Results 1 to 22 of 22
    Apr 27 2017
    Pennsylvania
    Audi A4 B8.5 APR Stage I Advice
    Hello Everyone,
    After going through a year and a half of a mix between unemployment and temping I finally am back to a big boy job and I'm ready to do some mods to my 2014 Audi A4. Now, awhile back I was already looking at an APR Stage I tune and this car is my daily driver so I'm not sure if I'm going to even consider a stage II at this time. My main question is how people feel about stage I upgrades they have made to their respective Audi and how the car has responded. I think I've come across only two or three post where someone's engine had completely shit themselves but I think each ended up just being an unfortunate engine malfunction and nothing to do with the tune itself.
    Second, are there any recommendations or suggestions in upgrading any of the OEM parts when doing a Stage I ECU tune? I feel like it's not necessary but wanted to see if anyone had suggestions and if so, how would this benefit/help my car? As you can probably tell by reading this I'm fairly new to the game and have done relatively extensive research but figured getting a threat opened up would give me better insight.
    Thank you!
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    Stage 1 is pretty safe, lots of people here run it with no problems. You will feel a difference and you will like it. Make sure your timing chain is in good shape and go get it tuned!
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    Take a look at your turbo/wastegate as well
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
    Established Member Two Rings colorado.a4's Avatar
    Dec 04 2018
    Quote Originally Posted by S-Liner View Post
    I one this as well. within 5 minutes of driving my vehicle from the shop after getting its stage 1 tune, I got underboost codes, resulting in replacing the turbo. Whether this was because of the tune, or an already starting to fail turbo, the tune definitely instigated it (65K miles). While I did replace the turbo through audi years ago, I would’ve gone K04 for cheaper than an OEM. Little did I know. Either way, stage 1 is a fun entrance to the always wanting more power life, and wouldn’t regret it!
    On an ironic note, every time I moved up a stage there was a failure of some part! Mind you, I treat my car like if it was my own child! Goes to show that parts going out will be excelled to failure faster with tuning.
    Stage 1 - Turbo (65k)
    Stage 2 - Injectors (82k)
    IG @Colorado.a4
    Junior Member One Ring Scoosch's Avatar
    Feb 18 2018
    Minnesota
    I think the stage 1 tune is a no-brainer. It only takes about an hour at the shop and you really notice the difference when driving the car. If you like working on the car yourself I would say change out the air filter with an aFe dry performance filter, and you can think about swapping out your turbo inlet hose. It's nice to help the car breathe a little better. If you are a little more ambitious a GFB DV+ diverter valve upgrade can help with the turbo lag or make noise if you are after some fun sounds. Depending on your maintenance schedule it might be time to check the plugs and see if you need new ones, they don't need to be fancy though.
    2015 A4 Prestige Plus - Brilliant Black, APR Stage 2, APR Downpipe, ECS Turbo Muffler Delete, GFB DV+, ECS Silicone Charge Pipe Tubing, ECS Exhaust Cutout, aFe Air Filter, ECS Billet Boost Tap, LED Puddle Light Audi Rings, MMI USB Adapter, Center Armrest Insert, 17" Sparco Pro Corsa Winter Wheels
    May 10 2015
    Pittsburgh PA
    It is typically recommended to go one heat range colder on the spark plugs when tuned, but you will be fine on the stock plugs if they are fairly fresh. But the tune is a night and day difference on these cars, you will really enjoy it!
    You can pretty much run all stock hardware with stage 1, big thing is maintenance. Make sure everything is functioning 100% before adding power
    Jan 05 2019
    Ft Collins, CO
    Quote Originally Posted by Scoosch View Post
    Is that DV going to reduce throttle lag off the line when there's zero boost built up?
    2014 allroad
    Nov 26 2018
    Quote Originally Posted by COar View Post
    There's no reason it should. Short of brake boosting if you're an auto or get launch control or a 2-step, you're not going to be building boost at a standstill.
    2013 B8.5 A4 Quattro 6MT | 034Motorsports HFC | IE Stage 2 Tune
    Apr 27 2017
    Pennsylvania
    Quote Originally Posted by colorado.a4 View Post
    Understood, I'm right around the corner from 65k miles so I'll make sure to get a good look at this stuff before I do anything. Thanks!
    - - - Updated - - -
    Quote Originally Posted by wack0 View Post
    Great, thank you!
    - - - Updated - - -
    definitely feel this is a good idea considering my car is roughly around 62k miles right now probably a good idea to check these beforehand.
    Apr 27 2017
    Pennsylvania
    Quote Originally Posted by 19birel View Post
    Would you be able to elaborate on what's considered fairly fresh? I'm at around 62k miles. I also want to know if checking the turbo, belt chain, etc is something I can diagnose myself or not. I'm sure from some basic research I can do so myself. I love Audi but unfortunately when it comes to maintenance I'm fairly nooby at checking this stuff myself.
