Results 1 to 40 of 42
    Junior Member Two Rings Chen5441's Avatar
    Jan 25 2020
    2020 Honda Pilot AWD
    California - Bay Area
    ACC and Audi Braking Guard unavailable
    Hey guys. I have a 2013 c7 a7 that is throwing the error "ACC and Audi Braking Guard unavailable" consistently and will not go away. I tried reading codes with a generic obd2 scan tool and I get error along the lines of image processing fail and no video signal from camera. What I did do before I noticed this was change the courtesy lighting on all four doors with aftermarket projection audi logos. I tugged the one on the front right door pretty hard to get slack in order to plug the new projector in. It did not illuminate like the others, I feel that i may have shorted that wiring harness. Do you think this is a plausible/likely cause of my error? I have ordered an obd eleven to get more in depth fault codes which will be arriving soon.
    May 03 2011
    El Paso, TX
    Had this same problem. It’s either your top camera, image processor or wire connecting the two. Mine turned out to be a bad top camera. Found a used one online for 60 bucks and had it calibrated at an auto glass place. The wire in your door is not connected but my camera died suddenly as well with no intermittent problems. The wire for the system runs from the top camera through the headliner and down the passenger side pillar to the image processor under the passenger seat. You can pay Audi to diagnose and fix but they will probably say to replace everything like they said for me. What I would do is acquire a new wire and pull the passenger seat and run the wire and see if that is your problem. If that doesn’t work it’s dealers choice what you want to do next but you can find used cameras and image processors on eBay. Either way you’ll need to code them and either take it to Audi or work with an auto glass place to calibrate your system.
    Jan 25 2020
    Post
    Thanks for your response. You are most likely correct. Nothing is pointing to the passenger door. I actually ended up finding out that the courtesy light came back on even after slamming the door a couple of time. I wonder if Audi is using solid state fuses for that component? Anywho, I went ahead and purchased one of those obdeleven next gen scan tools and so far I am liking it. Below is the scan log that I took a few hours ago. I also began visually inspecting components in the camera vicinity. I noticed that what looks like to be a heating pad of some sort is coming loose on the driver side and if that corresponds to the section of the log " C110115 - Windshield heater for directional stabilization assistance Open circuit/short circuit to B+" If this is true, it may be blocking the signal from the camera to the image processor as a safety precaution. Ill post a link to a shared dropbox folder so you can see what I mean. Visually, as far as I can tell, everything else looks good. what I want to do next is test the continuity for each pin on one end of video line to the corresponding pin on the other side of the wire using my multimeter. Please let me know if you see anything else in the log that looks off to you. I'm new to repairing car electronics, however, I do microsoldering on a regular basis and am pretty good mechanically.
    Link to dropbox: https://www.dropbox.com/sh/8wdj4mx9l...YZBZW0sqa?dl=0
    Code:
    OBDeleven data log
    Date: 2020-02-21 22:09
        VIN:
        Car: Audi A7
        Year: 2013
        Body type: Sportback
        Engine: CTUA 228 kW (310 HP) 3.0 l
        Mileage: 158345 KM
    01 Engine Control Module 1
        System description: 3.0l V6 TFSI�
        Software number: 4G0907551D
        Software version: 0006
        Hardware number: 4G0907551A
        Hardware version: H07
        ODX name: EV_ECM30TFS0214G0907551D
        ODX version: 001007
        Long coding: 1A2A0034056601060000
        Trouble codes:
            No trouble codes found
    02 Transmission Control Module
        System description: 0BK 30TFSIUSA
        Software number: 4G1927158A
        Software version: 1006
        Hardware number: 0BK927156AM
        Hardware version: H16
        ODX name: EV_TCMAL551211
        ODX version: 002022
        Long coding: 000002
        Trouble codes:
    03 Brakes 1
        System description: ESP PREMIUM
        Software number: 4G0907379J
        Software version: 0361
        Hardware number: 4G0907379J
        Hardware version: H09
        Serial number: --------------
        ODX name: EV_ESPPremiAU57X
        ODX version: 004028
        Long coding: 44A78F0322E5F1C04B00
        Trouble codes:
    04 Steering Angle Sender
        Trouble codes:
    05 Kessy
        System description: BCM2 2.0
        Software number: 4H0907064CR
        Software version: 0421
        Hardware number: 4H0907064CR
        Hardware version: H32
