Results 1 to 34 of 34
    Jan 20 2020
    MY
    DSG Fart Totally Gone. What Could Have Happened?
    Hi guys,
    I recently went for a Stage 1 ECU and TCU tune. The car was more responsive and alive but it bogs down on every gear change on WOT.
    So I told the tuner to detune my TCU back to stock and the problem was still there. Then I told them to revert my ECU to stock too and the problem went away. Which concludes there is something wrong with the ECU tune.
    After detuning both my ECU and TCU to stock, the dsg fart has dissappeared totally on both D and S mode. The fart was there before on stock and when running on Stage 1 tune.
    What could have been the problem? Any ideas?
    Thanks
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    I usually only get the DSG fart between 4k-5k. Try to see if you're able to get it then. Of note I believe that most tuners usually give you a generic box tune when reverting you back to stock and not you original ecu tune.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    I am unsure which tuner you went with but my TCU tune was bogging before using the tuner's adaptation procedure when flashing to the Stage 1 ECU tune and TCU tune. Adaptation may have helped your original issue. Just a thought.
    FYI, I still have my DSG fart when I flash back to stock.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Senior Member Three Rings hmc2261's Avatar
    Nov 25 2019
    Charlotte, NC
    When did you take the tunes off? I have heard that just because the tune is gone, it can take a little bit of time to readjust everything by itself, dont know for a fact if thats true or not, but my tuner has told me to give it 24 hrs and things will usually work themselves out.
    I would expect a decrease in said Fart with the TCS tune since the shift timing was decreased, I have noticed less of a fart myself with the tcu tune, kinda makes me sad a little bit.
    Jun 22 2016
    Prescott, Arizona
    My DSG fart disappeared after I went 034 Stage 2 (just ECU tune, not TCU tune). Contacted the guys over at 034 about it. They said they purposefully remove the farts for faster shifting.
    Edit: after re-reading your original post, I see you removed the tunes. I’m wondering if a DSG adaptation with vagcom might bring the fart back?
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Did the tuner reflash your car with what they had captured before you did the stage 1 tune or did they just put a base map back on?
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Was it an "apr stock tune" or an actual stock tune. Lol
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Three Rings street2gen's Avatar
    Oct 13 2013
    Whitewater, WI
    Quote Originally Posted by hmc2261 View Post
    But my doctor has told me to give it 24 hrs and things will usually work themselves out.
    I would expect a decrease in said Fart with the timing decreased, I have noticed less of a fart myself, kinda makes me sad a little bit.
    im sorry.... what...... lol JK
    '11 S4 | 034 E40 | 034 TCU | 3.315PR-Ported | iABED 75 | MercRacing HX | AutoTech HPFP | ECS Intake | JHM Test Pipes | AWE Resonated |
    Established Member Two Rings 4DOORFUN's Avatar
    Jul 22 2016
    Glen Ellyn, IL
    I'd be more concerned with the bogging on every gear change. I don't see why an ECU tune would make it shift any differently than stock unless the DSG can't handle the added the power. You are not the first person to report this after receiving a power bump.
    Nov 25 2019
    Charlotte, NC
    Quote Originally Posted by street2gen View Post
    Idk whys is saying something completely different that what i wrote, i didnt edit the comment or anything
    weird
    Jan 20 2020
    MY
    Quote Originally Posted by blackfunk View Post
    Nope, cant get it. Previously it would fart on all rpm range. Now its totally gone.
    I am unsure whether it was my previous stock tune or it was a generic one. They did read out the stock file before flashing the Stage 1. So I presume, they flashed back the stock file from my car.
    Jan 20 2020
    MY
    Quote Originally Posted by doughboy17 View Post
    The tuner did go through the DSG Adaptation after having the bogging down issue. However, that still does not solve the issue.
    Do I have to go through the DSG Adaptation process again after returning to stock? Because they didnt performed it after reverting it to stock.
    Jan 20 2020
    MY
    When the bogging issue was there, the tuner told me to give the car few days to readapt to the new tune. But it still did not work out.
    And now, after going to stock the DSG fart is gone. Been driving the car for few days now and its still the same.
    Jan 20 2020
    MY
    Quote Originally Posted by Tree.Audi View Post
    The "DSG adaptation with vagcom" is the only thing that I have not tried after going back to stock. Any guide on how to perform the following correctly?
    As I mentioned in my previous reply, the DSG adaptation was performed by the tuner when the bogging issue was present. And once back to stock, nothing was done.
    Jan 20 2020
    MY
    Quote Originally Posted by Solarsuplex View Post
    I asked them previously and they mentioned they flashed the stock file that was captured from the car previously. I have no idea how to confirm this.
    Jan 20 2020
    MY
    Quote Originally Posted by 4DOORFUN View Post
    Yep, I have been searching through the forum before posting this. And I can see that I am not the only one that is facing the bogging down issue.
