I just got a ross tech cable and I scanned my car and found a number of faults but I have no idea what to do as I am not able to decode the faults
Would greatly appreciated if someone can help me figure them out. The fault with the rear speaker is self explanatory
Thanks in advance for any help.
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H02 0008
Revision: 15H02---
Coding: 0121002C240F0828
Shop #: WSC 00217 217 96495
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 39791414B8C05882D2-806C
2 Faults Found:
4528 - Coolant Fan Control Circuit 2
P0481 00 [047] - Electrical Malfunction
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 110755 km
Date: 2020.01.03
Time: 10:48:55
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 85 °C
Intake air temperature: 28 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.160 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Intake air temperature: 28.7 °C
Air mass: specified value: 1200.0 mg/stroke
C Thmst r: 0.00 %
Field regeneration status-Bits 0-7: 00000000
Field regeneration status-Bits 0-7: 00010000
Field regeneration status-Bits 0-7: 10000000
Exhaust gas temp.bef.turbocharger: -273.1 °C
4797 - Mass Air Flow Sensor
P116F 00 [032] - Interrupted Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DQ HW: 8K0 907 064 DQ
Component: BCM2 1.1 H02 0324
Revision: 00002001
Coding: 011500
Shop #: WSC 06335 000 00000
VCID: 020BB3F89D96DB5AC3-8056
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000048428019
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000062931007
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 114
Reset counter: 198
Mileage: 104036 km
Time Indication: 0
Date: 2019.07.19
Time: 00:10:33
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G0982581CD
Coding: 00C303
Shop #: WSC 00217 217 56833
VCID: 50AF49B0037AF9CA05-8004
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140645074
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 8
Reset counter: 178
Mileage: 110663 km
Time Indication: 0
Date: 2019.12.30
Time: 21:08:00
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 61
Reset counter: 232
Mileage: 110663 km
Time Indication: 0
Date: 2019.12.31
Time: 01:08:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.60 V
Count: 17
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0121456113
Coding: 013B0622203934940420050000000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE19SKB12 H01 0220
1 Fault Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 9
Reset counter: 231
Mileage: 110602 km
Time Indication: 0
Date: 2019.12.27
Time: 08:05:49
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 S HW: 8T0 035 223 B
Component: DSP Prem H13 0210
Revision: 00013001 Serial number: 34833004820605
Coding: 0203010301
VCID: 3E730708A9EE7FBAE7-806A
2 Faults Found:
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 11
Mileage: 108883 km
Time Indication: 0
Date: 2019.11.05
Time: 09:20:05
Freeze Frame:
Voltage: 12.20 V
Temperature: 22.0°C
Temperature: 24.0°C
Bin. Bits: 00000100
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 111216 km
Time Indication: 0
Date: 2020.02.01
Time: 12:09:34
Freeze Frame:
Voltage: 12.10 V
Temperature: 16.0°C
Temperature: 18.0°C
Bin. Bits: 00000100
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 C HW: 8K0 907 383 C
Component: Anhaenger H06 0040
Revision: 1G002002 Serial number: 00000116707269
Coding: 0109080000000000
Shop #: WSC 00000 000 00000
VCID: 3467252097A2A5EA01-8060
1 Fault Found:
02539 - Terminal 30 from Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 192
Mileage: 110649 km
Time Indication: 0
Date: 2019.12.30
Time: 15:56:25
