Having blown 40k worth of parts on my B7, this is hands down my favorite mod of all time. It can display over 100+ different vehicle parameters, programmable alarms for each one being monitored. I had oil pressure, boost, oil temp, coolant temp, intake air temp readings as my main screen. Knock sensors on my secondary screen and fuel trims on my third screen. It can read and clear engine fault codes. Has real time graphing. Instrument cluster gauge sweep opening ceremony. That's just scratching the surface of what it's capable of.
"The VFIZ is an embedded measurement computer allowing one to monitor the car's health and performance parameters in real time, directly via the Instrument Cluster FIS, without the need of any external equipment. It allows one to read and clear Diagnostic Trouble Codes, or see user configured alarms which inform the driver when some parameter's limits are exceeded.
It fits behind the Instrument Cluster and is not visible. The Installation is easy: two plugs just need to be connected to instrument cluster then tachometer adaptaion channel needs to be configured one time to have navigation or telematic supported.
The VFIZ is enabled by a fast double press activation key. In case of Audi activation key can be left key on Multifunction Steering Wheel (MFSW) or Dial on Navi Panel near handbrake. In case of Volkswagen Reset key on MFA wiper stalk .If you press this button single time the button operates in usual way. It integrates seamlessly with the existing car infotainment. The use of the Navigation system, MFSW, Bluetooth module is same as usual."
Features, Standard version:
Display Measuring Values Blocks gathered directly from CAN bus or over OBD protocol
Both KW1281 and KW2000/2089 supported over k-line and can-bus
Reading, decoding and displaying Diagnostic Trouble Codes DTC
Clearing Diagnostic Trouble Codes DTC
Plot user chosen parameter over time
Measuring performance e.g. from 0 100 km/h, 0 96 km/h, 60 90km/h, 0 200km/h, etc..
Alarms user configurable alarms (display + audio) when a configured parameter limit is exceeding
Welcome message
Open Ceremony Tachometer needles sweep after ignition off
Plug & Play install, no factory modification needed, only Instrument Cluster adaptation
Seamless integration with car equipment
Upgrades through USB connection
Standard warranty period to 24 months with free updates
Extended version:
support for connecting four additional analogue external sensors:
two type K thermocouple for temperature measurment e.g. Exhaust Gas Temperature (EGT), CHT, IAT...
two voltage output sensors for Oil Pressure Sensor, Turbo Rotational Speed sensor, additional Boost sensor, etc.
there is also optional possibility to configure input to support resistive output sensor like common Oil Pressure sensors
integrated relay for configurable driving external circuit to be used in future
additional storage memory for files, DTC descriptions, additional graphics, logger
background logging
extended warranty period to 48 months with free updates
The VFIZ for Audi (complete set).: A4/S4/RS4 B6/B7 (8E) - Color FIS German US / Imperial MFSW or Navi Panel $233.00 USD
Valentine 1 radar detector input 25.00 USD
Extra features: Extended (ext.Inputs) Int. MAP 60psi $49.00 USD
Total $356.03 USD
$275 shipped (latest firmware included)
