Results 1 to 7 of 7
    Mar 05 2013
    CA
    How to walnut blast?
    How is everyone carbon cleaning?
    Seems like the best method is via walnut blast with maybe a metal adapter from 034
    Are you using the Harbor Freight kit?
    kit: $35
    adapter: $50
    walnut fine media: $25 per 25lb bag
    I wonder how long one bag lasts and how many cars it can do
    Also, if you decide to blast other things as a side project, such as cleaning up a metal part
    how does that work?
    I am more worried about getting the work area sandy and polluting the environment
    It's one thing to use a blast cabinet (which I don't have)
    but switching over to glass bead (if it's needed?) and then spraying that stuff all over the area and outside seems kind of sketchy
    like what if a random animal walks by and licks it up off the ground
    IDK if Harbor Freight is the cheapest place to obtain walnut media
    looks like BMW even has a factory adapter, part number 81 29 2 208 037
    Not sure if it works on other vehicles
    Hopefully whatever tool is used has a good seal to the cylinder head and with the hole the spraygun goes into, so that media doesn't get all over the place in the engine bay
    at slightly lower price, people also sell plastic ones, but IDK how many uses they last up to
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    I tried the harbor freight kit and its garbage, dont waste your money. I think people have good luck with the soda blaster.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Apr 11 2012
    2008 VW R32 Audi TT 225 mk1 audi B7 A4 1999 Jeep Xj B6 a4
    Corning NY
    someone has a template to make your own adaptor on the site somewhere. if you soda blast make sure you cover the area with a sheet. And dont buy the 20 dollar gun from harbor frieght doesnt hold enough to do crap. Also a pancake compressor isnt going to work need a larger one. Ive walnut blasted under my jeep and works great for rust. I dont think I would use it on valves. Sode blasting is your best bet. Just warning you makes a huge mess.
    Feb 15 2016
    Cambridge,Ontario
    use dry air ...
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by Der Konig View Post
    this.
    I took a cheap sand blast gun from local store, open my fridge and take the soda box and a shopvac to catch the dust.
    cheap, and working. A bit messy, but it will dilute and wash away with water.
    Senior Member Two Rings megarex's Avatar
    Dec 29 2010
    Puch moped
    SD
    walnut blasting is really effective when the tools are correct. If you have access to a high CFM <20gal air compressor then go for it
    Here is a good BMW DIY with that HF kit for help:
    https://docs.google.com/file/d/0B3Ta...BoTTM5aEE/edit
    he also sells a 3d printed vacuum attachment for vw/audi instead of the 034:
    http://www.bimmerhelp.info/Buy_Blasting_Tools.html
    iI would get a thin sheet of urethane or foam to make a gasket and glue it to the 034 adapter for better suction.
    AKA: mj109
    Aug 19 2005
    07 A4 Avant S-line 6MT
    CNY
    I used the small Harbor Freight gravity feed gun and the coarse walnuts when doing my VR6 motor. The block was on an engine stand which made it easy to roll outside and not worry too much about clean up. I used a metal toilet hook up pipe threaded on the end to extend and an old inner tie rod boot connect similar to the 034 adapter.
    Depending on how good your process is with the shop vac, a box should do at least two cars. For when I will do my 2.0t I bought the RKX head adapter (https://smile.amazon.com/gp/product/B07T81SGT7/) figuring having a stiffer base for the connections would be better then the boot I used.
    '21 SQ5 Ultra Blue
    past: B7 Avant 2.0t S-line Manual [CTS K04, 034 K04 Tune, Golf R intake cam, CTS HFC, Stasis Exhaust, BFI Snub, 034 Street Mounts, Apikol Race Diff Mount, Hotchkis 29mm RSB]
