Results 1 to 39 of 39
    Established Member Two Rings Ronnitude's Avatar
    Feb 06 2020
    Chicago, IL
    Lowering Springs or Coilovers?
    Newbie dumb questions here! Trying to lower my C7 A6 and I'm trying to learn and understand all the variables here so I can make the best decision!
    From what I've been reading, watching and listening here are the questions that I have (some will be dumb and obvious to most of u I'm sure):
    1- Springs or Coilovers?? And why?
    2- How does tempering with the suspension affect the Audi select system (dynamic, comfort...etc)?? Would that system still work after installing aftermarket parts?
    3- I have 18" wheels now, I plan on going to 20" in the future, will lowering the car affect my ability to do that? Like if I end up over doing it and lowering it too much!
    4- what are some brands and part numbers that people usually go with??
    Thanks and my apologies if those r repeated questions. I've been reading about this for the past week and I feel like I still can't quiet answer these!
    Sent from my SM-G975U using Audizine mobile app
    C8 2019 Audi A6 - Prestige
    Established Member Two Rings Rsniper4's Avatar
    Nov 14 2016
    I can offer some points to think about
    1 - The suspension layout varies depending on your trim and year. Some trims offer air ride suspension, so obviously that would rule out any mechanical adjustment from shocks or springs. If you are not running air suspension, then you will see coil overs in the front , but the rear have the shock absorber and spring separate on their own. You have the option to simply buy four springs - the rear would be super easy to swap out, but for the fronts, you would have to remove the coilover assembly and take it apart to put in the new spring. Also, if you're only planning to drop by no more than 1.5 inches, the stock shocks I think would still work fine. If you are dropping more than 2 inches, I think you will have to get new shocks that are designed for that. You can also buy the full aftermarket coilovers that you just swap without messing with the spring.
    2 - Unless you have the air suspension, then I don't think the various driving modes affect the suspension feel at all.
    3- The larger wheel you get, the skinnier the tire must be to keep the overall wheel circumference the same. You can go over a bit, but then your speedometer will lag behind (ex- will show 80 mph when you're actually going 85). Your 20" wheels might also have different offset than your stock 18"s, and you might also choose to get wheel spacers for a more flush look. If you go that route, it will decrease the amount you can lower your car before you run into clearance issues.
    4 - I cant recommend any brands personally, but as with everything else, you tend to get what you pay for. Do your research and read the reviews.
    Now for the big picture: When you lower your car (properly) the spring stiffness must increase too to keep it from bottoming out. This means your ride will feel more firm, and obviously your ground clearance will be reduced. Now combined with larger wheels and skinny tires, this adds further to the firmness of your ride. This is an unfortunate compromise in the pursuit of style...
    If you intend to use your A6 as a daily driver, you will definitely notice a reduction in comfort. On the other hand, you have lowered center of gravity, which will result in sharper feeling steering and less body lean around corners. Luckily from what I have read on these forums, and generous 1" drop and 20" wheels should be within reason to keep a sensibly comfortable and sleek daily driver.
    Good luck!
    2001 A4 1.8T , 260,000 mi (resting)
    2014 A7 TDI
    Feb 06 2020
    Chicago, IL
    Quote Originally Posted by Rsniper4 View Post
    Good luck!
    Such a great response!! Thank you so much. I'm glad I came back here since I didn't get a notification that someone replied haha!
    I've been reading and watching videos none stop since I posted this, and you are absolutely correct! I love how comfortable the ride is, and my biggest fear is adding coilovers will greatly impact that.
    As for the lowering springs, I keep reading that installing those puts more stress on the stock stutts which will speed up their life. But as you said, i'm not looking to lower THAT much...honestly 1" would make me happy (that's what she said)!
    a 1" drop with 19" or 20" wheels will be ideal.
    At this point, i'm leaning towards not messing with the suspension since I really reaaaally like how comfortable the ride is...but if I can get a minimal decrease in comfort, I might change my mind
    May 10 2015
    Pittsburgh PA
    The problem you might run into, if your car does not have factory sport suspension, is that the ride might get bouncey because the lowering springs are too stiff relative to the shocks (assuming you kept the originals). The best way to do it, is to upgrade the springs and the shocks, that will ensure the best ride with lowering springs. That said, it will still be stiffer than stock.
    If ride comfort is a top priority for you I would probably refrain from lowering it.
    Feb 06 2020
    Chicago, IL
    That makes sense. But when you say "upgrade" the springs and shocks, would aftermarket shocks really be an upgrade to the stock Audi ones? In terms of built quality and such. Or is it an upgrade as in they are new!
