My son's 2005 1.8T Tiptronic developed an issue today that has me stumped.
Car ran great a couple of days ago. Today, I jumped in it to move it to a different part of the driveway and could not get it running. Instrument cluster seems dead with the exception of the airbag and traction control lights (no warning lights or CEL prior to this issue). It will start, but die in a couple of seconds like an immobilizer issue. Here are the codes that I pulled:
OBDeleven data log
Date: 2020-02-15 13:38
VIN: WAULC68E05A123318
Car: Audi A4
Year: 2005
Body type: Saloon
Mileage: 311830 KM
01 Engine Control Module 1
System description: 1.8L R4/5VT G
Software number: 8E0909518BC
Software version: 0020
Hardware number: 8E0909018A
Serial number: AUZ6Z0D0339797
Coding: 0016751
Trouble codes:
P1650 - Databus drivetrain missing message from instrument cluster No signal/communication
static
P1635 - Databus drivetrain missing message from A/C control module Implausible signal
static
P1699 - Databus drivetrain missing message from Steering Column Electronics Implausible signal
static
02 Transmission Control Module
System description: AG5 01V 1.8l5VT USA
Software number: 8E0927156AA
Software version: 0505
Coding: 0001002
Trouble codes:
No trouble codes found
03 Brakes 1
System description: ABS/ESP allrad 4529
Software number: 8E0614517A
Coding: 04277
Trouble codes:
01317 - Instrument cluster control module No communication
static
08 Air Conditioning
System description: A4 Klimaautomat 1424
Software number: 8E0820043AD
Coding: 00000
Trouble codes:
Trouble codes:
static
00474 - Anti-theft immobilizer system control module No communication
static
09 Central Electrics
System description: int. Lastmodul USA 0517
Software number: 8E0907279F
Coding: 00003
Trouble codes:
static
01317 - Instrument cluster control module Please read DTC
static
static
11 Engine Control Module 2
Trouble codes:
15 Airbag
System description: Airbag 8.4EP
Software number: 8E0959655K
Software version: 1001
Coding: 0010607
Trouble codes:
00474 - Anti-theft immobilizer system control module No signal/communication
static
16 Steering Column Electronics
System description: Lenksáulenmodul 0611
Software number: 8E0953549N
Coding: 01041
Trouble codes:
static
static
17 Dash Board
System description: KOMBI+WEGFAHRS. RB4 D42
Software number: 8E0920950P
Coding: 01231
Trouble codes:
25 Immobilizer
System description: e 17 eingeben
Software number: Bitte Adress
Trouble codes:
46 Central Module Comfort System
System description: Komfortgerát T7B 1612
Software number: 8E0959433BB
Coding: 11788
Trouble codes:
static
Seems like it's a cluster issue. I checked all of the fuses on the side of the dash, tried a spare key, swapped the ECU relay with a known good one, pulled the cluster and reseated the connectors with no change in behavior. Battery is good, codes do not clear. Any ideas of what could be the issue, or what I should check next? Thank you.