        Long coding: 0DAA2046000000000000
        Subsystems:
            System description: J764 ELV MLB
            Software number: 4H0905852C
            Software version: 0046
            Hardware version: H40
            Serial number: 2312000113947004
        Trouble codes:
    08 Air Conditioning
        System description: KLIMA 4 ZONEN
        Software number: 4G0820043AF
        Software version: 0810
        Hardware number: 4G0820043AF
        Hardware version: H13
        Serial number: 12061200040272
        ODX name: EV_AirCondiComfoUDS
        ODX version: 002044
        Long coding: 668320BA5D
        Trouble codes:
            B11D501 - Supply voltage terminal 30 for coolant circulation pump Electrical error
                Intermittent
                    Date: 2020-02-21 19:48:03
                    Mileage: 158342 km
                    Priority: 3
                    Malfunction frequency counter: 1
                    Unlearning counter: 6
                    Dynamic environmental data: 02860C1426098F26131AC8
    09 Central Electrics
        System description: BCM1 2.0
        Software number: 4H0907063CG
        Software version: 0130
        Hardware number: 4H0907063
        Hardware version: H12
        Serial number: 00000001353108
        Long coding: 0D072091073E9FE281000084A0003820CF9CD308A6090225800308457B00
        Subsystems:
            System description: WWS57X 120521
            Software number: 4G1955119
            Software version: 0080
            Hardware version: H35
            Serial number:         120531044217
            Long coding: 0045F7
            System description: G397_RLFS
            Software number: 8U0955559B
            Software version: 0002
            Hardware version: H06
            Serial number: 20335685
            Long coding: 02006E
            System description: E1 - LDS
            Software number: 4G0941531H
            Software version: 0044
            Serial number: 08 06 2012  00000570
            System description: USHL4.2
            Software number: 4G0907410A
            Software version: 0030
            Hardware version: H30
            Serial number: 0000002274555R20QX02
            System description: SLR-B8
            Software number: 8K0959772E
            Software version: 0007
            Serial number:           0031522884
            Long coding: 853000
            System description: A31 LED Mod1L
            Software number: 4G0907472
            Software version: 0001
            Hardware version: H02
            Serial number: 00000000001205110670
            System description: A27 LED Mod1R
            Serial number: 00000000001203302149
            System description: EVLS-SG
            Software number: 4H0907705K
            Software version: 0300
            Hardware version: H08
            Serial number: WA103199000001433268
            Long coding: 020300
            System description: AQ_Hum_Sensor
            Software number: 4H0907658
            Software version: 0003
            Hardware version: H03
            Serial number: 4D18C236000000000001
            System description: A32 LED Mod2L
            Software number: 4G0907472A
            Serial number: 00000000001205102714
            System description: A28 LED Mod2R
            Serial number: 00000000001205103331
        Trouble codes:
    10 Parking Assistance 2
        System description: PARKHILFE ACC
        Software number: 4H0919475AG
        Software version: 0072
        Hardware number: 4H0919475AG
        Hardware version: H01
        Serial number: 61061216300156
        ODX name: EV_EPHVA18AU57X0000
        ODX version: 003008
        Long coding: A8EB04
        Trouble codes:
    13 Adaptive Cruise Control
        System description: ACC3
        Software number: 4G0907561A
        Software version: 0400
        Hardware number: 4G0907561
        Hardware version: H17
        Serial number: 00000000000000
        ODX name: EV_AdaptCruisContrAU57X
        ODX version: 002010
        Long coding: 7E01010201
        Trouble codes:
            U111300 - Function limitation due to received malfunction value
                static
                    Date: 2020-02-21 19:48:05
                    Mileage: 158342 km
                    Priority: 6
                    Malfunction frequency counter: 4
                    Unlearning counter: 221
                    Dynamic environmental data: 028D002202852F1F100EFFFE100F0000
    15 Airbag
        System description: Airbag10.43
        Software number: 4G0959655A
        Software version: 0032
        Hardware number: 4G0959655A
        Serial number: 003D80025AJH
        ODX name: EV_AirbaAU10BPAAU64X
        ODX version: 001014
        Long coding: 303145313131303031304A55304C34473853
        Subsystems:
            System description: BF-Gewichtss.