    That's the other thing I'm worried about, since Audi is such a high quality car, would these aftermarket parts be a downgrade!?
    Quote Originally Posted by 19birel View Post
    May 10 2015
    Pittsburgh PA
    Quote Originally Posted by Ronnitude View Post
    When I say "upgrade" I mean an upgrade in terms of performance and handling. While this doesn't apply to all aftermarket products, some of them of as good as if not higher quality than stock. That has been my experience with Bilstein shock absorbers and H&R springs in the past.
    That said, if you buy low quality parts, yes, those can be a downgrade.
    Feb 06 2020
    Chicago, IL
    Bro! You have no idea how helpful your answers are! Thank you very much!
    So now the question becomes, Springs & Shocks VS Coilovers. For me to have that question answered in my head, i need to better understand the things a coilover would allow you to adjust. The damping..etc. I definitely don't see myself adjusting anything (after an initial set up)...so in that sense springs and shocks combination makes more sense for me. However, If those extra adjustments a coilover have mean I can adjust the ride to be more comfortable than I'm all in! I can go up to 2k in budget...maybe even 2500! Def want quality parts not cheap ones.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    A $2k budget can get you some nice PSS10's
    Looks like you can adjust for "comfort" or "competition" with just a knob. Since it is a matched spring/damper combo no need to worry about getting the right combination.
    https://www.tirerack.com/suspension/...dClar=Prestige
    or H&R streets, but looks like they only offer height adjustment
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Feb 06 2020
    Chicago, IL
    Quote Originally Posted by gk1 View Post
    Oooo those Bilstein B16s look sweet as hell! Prior I was looking at the KW V1s!!
    Thanks gk1! Much appreciated, friend.
    Feb 10 2019
    New York
    Great info on this thread! Just wanted to add that I avoided coilovers because I live in a high salt area. Roads are constantly sprayed throughout winter and the shop I’ve been working with told me they’ve seen just about every brand seize. Not sure if other readers need to take this into consideration. Opted for H&R springs on stock sport suspension shocks, on 20” the ride is tolerable, definitely not what it was and I feel like the front end is too low and can bottom in really aggressive turns.
    2016 A6 / 3.0T | APR Stage 2+ DP, TB, Intercooler | P3U TCU | W/M injection | Jokerz Port | AWE Intake/Exhaust | JHM Downpipes/Race Cats | H&R Springs | Ferrada FR8 on Michelin PS4s | StopTech Brakes | 034 Mounts | and way too many other things…
    Senior Member Two Rings dorothy_c7's Avatar
    Aug 21 2018
    New Jersey
    Also look into kw street comforts. I'm probably going to head that way or v3s!
    Sent from my SM-N950U using Audizine mobile app
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by BobbyWatts View Post
    I've heard the same, but unless you are frequently adjusting the ride height I can't image it being much of an issue for most people. Once you get the ride height dialed in what should it matter if the threaded part seizes? Perhaps when it comes time to remove them or replace them it could make things more difficult, but I assume shops are prepared to handle those types of eventualities or you use a spring compressor and yank em out like any 'ol strut.
    FWIW the Bilstein's are zinc coated too.
    https://www.bilstein.com/us/en/techn...-c-technology/
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Aug 21 2018
    New Jersey
    Ecs makes coilover protectant sleeves
    Feb 06 2020
    Chicago, IL
    Quote Originally Posted by dorothy_c7 View Post
    I came across those, but if I remember correctly they dont make them for my car (2014 A6 C7)!?
    Feb 06 2020
    Chicago, IL
    I live in Chicago, so that would def be an issue! What's the difference with those tho as oppose to the factory stock suspension? Wouldn't the affect be the same?
    Apr 19 2010
    2020 GMC AT4 HD, 2020 Jeep JLUR, 2008 Chris Craft Launch 22
    Danville, CA
    Chiming in with my perspective (a lot of it) here. Take it for what it's worth...
    I will never put coil-overs on another daily driver. Here's the story.
    I bought a C7.5 S6 in October of last year. This car has the air suspension which pleases me to no end. I will never have to "guess" how my car is going to feel after I spend a ton of money on it again.
