Hi!
Trying to help a friend with his 2010/11 Q5 3.0 Quattro S-Tronic.
It has the AFS/LWR function, and throws the fault code:
02071 - Local Databus
004 No signal/Communication - MIL ON
Fault status 11100100
Its in the module 8H0 907 357 C we see the fault code.
We have replaced the electonic unit on the lights, 8K0 941 597, no luck.
Checked the main connector to each light, looks fine.
Pulling fuse 6 (LWR) makes no difference
Pulling fuse 7 (LWR) cuts power to the above mentioned module.
Could it just be that the "8H0 907 357 C" is somehow defective?
Someone mentioned that if the H7 bulb was blown it could give a similar error, but these are bi-xenon, aren't they?
Any ideas what to do next?
