Results 1 to 9 of 9
    Aug 22 2011
    Doylestown
    Plastic engine parts suck
    I own a 2011 B8 S4 which I picked up at the factory. European delivery is amazing and I hope they bring it back. I have 85,000 miles on the car and love it. I have added a few aftermarket suspension parts and other than that, the car is box stock. My issue is failing plastic engine parts. There is a plastic coolant pipe that dumped all the coolant at 85,000 miles. The problem? A bad design. The O-ring blew out. I checked on how to replace the part. Step 1? Remove supercharger. The pipe has obviously been a problem, Audi has revised it 3 times. Next up, a few weeks later, the DSG filter housing cracked and dumped the transmission fluid. What did these parts have in common? They were both made from German wonder plastic.
    Has anyone else had these type of problems?
    Senior Member Three Rings Iwantyourcar's Avatar
    Jul 14 2018
    2010 Audi S4, 2019 Jeep Grand Cherokee, 1994 Oldsmobile Bravada
    Indiana
    Huge issue with a plastic coolant pipes in Porsche. Unfortunately it seems all too common.
    '10 S4 / Koni / JHM / 034 Motorsports / ST Suspension / ECS / CTS Turbo / Maxton Design / Polo / EPL / Rotiform / Podi / Brembo / Stoptech
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Old brittle plastic parts is a problem for all German cars, not just VW group. There's an opinion that this is because German wonderplastic has some recycled content, but I just don't think that plastic is not going to last forever when contacted by 100+C coolant
    Jun 15 2019
    Earth
    Wait, we are not even gonna talk about the PLASTIC parts that are INSIDE the engine.. The plastic chain guides which break, get loose, and wonder around inside the engine...?
    Plastic screws for the SC bleeding ports
    Plastic intake flaps
    Plastic connectors
    Plastic coolant reservoir
    Plastic sensors everywhere, and the list goes on
    Plastic and heat dont go well together. They crack, break, etc
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Quote Originally Posted by Waffles_s4 View Post
    Plastic connectors
    You're forgetting the worst offender. The fucking plastic PCV
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jun 15 2019
    Earth
    Quote Originally Posted by Morritse View Post
    Oh ya that one too. Great idea, let's put a plastic pcv under the very hot supercharger, and between the two heads of an already warm engine. Fantastic. And let it heat soak till it cracks.
    Established Member Two Rings Sleipnir's Avatar
    Feb 02 2019
    California
    Plastic is the bane of almost all modern manufactured vehicles.
    Plastic parts are cheap, easy to mass produce, and lightweight.
    Not much you can do about it, really.
    But I'm sure there's a special place in Hell reserved for the executives and engineers that came up with the decision to use plastic.
    Sent from my SM-G950U1 using Tapatalk
    Jun 15 2019
    Earth
    True. And any alternative will increase a lot the price of the vehicle.
    Plastic for air box, fine. Plastic for sensors, fine.
    Plastic inside the engine itself, or for the pcv or coolant reservoir, not so fine. It's all about context.
