Results 1 to 3 of 3
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Rear Hatch says open on dash, not open in real life. Where is the switch sensor?
    All,
    This is more than likely a very newbie question for the veteran avantists;
    B5 dash says rear hatch is open even when it is closed. I am guessing that there is a switch with a sensor (latching mechanism?) in the hatch that is farked.
    Can someone given me some info on how they resolved this, I don't want to start digging into the rear hatch if the issue is elsewhere.
    Thanks in advance.
    Junior Member Two Rings turboit's Avatar
    Sep 17 2017
    1993 VW Corrado SLC 2022 Forbidden Druid 2016 GT Grade 2022 Fezzari Signal Peak SL
    wilmington/de/usa
    Most VW and Audi have a micro switch built into the trunk or lift gate latch itself. What year and model car? Edit you did mention B5. So the microswitch can be had separately . I would start there. Also check the latch striker to make sure it's not loose or out of adjustment
    Sent from my SM-G975U1 using Tapatalk
    May 13 2009
    XXXX
    Quote Originally Posted by turboit View Post
    Yes, thank for the info
    I am pretty certain that there must be either;
    1) a switch that sensed as closed (that depresses when hatch is closed.. likely)
    or
    2) this sensor is built into the latch(?)
    The latching mechanism seems to be working.
    I wanted to know if anyone has a diagram or location of the switch that senses close ?
    I moved in the last year and I can't find my B5 Bentley, grr.
