Results 1 to 7 of 7
    Feb 05 2020
    Newington, CT
    2012 A7 Rear spoiler issue
    Hi, new to the forum. Looking for some help. My rear spoiler stopped working and will not go up with the button or at the speed where it should. I have no fault codes regarding the spoiler and when i do press the button after starting the vehicle you can hear the spoiler motor working and the light does come on. Any suggestions? Thanks in advance!
    Active Member Three Rings Thomas@TAI-VW's Avatar
    May 20 2005
    B8S4 Chariot of the CLODS
    Hawaii
    2012 S4,6MT. Steering wheel/4 rims & tires/seatbelts/windshield wipers/41 psi in front tires/40 psi in back tires/CD player/AC/sunroof/oil level=full/coolant=full/no CEL/glovebox/no car payments/dusty brakes/lowbeam/high beam/turn signals/small nick in the bumper from a stone about 1/16" in dia. about 4 " below the headlight/gas in tank/clutch-brake-gas pedals.
    Junior Member Two Rings RickInJax's Avatar
    Dec 04 2018
    2009 Mini Cooper S Convertible 6 speed manual
    Fruit Cove / Florida
    Hi Everyone. I was looking at this thread as my rear spoiler will not go up or down. The button show the light on/off and I can hear it trying (motor sound) but nothing. I do not get a fault.
    Suggestions? I saw the link but it is for a system fault. There is no system fault and I hear the motors running when I press for up and/or down.
    thanks
    rick
    Rick In Jax
    2013 Audi A7 Prestige Black on Black
    Dec 04 2018
    2013 Audi A7 Spoiler Actuator Motor Assembly Replacement
    Intro
    Hello everyone. My spoiler was stuck down. It would not open or close using the button or automatically. I could hear the motor turning but nothing happened. I DID NOT have an on-screen Fault. I did try to unplug and then re-plug the controller, but nothing changed. After searching and only finding bits and pieces for this problem I finally just did it.
    I did this in two sessions. First, I disassembled to test the actuator. In my case it failed so I knew what I needed. Then I put everything back. Second, I had my replacement actuator (made sure the part numbers matched) and made the change.
    Removal
    Step 1 – Remove the rear cover by pulling on the handles on each side of the cover. These will simply pull away and the cover will drop.
    Step 1
    Step 2 – Remove hatch lock cover and adjacent cover. Pull the hatch lock cover and use a screwdriver to release the other. You may have to pry the lock cover loose before pulling off.
    Step 2
    Step 3 – Remove inside cover molding by 1st opening the access door and removing the two 25T screws, then pull the cover from the trunk lid. It must be pried off, but it basically snaps off.
    Step 3
    Step 4 – Remove seven nuts, being careful not to drop them inside the housing. You will need a deep socket 10mm. Also remove two nuts, one at each light. Remove two screws (one each side) from rear light. Then remove two screws (one each side) from the outsides of the rear lights. I had a magnet just in case and to help in reassembly.
    Step 4
    Step 5 – Remove the four wire connectors in the center area, each having a release. Also remove the wire connectors at each taillight.
    Step 5
    Step 6 – Now you are ready to remove the rear section of the A7. Place your fingers underneath the spoiler wing and against the permanent part of the rear section. This will give you leverage to pull off. Note – you will need to unplug the “close” button wire before you can remove it fully.
    Step 7 – Now you have removed the spoiler section. Next you will need to remove the actuator motor assembly. In my example the spoiler was stuck down.
    Step 7
    There are eleven nuts to be removed with two having caps/covers.
    Step 7b
    Step 8 – The actuator will separate from the rear section but there is a wire connection that needs to be undone first. However, at this point it is easy to test your spoiler to see if it actually works or not before disconnecting the wires. You will need a 12-volt power source (positive & negative) ends. Touch the two connectors shown in the image below and reverse them for the opposite direction. In my case the motor tuned just a little, but the wing never did open/close.
    Step 8
    Step 9 – Unplug the wire to disconnect the actuator motor assembly and remove it.
    Step 9
    Step 10 – Remove the wing by removing two screws on each end.
    Step 10
    Step 11 – Remove these two screws if needed. In my case I needed to remove these as they were missing on my replacement part.
    Step 11
    Summary – This was the last step in removal. I did test the replacement actuator before disassembling and installing it onto the A7. When reassembling the unit, make sure you test the wing alignment before the final tightening of the spoiler wing. In my case it could have used a little tweaking on alignment. But back in business!
    Final
    I hope this helps others.
    Rick Hill, Jacksonville, FL 2013 Audi A7 Prestige, Brilliant Black, Stock
    Let me know if you want the pdf.
    Sorry but could not upload images from my PC. If there is a way please let me know.
    Pics in links below.
    https://www.audiworld.com/forums/a7-.../#post25598440
    Rick In Jax
    Junior Member Two Rings DarthVader711's Avatar
    Nov 18 2014
    United States
    I just want to say this thread is really helpful. I ran into a similar situation recently in my 14 S7. When I press the spoiler button, i can hear the motor work, but I hear some nasty grinding noise as if the gears are not engaged to open the spoiler. So now, its stuck and won't go up. What is the part number of your actuator?
    2013 Audi RS5 - AWE Exhaust
    2019 Audi S5 Sportback
    2012 Audi S4 - BLK - DSG - AWE Exhaust
    2013 Genesis Coupe 3.8 RSPEC
    Dec 04 2018
    Quote Originally Posted by DarthVader711 View Post
    Here is the pic with the part numbers off for my 2013 A7 replacement.
    But there is what I see:
    4GB.827.948F
    Modul No. 80252
    Another number: 004 10087 F
    Found this on ebay...
    https://www.ebay.com/itm/23416380816...Bk9SR7L81M2KYQ
    rick
    Rick In Jax
    Dec 02 2022
    Albania
    Audi a7 c7 spoiler gear removal
    I have my spoiler removed but my gear are damaged and i want to replace it but i cant remove it.