    I came from a B8.5 S4. I had 4 suspension combinations on it, some very expensive and was ultimately never completely happy. The following are the summaries of each:
    Completely Stock: I was basically happy with most aspects of the ride. The car did not come stock with electronic ride control so it was what it was... And it worked. Cornered flat, dealt with harsh road conditions reasonably well for a car with 19s and 35-series tires, well-damped, fairly quiet. Basically, what one would expect from a sports sedan in this class. But the B8.5 especially, just didn't have the look I was after and I got the bug and started modifying it.
    Suspension Setup #1: Bilstein B16 with electronic ride control: This setup got some things right but a couple critical ones very wrong. Having the ability to adjust ride-height meant I was able to dial the car in to exactly what I felt I wanted so this was great. I did not want a "slammed" car. I wanted a somewhat subtle lowered stance. And because the Bilsteins had isolation included, the car did not become noticeably louder with regard to road noise compared to stock. This was a win that I didn't realize the importance of until later. HOWEVER, the flaws ended up being more than I could tolerate. The suspension basically has three modes. Comfort, Auto and Sport. Comfort ended up being much too "soggy" and therefor unusable in my mind. And, even though ride was soft, I still noticed an increase in harshness over broken surfaces. Not great. "Sport" mode ended up being where I left the car most of the time because I couldn't deal with the soggy ride. But it was too harsh for my taste most of the time. Auto just switches "real-time" between the two based on driving habits and conditions. Nice in concept, not in practice. I never left it here because it seemed the adjustment was always behind. I did calibrate the system with the app, multiple times. No dice. It was never right. But there was a much bigger problem than the modes not really working for me. Rebound damping in the rear end of the car. There was simply not enough and the car would "buck" over large bumps and in certain conditions giving the impression that there was a lack of control. For this reason I would say that the car handled better for most conditions (especially daily driving) in stock form. This was a fatal flaw for this system in my mind and one Bilstein had no interest in helping with. The installing shop (which my brother owned) checked the car over several times and everything was installed appropriately. It should be noted that the different ride modes had very little effect on the damping issue. ANd since PSS10 is as I understand it, very similar but with manual adjustment, I would be very wary. And there will be more on Bilstein issues on S4 later in my post.
    Suspension Setup #2: After being annoyed for as long as I could stand, I pulled he Bilstein off the car. At the recommendation of 034 Motorsports (who is local for me) I went with their lowering springs. They felt it would better meet my expectations. We went back and forth on which shocks I would use and we ended up deciding that we'd try the factory ones first and see how it went. And it was the right move. The car rode great. Almost as comfortable as stock. HOWEVER, there was a ride-height problem right from day one. My shop called me and sent pics - the car was at least as high as stock in the rear end. I didn't have a choice but to take the car back and see what happened. And while it settled some, it was not enough. The car had hot-rod like rake and the look just didn't work for me. Unfortunately 034 had no real interest (or resources) to get this right. It kind of baffled them but that's the extent of it. So off it went.
    Suspension Setup #3: KW v3 Coil-overs: After doing lengthy research, more people recommended this setup than any other and I was at the point where I was willing to spend to get what I wanted. So I pulled the trigger and had my brother install it. Before I ever drive it his impression bothered me. It was stiff over the small stuff but soft over the bigger stuff. Now of course the suspension is completely adjustable, 2-way all the way around and so I took to doing so over the following weeks. And ultimately I got it to a point where I felt I couldn't do any better. This experience showed me that there is likely some flaws in dynamics of the suspension of these cars. As with the Bilstein, the front end of the car behaved relatively fine. It was the rear that provided the challenge. I ended up with very little relative compression (bump) damping (around 1 or 2 clicks out of a possible 12), and a ton of rebound damping (around 8 or 9 out of 12 clicks). And I would have gone higher on the rebound damping if I could. But more made the car ride real harsh due to the fact that suspension travel was impeded, I believe. At the end of the day, I was never able to adjust the harshness over small bumps out. I felt EVERYTHING. And while I could mostly live with the control over larger bumps which was better than the Bilstein setup, for the money it certainly wasn't perfect. And again, ride quality wasn't the only issue. Due to the lack of bushings/spring perches, there was a huge amount more road and mechanical noise. Keep in mind that I did do the 034 X-Brace and a couple of the chassis inserts at the same time as the KW's. I did specifically as 034 NOT to sell me the ones that I would notice this kind of thing from. So I don't honestly know how much of the added noise was from the inserts and how much was from the KW's.
    At the end of the day, enough was enough. When I sold the car it handled well but added harshness and road and mechanical noise was too much for this 40+ year-old to handle, considering what started with. I do blame myself for some of this. I tend to over analyze this kind of thing and admittedly have some OCD. But objectively speaking, for the money I spent I should have been happier with the car.
