Results 1 to 8 of 8
    Established Member Two Rings Jamesey's Avatar
    Oct 18 2018
    Connecticut
    vinyl wrap vs plasti dip
    so im looking to black out my rear audi ring badge and have heard good and bad things about plasti dip. i would prefer to just put a piece of black vinyl over it and use a heat gun to mold it and cut off the extra pieces. does anyone have experience using vinyl wrap to do this? my only concern is how small the holes in between overlapping rings are. will the wrap form completely onto those inner edges? thanks in advance!
    2018 S3 Daytona Gray Pearl - Black Optic Package, OEM Resonator Delete Kit
    Gone - 2009 A4 - Stage 1, AWE Track Exhaust Quad Black Diamond Tips, Adjustable Coilovers
    Established Member Two Rings colorado.a4's Avatar
    Dec 04 2018
    honestly for the price of vinyl or dip, you could easily get blacked out rings off ebay
    IG @Colorado.a4
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    i doubt vinyl wrap would even work, it would just peel up on the edges and look like trash. plasti-dip is much easier and takes 30 mins max.
    Senior Member Three Rings Iwantyourcar's Avatar
    Jul 14 2018
    2010 Audi S4, 2019 Jeep Grand Cherokee, 1994 Oldsmobile Bravada
    Indiana
    Quote Originally Posted by colorado.a4 View Post
    I agree. This or dip. I wouldn’t mess with vinyl unless you feel confident with it.
    '10 S4 / Koni / JHM / 034 Motorsports / ST Suspension / ECS / CTS Turbo / Maxton Design / Polo / EPL / Rotiform / Podi / Brembo / Stoptech
    Senior Member Two Rings BrianVan's Avatar
    Apr 03 2015
    Naperville, IL
    I did my rear badges 2yrs ago and they still look good. To cut vinyl against the paint in such small amd detailed areas wont look perfect. Plasti-dip it.
    Sent from my LG-Q710AL using Audizine mobile app
    2013 B8.5 A4 Quattro Auto| Ice Silver | RS4 Grill and Fogs | Painted Calipers Gunmetal | R1 Concept Rotors Drilled\Slotted | Ceramic Pads | Audi Puddle Lights | LED Interior Lights | RS4 Pedals | ECS Drivetrain Mounts |Luft-Technik Intake | Red Coil Paks | Plasti-Dip Rear Emblems | Carista | Spacers 12.5Front 25Rear | ST Coilovers | Ceramic Paint Protection | Lamin-X Tail Light Tint GunSmoke |
    Aug 17 2015
    California
    Does the plasti-dip just peel off around the edges of the rings? I suppose there is a chance it will tear across the rings, then you have to re-do it or touch-up that spot?
    Apr 03 2015
    Naperville, IL
    Quote Originally Posted by A4x View Post
    There are tons of You Tube vids on it. TONS. Just tape off a square around each badge, spray spray spray, then peel it off. The edges will cut perfectly.
    For $5 can of plasti-dip and 30 mins...can't go wrong. If you don't like it....peel it off....you mess up...peel it off...start over....
    I plan on "Dip-your-car" this summer myself with the kit. You Tube is your friend....
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    For something as small and intricate as rings, dip it for sure. This coming form someone who vinyl wrapped his entire car.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
