Hi everyone,
When shifting in my 2000 1.8t (AWT), the rpms jump up higher than what I was currently driving at when I push in the clutch, even though my foot is completely off the accel pedal. Since I got this car, I adapted to this and usually wait a bit before pushing the clutch in, but now it's starting to annoy me.
I can hear the turbo flutter instantly when I put my foot off the accelerator (ik it's not supposed to flutter, I might have a bad DV), but even after hearing the flutter and pushing in the clutch instantly, the car still revs up a bit like I'm still holding the accel. pedal.
While cruising without accelerating and pushing the clutch in, the rpms stay still for a second or two, and then start dropping, it drops to 1.1k or 1.2k and stays there, it will go down to idle speed only if I completely stop. I also tried stalling the car and it just wouldn't happen because it was always at cca. 1.2k as long as I wasn't going uphill. It drove by itself in every gear, with my feet nowhere near the pedals, even fifth, not 'coughing' or anything. That made me think the ECU is adding this to prevent stalling? But would this be connected to the shifting situation I described earlier? And why would the ECU do this once I let go off the accel. pedal to shift?
I got it to do something werid before when testing: going down my driveway from 0 (it's downhill) I put it into third and slowly lifted the clutch, once I was rolling I completely let go of it, it coughed but kept going, I did about 10m then pushed in the clutch and brakes completely at once to come to a full stop, the result was the car running by itself at cca. 1.8k (can't remember exactly), holding it there perfectly and I was standing still with my clutch and brake pedals in, the gas pedal wasn't touched at all in this whole process, .... ??? I watched it run like this for like 20 seconds, thinking it will eventually stop, it kept running like this until i put it into neutral and let go of the clutch.
Anyone got an idea what to check? I got VCDS but I only have some HVAC codes and central electronics stuff (alarm triggers etc), nothing that I think would affect this.