    What I learned from my B8.5: I don't like coil-overs for daily-driven street use. And I have a feeling many Audi owners will feel the same way. Too harsh and too noisy. Lots of variables, often high-cost and difficult to I'm now on my 6th Audi and almost every one I have modified suspension on has had issues. My first was a B5 A4 which I bought lowered. I think it had Koni's and I don't remember the spring but it was a street-comfort thing because the car was not real low. No shock, this car rode and handled perfectly with the exception of the inherent under-steer. The car was light, nimble and fun to drive and had zero harshness or excessive noise. A great daily-driver and a gateway drug for Audi.
    But the 1.8T, even tuned as it was, was pretty gutless. And so I found a B6 S4 used and pulled the trigger. The S4 was stock until I decided to lower it. As it relates to this thread, I put street-comfort springs on the car and Bilstein shocks. It should be noted that, at the time, Bilstein did NOT have a SKU for the B6 S cars. Just the A. So they actually re-valved the fronts for the extra weight of the V8 and gave me A4 rears. Ironically, the front was fine but the rears were never right. And if you're guessing that the problem was the start of a theme, you're right. Rebound damping was pathetic! The car was never right and no amount of calls to Bilstein or tweaking by my shop helped. Overall, everything else was fine for my taste but the rebound problem tweaked me. Car sold.
    Next car was a B8 S5. I could barely afford the car at the time. It was a City car and had been a bit abused. Paint was never great, had some rash on the wheels but from 10' away, was as beautiful a car as I had ever hoped to own. Plus the sound of that V8... But since the car was never in great shape, I never modified it. I owned it for 4 years, stock and loved every minute - until it started leaking heavily every time it rained. Weather dried out and I traded it in for the B8.5 S4. Considering my wife had my son while I owned the S5, the move to the S4 made sense. And as much as I liked the sound of the V8, the blown 6 was better in virtually every way.
    Now to the S6. It's a 2016 Prestige and had a bunch of mods when I bought it and only 6500 miles. So I was able to do that critical "audition" before I bought and I found that the electronic lowering modules did not negatively impact the car at all. I drive multiple stock cars before I bought mine. The car does have EC sway-bars and end-links which are a little noisy but the added stability makes it worth it. I am genuinely happy with this car. It's the all-around perfect car for me. And again back to the point, if I did not have the air-ride I would be cautious about modifying. But if I were going to, I think I would go to a reputable manufacturer's street/comfort lowering springs. And personally, I would steer clear of Bilstein on Audi. I know they work on other manufacturer's cars but I've not had good luck. Koni has some good options and if you're not going too low or too stiff, the factory shocks can appropriately damp a mild lowering spring. I would not change any bushings or perches.
    I think that if you're looking for what I do in my cars, near-stock comfort and noise levels, near-stock handling with subtle improvement, and with a stances that's improves the overall look of the car, over-doing it will net you spending a lot of money with the potential for frustration. I understand that everyone is different and to be clear, this is my personal experience and opinion. But I hope it's useful.
    Feb 06 2020
    Chicago, IL
    Quote Originally Posted by djmika View Post
    Thanks for the very thorough response! I feel like my hesitation comes from exactly what you are talking about. I drive this car daily and I appreciate how comfortable it is. I also don't want to lower it too much! Just an inch would be more than enough! So lowering Springs might just be what I need...with keeping stock suspension....I just need to know exactly how that would impact the longevity of said suspension...
    Aug 21 2018
    New Jersey
    kw has or street comforts are great lowering suspensions. Their springs come with a support spring that helps the rigidity of the springs in the collar during corners. Not only that they are adjustable and come with new hardware such as bump stops. Could piece together some new items elsewhere with different springs but kw provides it all in one box. Then they have additional hardware for for their suspensions. Street comforts to me beat the h&r cause they are dampening adjustable and they beat the bilstein ps because they are stainless steel not zinc. But their is plenty of anti zinc protectants.
    Feb 06 2020
    Chicago, IL
    The KW Street Comfort Coilovers isn't compatible with the C7 A6 though, no?
    Aug 06 2014
    NJ->CO
    Why not?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 06 2020
    Chicago, IL
    Oh interesting!! the last time i checked those on an other website it said not compatible!!
    Aug 21 2018
    New Jersey
    Nah get them from eurocode plus they are cheaper and have a $100 rebate on all coilovers
    May 10 2015
    Pittsburgh PA
    Great response, I was actually considering those Bilsteins for my B8.5 A4 so it was nice to see the indepth impressions.
