Last summer I went on vacation Chicago to LA and back for 4,600 miles and burned about 1 quart. My current oil change I have only used a small amount in 2,400 miles so far. Depends on how hard I am mashing on the skinny pedal for consumption. Replacing the PCV is supposed to help with consumption but doing that will depend on what it is gonna cost you. If you turn your own wrenches you can do it yourself for probably $200 in parts and seals. If you are gonna take it to a shop then it might be closer to $1,500. We have to change 7 quarts each oil change and if you burn an extra 3 quarts each oil change you will not spend $1,500 in extra oil in the life of your car.
$1,500 @ $25 per 5 quarts is an extra 300 quarts. Burning an extra 3 each change then that is 100 changes, at 10K per interval that is 1,000,000 miles as a break even point. An extra 4 quarts gives you a 750,000 mile break even.
My point, carry an extra quart unless the PCV totally goes out.
