My car is failing the emission tests!
New ngk platinum plugs (old were all light chocolate brown), new 5w-50 no brand oil and a bosch filter. Tried the emission test with and without the airfilter.
Anyone see anything wrong on these logs? :)
VCDS logs, cold engine fast run max 225.28g/s on the MAF, may be bad?
https://www.dropbox.com/s/exwiqsakha...-003.xlsx?dl=0
Emission test
https://www.dropbox.com/s/rq52ucwwll...ssion.pdf?dl=0
Code:
Saturday,01,February,2020,16:30:23:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: License Plate: IDLE -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine (4D0 907 558 ) 16:30:13 Group 002 760 /min RPM 18.0 % Load 3.74 ms Inj. On Time 6.11 g/s Mass Flow 16:30:13 Group 032 3.6 % Lambda 7.0 % Lambda 1.3 % Lambda 7.8 % Lambda 16:30:13 Group 033 -5.5 % Lambda 0.065 V Voltage 3.1 % Lambda 0.110 V Voltage
Code:
Saturday,01,February,2020,16:50:00:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: License Plate: DELETED FAULT CODES Address 01: Engine (4D0 907 558 ) 16:49:50 Group 032 0.0 % Lambda 0.0 % Lambda 0.0 % Lambda 0.0 % Lambda 16:49:50 Group 033 25.0 % Lambda 0.040 V Voltage 20.3 % Lambda 0.650 V Voltage
Code:
Saturday,01,February,2020,15:40:17:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: License Plate: DJ80110 Mileage: 341340km-212098mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005) Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75 76 77 Mileage: 341340km-212098miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 4D0 907 558 Component: 4.2L V8/5V G 0002 Coding: 05752 Shop #: WSC 23351 VCID: 6ADC19EA16E4A91F19-515A 2 Faults Found 18084 - EPC Warning Lamp (K132) Circuit P1676 - 35-00 - Electrical Malfunction 18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: None Part No: 4B0 927 156 BT Component: AG5 01L 4.2l5V RdW 1314 Coding: 00011 Shop #: WSC 00120 VCID: 7AFC29AA6644199FE9-515A No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 8D0 907 389 F Component: ABS/ESP allrad D36 Coding: 06397 Shop #: WSC 12345 VCID: 3664FD9A12DC3DFF4D-515A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: VCID: 55A65A16AC9A16E7A4-FFFE ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI8.lbl Part No: 4B0 959 655 E Component: Airbag Front+Kopf 0001 Coding: 00406 Shop #: WSC 02325 VCID: 326CC18AFEB421DF61-515A 1 Fault Found 00532 - Supply Voltage B+ 07-00 - Signal too Low ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.lbl Part No: 4B0 920 930 P Component: KOMBI+WEGFAHRS. VDO D07 Coding: 01183 Shop #: WSC 00000 VCID: 2D56D2F6E78A7E273C-515A Component: AUZ7Z0X1177409 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1177409 3 Faults Found 01302 - Control Module for Telematic (J499) 49-10 - No Communications - Intermittent 01303 - Telephone Transceiver (R36) 49-10 - No Communications - Intermittent 01327 - Control Module for Parking Aid (J446) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: None Part No: 4B0 962 258 E Component: Zentralverrieg.,DWA D33 Coding: 04683 Shop #: WSC 02325 VCID: 2B52DCEED99E701722-4EE6 15 Faults Found 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 00668 - Supply Voltage Terminal 30 07-00 - Signal too Low 01566 - Activate Signal for Interior Monitor 28-00 - Short to Plus 01568 - Signal for Convenience Opening 28-00 - Short to Plus 01569 - Signal for Convenience Closing 28-00 - Short to Plus 00952 - Signal; Drivers Door Open 28-00 - Short to Plus 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Rear left door 59-10 - Can't Unlock - Intermittent 01561 - Rear left door 60-00 - Won't Safe 01561 - Rear left door 61-10 - Won't De-Safe - Intermittent ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4B0-919-283.lbl Part No: 4B0 919 283 Component: Parkingsystem A6 RDW D18 Coding: 01116 Shop #: WSC 02325 VCID: 66C46DDA02FC8D7F3D-51D0 No fault code found. End-------------------------(Elapsed Time: 06:44)--------------------------
