Results 1 to 20 of 20
    Senior Member Three Rings Celiot29's Avatar
    Jul 17 2012
    boston ma
    high mileage 2013 a4 timing chain tensioner ?
    i have 175k miles on my 2013 a4 and i am also fairly certain it was built right after they made switch to upgrade the tensioner early 2013 as the build date is january 2013. that being said if it is the upgraded one should i still be worried considering i’m going to drive this thing into the ground? it runs beautifully and i have never had an issue engine wise other than pcv oil separator needing replacement and that was even covered out of warranty. ive changed oil every 5k since i hit 100k. i have yet to ask My specialist lee malo from gloucester MA he’s well known around here for his expertise in all things audi and a straight shooter, but i just want to get an idea of people’s experience with the upgraded tensioner and whether it should
    be a life long part.
    does anyone suggest i replace the tensioner or maybe even just have him
    inspect it thru that little hole? not sure if it matters but i don’t drive it hard just a couple high revs here and there to let it breath a bit any thoughts would be appreciated
    2013 Audi A4 Quattro brilliant black | light pckg | convenience pckg | 35% all around | RS4 grille | S4 trunk lid | S Line rear valence
    Jul 16 2018
    Atlanta
    The tensioner style change was at least 12 months prior to your build. There should never be a need to replace that tensioner. You'll still monitor chain elongation by looking at how many teeth out the tensioner is through the inspection hole and by checking the camshaft adaptation value. Chains are better now than originally, but they are still not forever parts.
    May 10 2015
    Pittsburgh PA
    That's an impressive amount of mileage!
    While you have the updated tensioner, the chain is still subject to stretching over time. I would check the cam phase adaptation value via either VCDS or OBDEleven (android version). There is a whole thread where people have posted their results to give you an idea of what's safe and what isn't. At that mileage I would imagine that sooner or later you will want to do a timing refresh though.
    Jul 17 2012
    boston ma
    appreciate the replies and info!
    i will see if my guy can check out the values when he plugs into the comp to see how elongated it is.
    on the mileage yes i drive a lot and it has been super reliable, i can’t help but think it’s got something to do with the oil i use, Lee swears by mobil 15W 50 for these turbo engines i know that’s super thick and basically used for motorcycle and semi truck engine but it coats everything so well inside and i burn way less oil than if i was using the ow40 which is basically as thick as water lol i switched over as soon as i was out of warranty and i don’t regret it.
    thanks again
    May 10 2015
    Pittsburgh PA
    Quote Originally Posted by Celiot29 View Post
    thanks again
    No worries, please post the values whenever you get them! It would be interesting to see where your car is at after all those miles, especially with the 15w50 oil
    Jul 17 2012
    boston ma
    Quote Originally Posted by 19birel View Post
    will do!
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    2013 allroad here. my timing chain was stretched and threw a code at 126k miles. sounds like your chain is doing much better!
    Jul 17 2012
    boston ma
    Quote Originally Posted by wack0 View Post
    wow atleast it threw a code before it broke and cost u a piston or two i’m definitely going to have my guy check it soon. did you go to indy shop or dealer and what did it cost you for chain replacement?
    Dec 12 2005
    Buffalo
    yes i was very lucky! indy shop quoted me $2300, but dealer did it for $1700
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    I know we all say “chain stretch” but we are really talking about chain wear. (literally the metal pins wearing down). Most engine wear occurs at cold startup. So if you are driving tons of miles daily, those are easy miles. And maybe that is some magic oil too. But either way - the fact that you haven't had trouble with your chain yet shows your engine is wearing nicely considering all those miles.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Established Member Two Rings Calderone's Avatar
    May 31 2016
    I have a 13’ A4 Prestige and just had mine replaced at 110,000 miles. The Audi tech said the tensioner was on notch 8 and was stretched pretty good. They claimed I also had the old style chain/tensioner even though it is a 2013 A4
    These prices are with labor included at an Audi dealership. $200/hr USD and 10 hours of labor for the complete timing chain/tensioner/guides
    Jul 16 2018
    Atlanta
    Well, to replace the timing chain, the upper and lower covers have to come off. And you always replace the lower cover when removing it unless you like high risk of oil leaks. And a new lower cover always has the front main seal as a part of it. So line items 1 and 2 are already going to happen as part of performing line item 3, so they are just parts costs.
