will be on your right, numbered 4, 5, 6, the last one being nearest to the firewall.
    Jan 24 2010
    Paramus,NJ USA
    If you have that fault i doubt its just the sensor,Unless you have oil in the connector then you have a wiring issue.
    Ziddy Autowerks
    Jul 03 2016
    Sydney Australia
    Replaced the lower sensor on the US driver side, AU passenger side.
    Code hasn’t come back so hoping it was that for now, the sensor was original.
    I find it kinda weird how our cars drive so nice and smooth after you calibrate the Throttle body but that slowly fades to jerky driving.
    Thanks for the info
    Aug 27 2013
    Philly
    Quote Originally Posted by Turbo510 View Post
    Good call! Didn't even notice the Australia location of the OP.
    Jan 09 2012
    MA
    some good info here, page 26 has a good illustration of which bank is which
    http://www.volkspage.net/technik/ssp/ssp/SSP_255.pdf
    Aug 27 2013
    Philly
    Quote Originally Posted by deyrag View Post
    Awesome share! Some cool technical details in that.
    Aug 27 2013
    Philly
    Awesome share! Some cool technical details in that document.
    Senior Member Three Rings Cousinphil's Avatar
    Jan 29 2015
    1954 Ford Jubilee Tractor,1986 Ford Diesel Tractor, 2006 GMC One Ton Dump, 1986 Nissan Flatbed Truck
    East Blue Hill Maine
    The volkspage article is excellent but it doesn't show the location of the oil pressure sensor for the 3.0. I've been getting an intermittent oil pressure warning light on my 3.0 and I can get a new switch for $22. I know the chances are against the problem being the switch but I thought I'd eliminate that possibility first.
    Do any of you know where the oil pressure switch is located on the 3.0? Hopefully, it's easier to get at than the 1.8T.
    2004 A4 Avant 1.8T 6 Speed 120,000 miles Summer
    2005 A4 Avant 3.0 Tiptronic 80,000 miles Spring and Fall
    2005 A4 Avant 1.8T Tiptronic 105,000 miles Winter Tires
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Quote Originally Posted by Cousinphil View Post
    Different thread really..but oil pressure sensor is just above the oil filter cooler.
    It faces the front of the vehicle and is tucked in a bit.
    You are lucky if you find you do not need to put the front end in the service position.
    Getting the connector off the damn sensor, without damaging it, is a bitch.
    I thought about cutting the wire and pushing the whole 24mm socket over the connector and all, until I got luck and get it to disconnect.
    2002 Audi a4 B6 Q 3.0 6MT