            Software number: 5C6959339B
            Hardware version: H10
            Serial number: 6940000Y150001FWYH0T
        Trouble codes:
    16 Steering Column Electronics
        System description: Lenks.Modul
        Software number: 4H0953568H
        Software version: 0005
        Hardware number: 4H0953568H
        Serial number: 90372LF9000OW
        Long coding: 0004FC
        Subsystems:
            System description: E221 - MFL
            Software number: 4H0951528E
            Software version: 0009
            Serial number: 25 04 2012  D0115106
        Trouble codes:
    17 Dash Board
        System description: TBenUsaAccNv
        Software number: 4G8920983M
        Software version: 0515
        Hardware number: 4G8920983M
        Hardware version: H79
        Serial number: 6580706125960455
        ODX name: EV_RBD4K
        ODX version: 004046
        Long coding: 03C701060F53D705020100
        Trouble codes:
    19 Gateway
        System description: J533--Gateway
        Software number: 4G0907468AB
        Software version: 0028
        Hardware number: 4G0907468AA
        Serial number: 00000000563375
        ODX name: EV_GatewPkoUDS
        ODX version: 001013
        Long coding: 00CD073000
        Trouble codes:
            U105000 - Battery monitoring control module No Communication
                static
                    Date: 2020-02-21 19:48:06
                    Mileage: 158342 km
                    Priority: 2
                    Unlearning counter: 220
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 12.0 V
                    Control module temperature: 41 °C
                    System status: Terminal 15 on
                    Terminal 15 status: On
                    Terminal 15 status via CAN: On
                    IN ZAS_Kl_X: On
                    Engine running: Off
                    IN ESP_Stillstandsflag: standstill detected
                    Datenfeld: 0
    28 Climate Control Unit Rear
        System description: KLIMA FOND
        Software number: 4G0919158K
        Hardware number: 4G0919158K
        Serial number: 10061200040281
        ODX name: EV_ClimaContrUnitRearUDS
        ODX version: 002022
        Long coding: 20
        Trouble codes:
    36 Seat Adjustment Driver Side
        System description: MEM-FS
        Software number: 4G8959760A
        Software version: 0154
        Hardware number: 4G8959760A
        Serial number: 00000031468459
        Long coding: C0581B008F006001000001010101102030303232203232
        Trouble codes:
    3B Sensor Electronics
        System description: SARA 6D
        Software number: 4G0907637K
        Software version: 0053
        Hardware number: 4G0907637F
        Serial number: EJ1BPA820075N$����������
        ODX name: EV_SARA2
        ODX version: 005011
        Trouble codes:
    3C Lane Change Assistant
        System description: J769  SWA MasterH02
        Software number: 4G0907566J
        Software version: 0040
        Hardware number: 4G0907566
        Serial number: 6PZ 010 287-08
        Coding: 0000007
        Subsystems:
            System description: J770  SWA Slave H02
            Software number: 4G0907568J
        Trouble codes:
    42 Door Electronics Driver Side
        System description: TSG FA
        Software number: 4G8959793H
        Software version: 0506
        Hardware number: 4G8959793F
        Hardware version: H04
        Long coding: 011F57025E00628002000413
        Trouble codes:
    44 Steering Assistance
        System description: RCEPS
        Software number: 4G0909144L
        Software version: 0010
        Hardware number: 4G0909144G
        Serial number: 0004629603
        ODX name: EV_RCEPS
        ODX version: 009008
        Long coding: 101001010000
        Trouble codes:
    46 Central Module Comfort System
        Serial number: 0178587198
        Long coding: 0126063A20FAF08582B00A840201020F0000000000000000000000000000
        Subsystems:
            System description: GTO BF
            Software number: 4G0959719
            Serial number: 00000000000000091843
            System description: LIN BACKUP HO
            Software number: 1K0951605C
            Software version: 1501
            Hardware version: H05
            System description: J245 PS40.039
            Software number: 4G8959591
            Software version: 0008
            Serial number:     WOO16773907
            Long coding: 101F00
            System description: Dachelektroni
            Software number: 4G0947135G
            Software version: 0100
            Serial number: 0000000AP00001533153
            Long coding: 010000
            System description: HSP-SG
            Software number: 4G8959252
            Hardware version: H11
            Serial number: WA103647000001501205
        Trouble codes:
            01403 - Rear glass breakage sensors Open circuit
                static
                    Priority:  2
                    Frequency counter:  1
                    Driving cycle: 220
                    Mileage: 158342 km
                    Date: 2020-02-21 19:48:07
    47 Sound System
        System description: BOSE-G3-C7
        Software number: 4G0035223C
        Software version: 0160
        Hardware number: 4G0035223A
        Serial number: 00000000063594
        Long coding: 030000
        Trouble codes:
    52 Door Electronics Passenger Side
        System description: TSG BF
        Software number: 4G8959792J
        Hardware number: 4G8959792G
        Long coding: 011F57025E00628002000402
        Trouble codes:
    53 Parking Brake
        System description: EPB-4
        Software number: 4H0907801F
        Software version: 0013
        Hardware number: 4H0907801A
        Serial number: 00000000381913
        ODX name: EV_ParkiBrake
        ODX version: 001027
        Trouble codes:
                Intermittent
    55 Headlight Regulation
        System description: ....LWR12....
