Replacing my PCV/Oil Separator this weekend due to it failing (very loud shrieking sound at idle, sounds very scary). When removing the bottom section of the intake manifold and exposing the fuel injectors, i know you are supposed to replace the the top o-rings before re-installing. However, Audi doesn’t have a part number for those individual rings (only the full injector kit, which is more $). My question is, has anyone ever used another generic o-ring that has the same specs, and if so do you remember the part number? Just trying to save a few bucks since I’m not fully removing the injector.
On a side note, is the PCV failing common in the later B8 models (I have a 2016)? I know that it was in the early models prior to a software update involing air pressure or something but I haven’t seen much in regards to the B8.5 platform.
