Part A:
So let me tell the reason behind what I am about to tell you. I had stock wheels on my car when I bought it. I hit a nasty pot hole a few weeks ago and had to get a new front tire. Since there aren't many places that stock 255/35/20 Michelin PS A/S 3+ tires, I looked for a nice used one. Well I found a set of 2 that still had about 90% tread left. Replaced the driver front tire and kept the other as a spare. I now realize I should have replaced both front tires to have even wear side to side, but still it did not change the comfort of the ride. Still ran smooth as ever.
Part B:
Well then I decided to buy some wheels from Vossen, 20x9ET25 fronts and 20x10.5ET42 rears. So since they were staggered I needed to either fit a 295/30/20 rear to match the 255/35/20 fronts or 245/35/20 fronts and 285/30/20 rears. The issue I ran into was that Michelin didn't make a 295/30/20 in the MPSAS3+, and I figured since I want to keep the exact same type of tire, MPSAS3+, I would need to go with the 245/35/20 F and 285/30/20 R. Those sizes have a 0.5mm total diameter difference and only a 2mm total circumference difference. Well the issue is that I thought since I just got these newer 255/35/20s I would keep those on the front and put my brand new 285/30/20s on the rear. These have an 8mm difference in total diameter and a 24mm difference in total circumference. I have read many places that say to stay within 1% front to back. Well those 2 sizes are 1.1% while the 245/35 and 285/30 are 0.1%. I assumed that since the 1.1% was close enough to 1% that it wouldn't matter too much. I WAS WRONG! It rides like shit, with a shuddering feeling. I am thinking this is because the quattro isn't happy.
Part C:
I just dropped my car off at Tire Kingdom to have brand new 245/35s put on the front. I tell the guy my situation and he begins to give me crap that they may not be able to put them on my car because it isn't a OEM size tire. Stating that I could possibly sew them if handling was the cause of a wreck after the tires are installed. That and said it would void the warranty. Well I don't have a warranty anymore so that's a moot point. But the fact that he said he may not install them because its a different size than OEM baffles me. My understanding of the issue with tire size and quattro is that as long as the overall diameter and circumference are the same on all four wheels, it doesn't matter what size they all are. Like if I decided to put 205/50/15s on all four corners it would look stupid as hell but it would not affect the quattro since it is essentially a square setup. And the fact that 245/35 fronts and 285/30 rears have damn near identical diameter and circumference, I should be fine, right?
