Results 1 to 7 of 7
Thread: door alignment?
    Established Member Two Rings Juntuned's Avatar
    Feb 04 2020
    Meridian, ID
    door alignment?
    On the exterior, if you run your hand on the paint starting from the rear quarter panel until it meets the posterior most part of the rear door, the door itself is protruding outward a bit from the body when fully closed. Thinking in terms of offset, the door has a slightly negative offset compared to the body of the car and is poking outward by a couple mm, but still noticeable. The rear doors aren't sagging or angled wrong, they just don't appear to be fully closed or flush with the body on that posterior most gap. Any suggestions? The striker plate on the body seems to be non adjustable.
    Sold: 2010 Ibis B8 S4 (GIAC STAGE 1) pulled so hard. 150mph daily in Nevada
    Current: 2019 Quantum B9 S4 (APR STAGE 1) Now formidable, still not fast enough
    Jan 03 2020
    2019 Toyota Tundra Off-Road
    Texas
    This is how my doors are also. I think it is intentional.
    Jan 26 2019
    Same with mine. Pretty sure it’s not intentional. As I don’t see the point of it. Just some good ol’ fit and finish from Audi
    Veteran Member Three Rings Outie Essex's Avatar
    Jan 06 2020
    2013-Explorer-Limited, 2019 VW Atlas SEL Premium
    Cocoa, FL
    Ok so I had a similar issue on my S6. Mine was actually on the front door. All you need to do is open the door and adjust this:
    Its on the car body. Loosen the 2 torx screws and move it in ever so slightly. Then retighten. Voila, flush door.
    Proud owner of a '13 S6
    Bought used in July this year
    37k miles and counting
    White
    I believe it has every option available
    Nov 29 2019
    I have the same issue. ^^^if that's the fix, that would be awesome!
    I'll report back
    Sep 11 2011
    2022 RS7 & 2201 TTRS
    DFW
    I remember reading specs on one of the factory service manuals for the door alignment, as I had the same problem on a TT. factory specs call for a slight offset in the direction you notice, but you can get it closer to zero/flush if you desire by the method above but DO NOT use torx bits, they are triple square spline drive screws (you will strip with standard set of torx).
    I believe they are M8 size. Use painters tape to mark the current edge top and side, loosen very slightly and tap inward until you see a small gap between the edge of the striker and the tape so you can track your progress. Small adjustments, re-tighten and test with door close.
    Go too far and your door will be more difficult to close completely without slamming so take your time.
    2022 RS7 & 2021 TTRS
    Retired: Macan S, 2019 RS5, 2020 TTS, 2019 S4, 2017 TT, 2014 A6 TDI, 2014 S4, 2011 A4 Avant, 2011 Audi TT Roadster
    Jan 16 2007
    Necro Bump...
    Just noticed recently that while the passenger side doors are flush, I can push them in quite a bit. Was drying the car after washing and as I was dabbing the side, the door was moving in. Checked the driver's side and both are nice and tight. Tried moving the doors in, however, the screws are all the way on the inside range of their play. Any ideas?