    Interestingly, that rear end sensation you're experiencing is also prevalent on my A4 with stock sport suspension (which to my understanding is the same as the S4's setup just tweaked to account for the A4 having less weight). Feels slightly overdamped in the rear and over some bumps very unsettled. I was hoping coils with adjustable damping would remedy this but evidently not...No longer that inclined to change my suspension setup before the originals wear out
    Glad someone else is as particular about suspension haha
    Feb 06 2020
    Chicago, IL
    This is where it says it doesn't fit:
    https://www.ecstuning.com/b-kw-suspe...UaAuWqEALw_wcB
    The part numbers are different but it's the same product name so that's what confused me probably: 18025002KT VS 1801000B
    Aug 06 2014
    NJ->CO
    Street-comfort is a product line with many part numbers for many different cars....
    Sorry, I'm not sure your search-foo is strong.
    If you decide to purchase anything 100% call them before ordering to make sure you are getting the right product for your car. The ones you linked to were for a Mercedes...
    Here is the ECS link for the kit matching the Tirerack link for your car. (Still call them before ordering anything.)
    https://www.ecstuning.com/b-kw-suspe...it/1801000bkt/
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 06 2020
    Chicago, IL
    Yes sir! Thanks
    Oct 02 2006
    Wadsworth,OH
    If you like the idea of the KW Street Comforts also check out the ST system (https://www.ecstuning.com/b-suspensi...em/13210078kt/) typically they are on pair with their KW big brother V1 kits, just with galvanized bodies instead of stainless.
    With maintaining a comfortable ride in mind my brand suggestions would be; KW, Bilstein, ST, H&R. All are going to be quality setups with dampers designed to match the springs rates/car weights/balance/etc.
    -James
    Feb 06 2020
    Chicago, IL
    -James
    Thanks! Though the link u have there says it doesn't fit my car. Also, I live in Chicago, would stainless steel be better?
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    I have Eibach springs on mine with the stock S-Line shocks. Ride is smoother than stock was and it sits just lower enough not to cause headaches (like the H&R did on my B7 A4). Highly recommended.
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Senior Member Two Rings bthethy's Avatar
    Oct 28 2018
    London
    Quote Originally Posted by baldy View Post
    Looks good. How much did it drop it by? You got any close up pics.
    A7 3.0tdi 272 Black Edition Mythos Black Tech pack
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    That looks great. Slight forward rake. Also any 3/4 shots, the spacers look great. I have 15mm ready to go all around but debating 15/20. I have H&R Sport Springs yet to install.
    Feb 25 2020
    Hong Kong
    Guys, would you gave me some comment of KW HAS on my existing B4 vs Bilstein B8+some lowing spring to lower my A7?
    HAS Pro will be adjustable but it have to use with a softer B4 shocks
    B8+lowing spring will be totally brand new but un-adjustable
    In term of ride comfort and lowing, which setup will be better?
    Active Member One Ring Brownredrider's Avatar
    Mar 11 2020
    3.6l Touareg 2 1974 VW Thing
    Farmington, Utah
    Bilstein B8 and H&R Springs, winter wheels so they look crappy.20200329_103747.jpeg
    Sent from my SM-J337V using Audizine mobile app
    Mar 15 2008
    Chicago
    Quote Originally Posted by Brownredrider View Post
    Curious to hear your opinions on the Bilstein B8 struts.
    2015 Audi C7 A6 TDI S-Line Black Optics
    Mar 14 2019
    Miami, FL
    On ST Coiloivers
    Just put them in a week ago and still playing with the height:
    Feb 25 2020
    Hong Kong
    Have you try on OEM with H&R spring? Or you install them as a set
    Mar 11 2020
    Farmington, Utah
    The B8 are nice combined with the h@r springs little stiff in slow speed neighbor hoods but canyon driving is awesome bridges and overpasses not bad at all but noticeably stiff from an OEM sport suspension. I added the 034 rear sway bar as well and it helped with the understeer.
    Mar 11 2020
    Farmington, Utah
    My car had standard suspension so I did not if it had sport shock and struts I probably would have just installed the H&R springs for the ride hight.
    Quote Originally Posted by edmondhk View Post
    Feb 25 2020
    Hong Kong
    any idea on bilstein B4 same as standard or sport one? Coz that's exactly what installed on my car.
    And from previous owner.