        Software number: 4H0907357A
        Hardware number: 4H0907357A
        Serial number: 120614-0002-0301��
        ODX name: EV_HeadlRegulBasic
        ODX version: 005001
        Long coding: 1223A6601002A500
        Trouble codes:
    56 Radio
        System description: Radio U SIRIU
        Software number: 4G0035082D
        Software version: 0112
        Hardware number: 4G0035082
        Hardware version: H60
        Serial number: 156F$0C7605438
        Long coding: 020007010000000001
        Trouble codes:
    5F Information Control Unit 1
        System description: H-BNT-NA
        Software number: 4G0035746B
        Software version: 0549
        Hardware number: 4G0035746B
        Hardware version: H49
        Serial number: 194FY0C7504334
        Long coding: 090200040003EDEF7D16CB1E00000003100001000000000000
        Subsystems:
            System description: NAR 2012
            Software number: 8R0060884AM
            Software version: 0605
            System description: DU8 C7 SV
            Software number: 4G0919605B
            Software version: 0021
            Hardware version: H42
            Serial number: AUZ8ZDC9401UBC
            System description: E380 BDT C7
            Software number: 4G1919610C
            Software version: 0204
            Serial number: 90349LFG0000R
            System description: CD-Database
            Software number: 8R0060961D
            Software version: 4353
        Trouble codes:
    62 Door Electronics Rear Left
        System description: TSG HL
        Software number: 4G8959795J
        Hardware number: 4G8959795G
        Long coding: 010F17024000628002000002
        Trouble codes:
    6C Camera System Rear View
        System description: TopView
        Software number: 4H0907428A
        Software version: 0120
        Hardware number: 7P6907441D
        Serial number: 82330JF0041863
        ODX name: EV_CamerSysteTopViewAUDI
        ODX version: 005023
        Long coding: 0205000001010100000102000000
        Trouble codes:
    6D Deck Lid Control Unit
        System description: HDSG-Modul
        Software number: 4G8959107P
        Software version: 0039
        Hardware number: 4G8959107G
        Serial number: 133201172
        ODX name: EV_HDSGAu573
        ODX version: 001014
        Long coding: 0A3305C102
        Trouble codes:
    72 Door Electronics Rear Right
        System description: TSG HR
        Trouble codes:
    82 Head Up Display
        System description: HeadUpDisplay
        Software number: 4G8919604G
        Software version: 0106
        Hardware number: 4G8919604G
        Hardware version: 010
        ODX name: EV_HUDContiC7
        ODX version: 001020
        Long coding: DE0000
        Trouble codes:
    84 Night Vision
        System description: NV-ECU-Gen1
        Software number: 4H0907547F
        Software version: 0042
        Hardware number: 4H0907547
        Serial number: 0K84AE40073676
        ODX name: EV_NightVisioGen1
        ODX version: 001002
        Long coding: 1411
        Subsystems:
            System description: NV-CAM-Gen1
            Software number: 4H0980552A
            Serial number: 00000000001212900369
        Trouble codes:
    85 On-Board Camera
        System description: DPC-SG
        Software number: 4G0907217A
        Software version: 0038
        Hardware number: 4H0907217A
        Hardware version: H25
        Serial number: 26213002542100000004511905
        ODX name: EV_OnBoardCamerDPC
        ODX version: 001007
        Long coding: 6A060000
        Trouble codes:
            C110400 - Camera malfunction
                Intermittent
                    Date: 2020-02-05 22:00:49
                    Mileage: 156538 km
                    Priority: 3
                    Unlearning counter: 224
                    Control module temperature: 12.0 °C
                    Voltage terminal 15: 13.4 V
                    Outside air temperature: -45.0 °C
                Intermittent
                    Date: 2020-02-18 13:18:48
                    Mileage: 158236 km
                    Priority: 3
                    Malfunction frequency counter: 2
                    Unlearning counter: 254
                    Control module temperature: 63.0 °C
                    Outside air temperature: -37.0 °C