    Oct 30 2012
    Oxford, MS
    Clogged cats?
    Jun 22 2016
    Prescott, Arizona
    Quote Originally Posted by codegenesis View Post
    I believe this is the guide I followed: https://youtu.be/bSdPcbsL5w8
    Oct 13 2013
    Whitewater, WI
    Quote Originally Posted by chilort View Post
    Clogged cats?
    Theres a lot of other things that would accompany clogged cats.
    Jan 20 2020
    MY
    Just an update. My DSG fart is still not back regardless of what I do except for one thing :
    The only way to get a DSG fart on my car is by changing to M1 and slowly (10% throttle) drive it to 4k rpm and shift to 2nd gear manually, and I'll hear the fart.
    In the normal D or S mode regardless of what u do, the fart will never appear.
    I don't know what's the issue, definitely not a clogged cats because I'm able to get the fart on Manual 1st to 2nd gear. Anyone have idea or recommendations on what to check or perform?
    Thanks
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    It's the tune. Your spark is on when DSG changes gear, which might not be causing the timing retardation during DSG shift which would cause bogging of the engine, not the transmission when shifting. https://www.youtube.com/watch?v=CuoB365XXjg
    This is just my speculation. it might be that your engine tune and the DSG tune isn't in sync.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Jan 20 2020
    MY
    Quote Originally Posted by Midnight_Rider View Post
    Thanks for your input. I am currently running on stock file for both ECU and TCU and the DSG fart is gone.
    I went with tunes from different companies and all had the bogging down issue on each gear change. However, on stock it runs fine without bogging down.
    I just gave up on the tunes and now looking solution to get the DSG fart back :(
    Jun 15 2019
    Earth
    All this for a fart. My car can provide some farts...
    Jan 20 2020
    MY
    Quote Originally Posted by Waffles_s4 View Post
    Please do channel some to my car. Lol
    It's user preference I guess. I love the DSG fart.
    Jun 15 2019
    Earth
    Same, I do like it, i was trying to be funny.
    I also hope it's not gone when I tune the ecu/tcu.
    Jan 25 2015
    VA
    DSG fart is there for a reason. It helps you shift without lifting your feet up from accelerator. So if that's gone, what does that mean?
    Jun 15 2019
    Earth
    You tell us, did u notice more RPM when u shift hard in the upper limits?
    Jan 25 2015
    VA
    If you're asking me if my RPM goes up after shifting on Stage 2 tune, yes, because I know my tune is not that great.
    Junior Member One Ring
    Mar 17 2019
    Germany
    Same, same but different here… Did a TCU and ECU Tune by a local tuner and the DSG-Fart is gone… It is quite sad, as I liked the sound. As already stated I can only get it to fart in M1 and slowly revving up to 4-5K RPM and the shift. Sometimes it works also from M2 to M3 but a lot quieter.
    Feb 16 2019
    miami, fl
    i think he's asking does rpm continue to rise during the shift. the farts come from pulling timing/spark vs fuel cut(more dangerous) the car has to remove torque, though only briefly, to shift and not excessively wear on the trans/clutches 24/7, vag does this through cutting/pulling timing which causes the fart, without closing the throttle. if the fart isn't there then either the trans is in launch mode (at least on my giac tcu tune) and going full bore on the shifts for fastest accel or the car isn't properly cutting the timing/spark. if spark is still going and the throttle is still open you might expect to see a slight spike in rpm's while shifting shifts happen pretty fast so this will be hard to see without logging i'd think.
    Active Member One Ring Phantom_AudiS4's Avatar
    Jul 30 2021
    Krakow, Poland
    I have a similar issue...
    The mechatronics and harness was replaced and the gearbox issues were resolved - since then I don't get the DSG fart noise, I can only seem to make the noise when: in manual, 1st gear, throttle 15% and shift to 2nd at 4000rpm.
    The car is stock (ECU & TCU) and shifts gear perfectly but without the 'fart' noise.
    Have there been any new findings on this ??
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I thought I had read a rumor that Audi had introduced new software that would eliminate the fart in the interest of improving emissions. Wish I could remember where I saw that, but I do believe my stock 2011 used to fart (pleasantly so) during its earlier years, but then at some point, it just sort of faded away. It could be that a software update was introduced to the car when it was in at the dealer for scheduled maintenance that eliminated or reduced the sound.
    Meanwhile, I did see this tech article that was somewhat enlightening.
    Finally, one out of many videos of Audis and VWs :
    (Doesn't help listening to the seatbelt warning chime on ths one.)
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Jul 30 2021
    Krakow, Poland
    Quote Originally Posted by LYKUNO View Post
    Thanks for this, I think you might be correct about the emissions changes. That article sums it up nicely
