Results 1 to 13 of 13
    Senior Member Three Rings rs5_tdi's Avatar
    Aug 03 2016
    B9.5 Allroad , B8.5 RS5, B9.5 SQ5
    Boston
    AUDI FACTORY REMOTE START ( Massachusetts )
    Remote Start for your Audi Q5 - SQ5 New England Area - Massachusetts
    For the last few years I have even an authorized installer for a brand of vehicle remote start systems. Currently have them installed in all of our Audi vehicles, 09 B8 A4 Avant , 14 B8.5 RS5 , 23 B9.5 SQ5 and can honestly say , we have not had one single issue. From using the oem key fob to using the newly released GSM app , I can honestly say that the connivence has been incredible. Especially with the unpredictable New England Weather.
    For Most of the newer vehicles 2018 - , the system is plug and play ( with some additional coding on the remote start module done by installer ) easily removable for anyone worried about their Audi Factory Warranty
    With the newer cars a key is required to stay in the vehicle for remote start. If paired with the GSM phone app , you wont even miss the key !
    You phone will replace the key meaning you can drive your vehicle with just your phone alone !
    My Personal Experience - All my vehicles have been to the dealer with this system installed and has never been noticed and does not give any codes when the vehicle is looked over by Audi ! No trace
    Below you can see the vehicle being remote started via Oem key fob and the Gsm app !
    The app works flawlessly and has loads of features !
    ENGINE STARTING AND STOPPING CONTROL
    CHECKING THE START-UP CYCLE DURATION
    KEYLESS ENTRY AND DOOR LOCKING
    CONTROL OF CONVENIENCE AND COMFORT FEATURES
    MULTI-USER SHARING
    BATTERY STATUS DISPLAY
    ALARM AND SECURITY SYSTEM
    NOTIFICATIONS AND ALERT SYSTEM
    MULTI-VEHICLE MANAGEMENT
    GPS LOCATION AND EVENT HISTORY
    INDOOR TEMPERATURE DISPLAY
    CONTROL OF AVAILABLE CUSTOMIZABLE FEATURES
    For anyone interested in a remote start system feel free to shoot me a msg or a txt
    Id be happy to answer any questions or just demo the system for you !
    Install for these kits usually take less then an hour
    Can come to you if the location & weather permits
    Or we can schedule a time for you to come to the shop !
    617-702-2785
    Oct 18 2018
    Upper Marlboro, Maryland
    How much are they going for?
    Senior Member Two Rings Justadam's Avatar
    Feb 26 2017
    Atlanta
    Audi does not make a factory remote start. Compustar is an aftermarket company, and although it may be a plug in module, it is no way factory. Why German cars do not come with remote start is beyond me.
    Veteran Member Three Rings NoggieRS5's Avatar
    Sep 25 2019
    Houston/Texas
    Quote Originally Posted by Justadam View Post
    I heard from someone from the UK and they say that remote engine start is not allowed because of some safety reasons. I might not just be the UK, might be Europe as a whole.
    Apr 03 2016
    Yes for Cars with stick it’s not allowed, unless you do it aftermarket, which is what this unit is. But cool if it works. GLWS.
    Aug 03 2016
    Boston
    Pretty sure the Oem Keyfob remote is a factory item ! Installing a remote starter in a vehicle and then using your factory remote to start the car would be the case ! Pretty sure any audi owner that has made it all the way to AUDIZINE would be knowledgeable enough to know that correct ! AUDI DOES NOT COME WITH REMOTE STARTS HENCE THE MODULES BEING USED WOULD BE AFTERMARKET !
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Nothing new, aftermarket remote start has been available on the B8 for a long time.
    Mar 12 2014
    Long Island, NY
    How much for a unit shipped if I can sort out install?
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Junior Member Two Rings Brazeagle's Avatar
    Jan 21 2023
    Audi RS5, BMW R1250GSA, Ford F150 TREMOR
    Stamford
    There are several options on the internet for GOOD and RELIABLE remote starts...
    I am debating between two brands...will make a decision this weekend.
    One is the 12volt (600USD) and the other is the Lessco Electronics (198USD) BIG DIFFERENCE in price, and I am in the process of researching about them...
    SO far the Lessco wins in every aspect for a fraction of the price.
    12VOLT (USA)
    Lessco (Canada)
    Cheers
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Quote Originally Posted by Brazeagle View Post
    12VOLT (USA)
    Lessco (Canada)
    Cheers
    Do either of these use a separate fob? I have the Mods4Cars module to control the up\down of the roof on my Cabriolet, so I would need a separate fob.
    UPDATE: 12volt does offer "2 long range remote fobs".... but then the price jumps to $720! Also, it would likely require (regardless of if you use OEM remotes or fob) "Stage 2 programming" where you install everything, do Stage 1 programming, then remove the module and ship it back to them (in Tulsa, OK) and they will do the Stage 2 programming, then ship back to you. The do have a "cap" that will allow you to drive your car with all the wiring there but without the module. alrightythen.... bit too much hassle for me. I'll walk my happy-hind-end out to the car to start it...
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Jun 25 2019
    Ottawa/Ontario/Canada
    Not allowed to let car idle, that why audi has stop/start.
    Jun 25 2019
    I had an idatastart in my c7 a6. Didnt need a key. Just transferred it to my b8 sq5 but that needs a sacrificial key so I used that plastic key that fits into the fob in the glovebox.
    Aug 03 2016
    Boston
    Bump