    8B Adaptive Cruise Control 2
        Software number: 4G0907541A
        Hardware number: 4G0907541
        ODX name: EV_AdaptCruisContr2AU57X
        ODX version: 002008
        Trouble codes:
    8E Image Processing Electronics
        System description: BV-SG
        Software number: 4G0907107D
        Hardware number: 4H0907107
        Serial number: 00500005130612768602380000
        ODX name: EV_BC7
        ODX version: 001001
        Long coding: 03C198180111
        Trouble codes:
            C110702 - Video line for image processing Signal error
                static
                    Date: 2020-02-21 19:48:25
                    Mileage: 158342 km
                    Priority: 3
                    Malfunction frequency counter: 3
                    Voltage terminal 15: 12.1 V
                    Control module temperature: 35.0 °C
                    Outside air temperature: 21.5 °C
    8F Pretensioner Front Left
        System description: RGS-VL
        Software number: 4H0980945B
        Hardware number: 4H0980945B
        ODX name: EV_RGS_L
        ODX version: 002004
        Long coding: 0066E608031F037E070308014240C2010000
        Trouble codes:
    90 Pretensioner Front Right
        System description: RGS-VR
        Software number: 4H0980946B
        Hardware number: 4H0980946B
        ODX name: EV_RGS_R
        ODX version: 002004
        Trouble codes:
    Last edited by Chen5441; 02-22-2020 at 12:36 AM. Reason: Posted on mobile device previously, didn't look too neat.
    May 03 2011
    El Paso, TX
    Looks like you’re on the right track. The C110702 code is what mine was popping. After I diagnosed that the wire was not the problem I went after the top camera because honestly a used one was cheaper and it’s easier to replace. Luckily I didn’t have to replace the image processor. If you do need to replace the camera, alls I have to say is good luck. The plastic on the windshield is brittle as hell from the sun. Mine was like a potato chip. I was able to glue it all together but the only true fix would have been to get a new windshield.
    Jan 25 2020
    Wow, now I am scared to attempt it myself haha. Looks like I'm going to need to remove the plastic anyways if the video cable checks out. I find it hard to believe that the image processor would be shot since the Malfunction frequency counter for the processor is 3 which is equal to the total of the two malfunction frequency counters from the on-board camera which would indicate that the the malfunctions on the image processor are derived from the on-board camera itself. If you look at the pictures it seems as though the heating pad (if that's what it is) goes between the plastic and the windshield. It may be helpful if I applied heat using a heat gun to the outside of the glass to soften the adhesive and use a thin fishing line to cut the adhesive using a side to side motion. I'll update my solution to this issue as I proceed. Now I just have to figure to where the hell I'm going to get that heating pad from or if I can fix it and if that is even the solution.
    Oct 22 2014
    Atlanta, GA
    I had the same problem. I replaced the image processor and camera module, but in the end it was the cable. I replaced the cable and everything started working again .
    Jan 25 2020
    Pushed on the cables connected to the heating pads behind the rear view mirror and ACC is functional for now. I believe there is a short in one of the cables.
    Sep 24 2007
    2002 Audi A4 1.8TQ
    Kansas
    Having a similar issue. For the life of me I can not find the image processing module to even check that end of the cable. Tried searching all over and have not had any luck. Does anybody have more specifics on its location?
    May 03 2011
    El Paso, TX
    Quote Originally Posted by relic714 View Post
    Under the passenger seat. You have to take it out to access it. The wire runs from there up the b pillar
    Sep 24 2007
    2002 Audi A4 1.8TQ
    Kansas
    Thanks! On my 2016 A6 it is actually in the passenger footwell and the wire runs up the A pillar. While the seat doesn't HAVE to be removed, it certainly makes it easier. love this community.
    Sep 24 2007
    2002 Audi A4 1.8TQ
    Kansas
    Quote Originally Posted by SpectreGadget View Post
    What was the part number for the cable?