    Jan 05 2019
    Ft Collins, CO
    Quote Originally Posted by Ness-Tee View Post
    I think the spark plugs are due at 65k, so you're approaching the replacement interval. They're extremely easy to do yourself. It was a <1hr job for me, but most of the time was spent cleaning the engine bay.
    2014 allroad
    Apr 27 2017
    Pennsylvania
    So everything is fairly simple to check myself to the point where looking at youtube videos or reading forums will be just enough help? I don't want to look at my turbo and be like well it's not cracked, it sounds normal, my exhaust isn't smoking, etc and then find out I was wrong. If that is all it takes to determine if it's in good condition then fine but if it's more complicated than that I'd like to know so I don't try and make an uneducated guess. Like i mentioned I'm fairly new into the car scene when it comes to doing my own maintenance on my car. Just want to be properly prepared. Could be overthinking it way too much.
    Jan 05 2019
    Ft Collins, CO
    In terms of complexity, difficulty, time, etc, spark plugs (at least on this car) are a walk in the park. I'm 100% confident you could DIY after watching a video for any modern 4 cyl (doesn't even matter what the make or model is). You really just need a torque wrench, spark plug socket, and whatever fitting holds down the coils.
    I wouldn't necessarily worry about the turbo. If it's going to fail, it's going to fail. It wouldn't hurt to plan on that (and more happening, even if unlikely) so you're not surprised by a couple thousand dollar bill.
    2014 allroad
    Feb 18 2018
    Minnesota
    Lots of great advice in this thread!
    Sent from my Pixel 3a using Audizine mobile app
    Mar 08 2019
    MA
    My best advice would be to skip stage 1 and save for K04. You are going to want it, even tho you think stage 1/2 is good enough for you.
    2013 allroad Glacier White/Black Sport. Many Mods.
    May 10 2015
    Pittsburgh PA
    Fairly fresh as in replaced within 10k miles or so. If you are at 62k they are probably the originals and I would go ahead and replace them. I actually just replaced my today and it took 30minutes and that was with me checking the gaps of my old plugs and messing about.
    Watch a youtube video, make sure you have a spark plug socket and a T27 Torx bit. A flathead screwdriver helps with remove the connectors on the coil packs, just be gentle. It's a great job to get your feet wet with maintaining your car yourself, just take your time and don't rush. Even if it takes you an hour+ don't worry about it just go at your own pace. The more work you do the more comfortable you'll get.
    For turbo, if it's not throwing any faults and driving as normal I would not be concerned. As for the timing chain you'll need something called OBD Eleven and an android device (or VCDS which is a more advanced software for the computer). Are you near Pittsburgh?
    May 12 2017
    Quote Originally Posted by Chatchie View Post
    Although I'm going in that direction, I disagree. I came from all-show-no-go scene so this was my first time picking up a car that I'm actually working on, engine wise.
    Starting off from stage 1, learning and progressing to stage 2, then now waiting for my K04 has been a ride. I've learned a lot from going that direction thanks to everyone on the forum and actually learning about the process. Just my 2 cents.
    Apr 27 2017
    Pennsylvania
    Thank you all for the responses I really appreciate all the insight
    - - - Updated - - -
    I'm about 4 -5 hours away I live just outside Philly.
    May 10 2015
    Pittsburgh PA
    - - - Updated - - -
    Ah, if you were closer I would offer to scan it for you so you know the timing stretch.
    Being that you have a 2014 and the mileage isn't that high, I doubt that you are in any imminent danger. However, I would still recommend checking this at some point so you can plan ahead for when you may have to refresh the timing system.
    Apr 27 2017
    Pennsylvania
    I really appreciate the help on this. Thanks!
    Active Member Two Rings StreetSatori's Avatar
    Feb 04 2020
    Dothan,AL
    I can only speak to my own experience but the immediate difference in power is worth every penny IMO. My car was instantly more fun to drive: more power, faster throttle response and the torque increase is an added bonus...plus you get to eat up a lot of unsuspecting prey lol Now that being said I happen to live less than 2 hours away from APR headquarters so that made the decision a bit easier with regard to any possible issues or my belief in the tuner knowing exactly what they were doing. I have the Stage 1 for 93 Octane and a rear muffler delete on my 3.0 Prestige and it made it beastly! If you wanna rip it thru the twisties in dynamic, no problem but its still well suited for daily driver purposes in auto. At the price per HP I don't believe you'll have any regrets, JUST DO IT!
    Feb 15 2016
    Cambridge,Ontario
    The next question becomes which one ?
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