    upper timing cover, $160 - https://www.genuineaudiparts.com/oem...ver-06h103269h
    and then also the N205 inner o-ring, but that's like $5.
    lower timing cover, $205 - https://www.genuineaudiparts.com/oem...er-06k109210af
    and then also the crank bolt
    10 hours, dealership did mine for 9 hours, close enough. $200/hr? Damn, was $150-$160 for mine, but that was also ~4 years ago?
    oil control valve? Are they replacing the control valve in the intake cam shaft for some reason? I see they are quoting the crank seal and crank bolt and upper timing gaskets twice. Maybe they mean for these to be option A, B, and C, not for all three to be done together? Still, wtf is $375 supposed to be buying if it's only the gaskets? The gasket, seal, and o-ring are only ~$30? Another $40 if you replace the 5 bolts with their integrated o-rings (which are hard as rocks on mine).
    Seems not entirely solid to me. I bought all the parts from ECS for maybe $600, and that included the lower cover and two chains/two tensioners/all guides. Then supplied that to the dealership, which did the work for $16xx. I guess if you like them and just want to run the business through them, it's not entirely bad, if you find a 10% or 20% service discount coupon for them. :-)
    May 31 2016
    Quote Originally Posted by Smac770 View Post
    Yes line 1 and line 2 got cancelled out because they’re included in line 3. $200/hr is Chicago Audi dealership. I mainly went in to fix a leaking front crank seal and they said the top gasket was leaking as well. And since I was at 110k miles I decided to just replace everything. I can throw up a parts list
    Senior Member Two Rings acidvoodoo's Avatar
    Mar 11 2016
    Providence
    I have a 2013 also. Just hit 90K and had them check the stretch at my last oil change two weeks ago, its at -2°
    2013 A4 Premium Plus Sport Package IE Stage 2
    May 31 2016
    Jul 17 2012
    boston ma
    i finally got it down to my guy
    deviation was -.015 and the other important one was -4.015 and this is at 177k miles!!
    i’m pleased to see that number for sure. i do mostly highway miles so i wasn’t surprised to see it wasn’t in dire need but i’m surprised i’m not running to get quotes as we speak lol. at -4.015 i would say i have another year to get it into a shop, what do you guys think?
    thanks for all the replies
    Jul 17 2012
    boston ma
    is this the first ever dealer beats indy shop story
    Jul 17 2012
    boston ma
    Quote Originally Posted by Calderone View Post
    some 2013s have old style tensioner build date has to be after december 2012 so i’ve heard, but some say last half of 2012 for engine build date had updated tensioner so who knows
    with january 2013 build date i’m fairly certain mine is updated and my adaptation value was -4.015 at 177k miles so i assume i got updated tensioner with those values, not sure about chain though, i think i have a year or so before i start really considering replacement.
    Jul 16 2018
    Atlanta
    The adaptation value indicates nothing about which tensioner you have. The 06H tensioner is the old style. The 06K tensioner is the new style. Reflecting its 06K parts bin designation, it was for the gen 3 motor that came with the refresh in 2012 (for the rest of the world, "MY2013" for us and no new engine for us either, got more of the gen 2 though with updated parts such as the tensioner and PCV). When did they start using the 06K tensioner on the 06H engine? Good luck getting a solid on that, but one reference implies May 2012, which would have been for the start of 2012 production (2012 for ROW, "MY2013" for us).
    May 31 2016
    Ya my build date was October 2012