    Oct 20 2014
    Laredo, TX
    Quote Originally Posted by Chen5441 View Post
    How did you pushed on the cables? Did you have to remove any cover?
    Did any of your cameras stopped working when you got the error?
    I got all my cameras working including top view but still have this C110702.
    Feb 03 2016
    Cleveland
    I have a new cable and need to replace it this weekend, is there any instruction on this? I did not find it in the service manual and hoping the headliner doesn't need to come out since I hear that is a ton of work.
    Senior Member Two Rings jeff351's Avatar
    Dec 16 2020
    2015 Q5 Prestige TDI, 2016 RS7 Performance
    oklahoma
    mine had the same issue after a shop replaced my console, they ended up taking it to audi where they replaced the harness and had to reprogram the image processing module
    Established Member Two Rings tuscani66's Avatar
    Aug 09 2018
    Pittsburgh-PA/Acworth-GA
    Chen/All,
    I'm getting similar problems - I wanted to look at your photos linked from Dropbox but they're unavailable so if you guys can give me a hand on how diagnose these couple errors that I'm sure are related to each other. Note that the ACC/Brake error came on while on hour 3 of my 5 hour drive back from vacation, then about an hour the code went away and I could use my cruise control again. Well now the code is back the next day and comes on only after putting the car in drive after fresh start on car (basically always comes back on):
    Software number: 4G0907561B
    Hardware version: H21
    ODX version: 002014
    Long coding: 7E01010101
    Trouble codes:
    static
    --I believe the U111300 code is related/active because of the C110702 code. I tried doing a search on the C110702 and only 2 hits on threads, this one and one other (but no responses in that thread).
    8E Image Processing
    Software number: 4H0907107H
    Software version: 0090
    Hardware version: H33
    Serial number: 00500062180915769103680000
    ODX name: EV_BC7
    ODX version: 001001
    Long coding: 03C1BA180111
    Trouble codes:
    static
    --Maybe the coax but any pictures would help?
    I also have a couple other hidden/internal codes but they are just annoying to see every time I scan but curious anyways on how I can fix:
    Trouble codes:
    static
    --I tried looking, couldn't locate, anyone know the location?
    Trouble codes:
    B127313 - Connection between antenna amplifier 2 and antenna Open circuit
    static
    --Google search shows this might be the shark fin antenna or something, I found an example for the Q7 (behind/underneath the roof/trunk spoiler) but nothing on the A/S/RS7 cars.
    Thanks in advance guys! Been going on 6 months with the errors (and no cruise/lane control) but moreso the damn yellow errors is bothering me. There has been a couple times it would clear but come right back. Loose connection maybe and not a bad camera to what I originally thought? IDK...
    2016 S7 Prestige in Mythos Black over Arras Interior.
    Other Garage Items : Volvo S60 R / Lexus RC F / Saleen S281-Cobra Conv / Porsche Cayenne Turbo S / Toyota Tundra
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    ACC...yes....code is cascaded from the Image Processor C110702 code.
    You have to fix that first.
    G304 rear window breakage sensor
    Sorry I don't know where it is on the A7, but bet is, under the hatch trim.
    The B127313 connection should be from the amp to the rear window glass.
    I'd look through this thread.
    https://www.vwaudiforum.co.uk/forum/...ensor-location
    Was work recently done on your hatch or rear glass?
    Does your key fob work to unlock the doors? Mine did not when that connection was not connected...unless the key was about a foot from the rear glass.
    GL
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Aug 09 2018
    Seen answers below:
    Quote Originally Posted by gk1 View Post
    -I know, just wondering where to start or if anyone has some insight further than what was on this thread. I'm going to take off the two plastic panels, put the car in drive so the error code activates, then I'm going to check the connections (coax and power) in hopes its a loose connection to somehow cement my idea of a bad connection because of it intermitting while driving (but always activates after starting car immediately after putting it in 'drive gear'.
    -Thanks for the link, did some reading, when I get back in a couple weeks I'll take apart my hatch to see if I can find the culprit behind the hatch panels.
    GL
    -Yes, my fob works normal, never questioned or had any hiccups, whether by remote or even by prox.
    May 22 2016
    N/A
    I had a fault for the image processing unit and was getting the same message you are in DIS. I replaced the camera that is located behind the rearview mirror with a used one and had it calibrated by Audi. Since the camera was used, total cost including calibration was about $700. Replacement camera had to be “coded in” to work with my car. The camera was very difficult to remove, I had Audi actually remove it and install it. All I did was hold the camera up while I plugged it in, coded it in, then verified the only thing left was calibration.
    I posted more about this on this thread https://www.audizine.com/forum/showt...4#post14540484
    Jan 25 2020
    Hey, I haven't had a chance to swap out my top camera yet but my acc hasn't been working for a while.
    As for the rear window glass break sensor it is easy to access with torx bits and trim removal tools If I remember correctly. I also had that issue and the alarm would randomly go off sometimes. Located the sensor and soldered the 2 wires together to complete the circuit permanently as it is triggered when it detects a break in the circuit. Now if someone where to break my rear window my alarm would not go off but who breaks in through the back window anyways lol?
    Jan 25 2020
    FYI if you or someone else had the rear window tinted this is likely the cause. Tint installers tuck it under the trim to hide the lines and that is where the sensor is located.
    Jan 25 2020
    Quote Originally Posted by fixedhat313 View Post
    That's good to know. I'll probably take the same path that you did eventually. It's a nice feature but life goes on haha
    Jan 25 2020
    Quote Originally Posted by Esqueda_ View Post
    You can pop off the plastic trim on the top camera and see the coax cable on the passenger side of the camera. I played with it and got it to work for a short period.
    I thought about removing the camera and seeing if I could disassemble it to locate any loose/shorted components caused by faulty solder joints. If this is the case I could just re-solder but it is going to be time consuming and tedious to take the camera off and put it back on.
    Feb 03 2016
    Cleveland
    Can someone with a C7 S6/7 prestige post their coding for the camera module and image processor? I got an A7 camera and can now get everything to recognize everything as present and working for the most part, except when I turn the car off and back on the error message pops up on the dash again. I read that someone coded the camera because they had similar situation where the donor car features were different than theirs and once the coding was updated everything worked correctly again.
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by ItsLarryG View Post
    If you needed c7.5 i could
    18 S6
    Nov 25 2021
    2006 Porsche Cayman S, 1988 Porsche 928S4
    Southern California
    Quote Originally Posted by eveleth View Post
    I have this problem as well. Can you tell me what you needed to do to re-code the new camera in VCDS?
    Kevin R
    2012 A7 — also 2006 Cayman S and 1988 928S4.
    Active Member One Ring Sledgehammer1's Avatar
    Apr 02 2018
    Colrado
    My A7 is popping these same codes. My battery is also on its way out so I'm wondering if that's related?
    Code:
    OBDeleven vehicle history log
    Date: 2022-05-09 23:30:40
    	VIN: WAUSGAFC2CN013283
    	Car:
    	Year: 2012
    	Engine: CGXB  kW ( hp) l
    	Mileage: 220248 km
    8E Image Processing
    		Software number: 4G0907107B
    		Software version: 0034
    		Hardware version: H29
    		Faults:
    			Signal error
    				static
    					Priority - 3
    				Malfunction frequency counter - 2
    				Unlearning counter - 173
    				km-Mileage - 220248 km
    				Voltage terminal 15 - 14.1 V
    				Control module temperature - 31.0 °C
    				Outside air temperature - 21.0 °C
    				date - 2022-05-09 22:45:14
    		Hardware version: H15
    		Faults:
    				static
    					Priority - 6
    				Malfunction frequency counter - 8
    				date - 2022-05-09 22:38:14
    19 Gateway
    		Software number: 4G0907468E
    		Software version: 0213
    		Faults:
    			No Communication
    				static
    					Priority - 2
    				Malfunction frequency counter - 1
    				Voltage terminal 30 - 13.9 V
    				Voltage terminal 15 - 13.7 V
    				Control module temperature - 37 °C
    				System status - Terminal 15 on
    				Terminal 15 status - On
    				Terminal 15 status via CAN - On
    				IN ZAS Kl X - On
    				Engine running - On
    				IN ESP Stillstandsflag - standstill detected
    				Datenfeld - 0
    				date - 2022-05-09 22:44:07
    2012 Prestige A7
    Ibis White・HUD・LED lights・Heated & Ventilated seats・B&O・Radar Cruise・Night Vision
    APR Stage I ・ Retrofitted B8.5 S4 Exhaust with S7 Rear Bumper ・ RS7 Grill ・ Debaged
    May 17 2022
    San Antonio Texas
    2015 A7 Prestige TDI
    similar problem. Appears to be the cable needs replaced. I have been researching for a week or so. I have all the manuals. Found a few threads on removing headliner. My questions:
    1. Do you have to remove the headliner completely to reroute the cable or can you remove the passenger side (US market) front half and reach it?
    2. Is the image processor module under the seat pan (ie above the carpet) or below the carpeted floor necessitating seat removal?
    Jan 31 2009
    2016 RS7-P
    Not sure if this answers your question but to do surround camera I know the 4x video cameras would be in the box under the carpet.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Sledgehammer1 View Post
    Could be. A variety of "false" codes may be generated as the voltage becomes less stable. Try a new battery, clear codes, and see if any come back, is the usual advice.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    May 17 2022
    San Antonio Texas
    Connected a new cable to the camera and processor. Same error. Not sure whether to try the processor or the camera next. Camera will require calibration.
    Established Member Two Rings Nemesis tl-s's Avatar
    Oct 17 2014
    Philadelphia, PA
    Quote Originally Posted by OilBurner2015 View Post
    Did you ever find a solution for this? I'm having the same issue and just replaced the cable. Not sure where to change the processor or the camera next.
    __________________________________________________ __________________________________________________ ____
    2012 A6 Prestige, Innovation Package, Adaptive Cruise, HUD, Night Vision, Cold Weather Package, Phantom Black/Nougat Brown
    May 17 2022
    San Antonio Texas
    I tried a used processor and used camera. The dealership has to program the unit to the car but I was trying to diagnose and source a cheaper part. They said 90pct of the time it's the camera. They tried my used one, no joy. Put in a new one and it worked. $2400 and it was fixed in a day.
    Established Member Two Rings joeyjazesmith's Avatar
    Mar 11 2021
    boogy down, NY
    just to share my experience with this issue.
    I started having this problem after I hardwired a power source for my uniden r7 radar detector. I used power from the rear view mirror power which is also connected to a camera. To my understanding the power draw caused the error but both my ACC and Brake guard still function fine. I just get the message. I still had the message after i removed the uniden r7 so i just kept the uniden r7 attached and ignored it.
    Ive heard audi can clear it with a re calibration but im not sure if that's true and calibrations can be very expensive
    C7 2015 Audi S6 | APR Stage 1 ECU tune | APR TCU tune | ECS Performance Engine Mounts | | ECS Luft-Technik intake system | ECS Billet Aluminum Underbody subframe brace | 034 Motorsports street density control arms | 034 Motorsport adjustable swaybar links | JHM Oil Strainer relocation Kit | TGK Motorsport Coolant Tank AN lines | Leyo Shift Knob | Uniden R7
    Junior Member One Ring
    Feb 18 2016
    US
    I have the same error and trying to diagnose it on my 2015 A6 C7. Hoping it is the cable (cheapest fix) but not sure. Started happening after my car sat under blazing sun for a few weeks... so maybe temperature related. Can someone shed some light where the control unit is there the cable from the camera goes to? I got to the image processing module box that is under the passenger seat but it only has the four cameras that make the 360 view (front, rear, and both mirrors cameras). The camera that sits behind the rear view mirror (night view?) is connected to another unit and I am not sure where it is. Maybe it is under the driver's seat carpet...but wanted to check before I go and start ripping the other side.
    Apr 16 2012
    Grovetown/GA
    When you say “top camera” are you referring to the one near the rear view mirror?
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Quote Originally Posted by joeyjazesmith View Post
    Did you try clearing the codes for the acc module in VCDS?
    If that doesnt work pull the fuse on the passenger side that is for the instrument cluster and wait 5-10 secs and plug it back in. that should clear the message if the issue is resolved
    Also i would try to pull power from another source if possible.
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Mar 09 2021
    Jenkin's Island, SC
    Oilburner - While expensive, that seems like a deal compared to the $4k I was quoted.
    Where did you get it fixed/replaced?
    Junior Member Two Rings H4mm3R2's Avatar
    Sep 10 2018
    Poland
    I can fix your cam with the C1107 02 and U1112 00 fault code. You need send it to my.
    Apr 16 2012
    Grovetown/GA
    Quote Originally Posted by H4mm3R2 View Post
    How much and what state are you in?
    Sep 10 2018
    Poland
    Quote Originally Posted by passatevos View Post
    $250 but you need send it to Poland. From Poland to US shipping take 7-10days
