Results 1 to 4 of 4
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Flex plate to crankshaft bolt torque spec
    Working on an 06 A4 2.0T and need the torque spec for the bolts securing the flex plate to the crankshaft. This is an automatic transmission. No mention in my Bentley manual, always seems to be missing the info I need.. thanks
    Senior Member Two Rings OliNix's Avatar
    Oct 22 2014
    London, UK
    Pretty sure it’s 30Nm+90°.
    As in
    1) Torque all bolts to 30Nm in a star pattern.
    2) turn all bolts an extra 90°, again in a star pattern.
    Bolts are single use, so make sure you use new ones! Also don’t forget the shims.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by OliNix View Post
    As in
    This Is not correct.
    I have confirmed torque by contacting the dealer
    60nm (44ft/lbs) + 90 degrees for vehicles without dual mass flywheel
    60nm (44ft/lbs) + 180 degrees for vehicles with dual mass.
    This is exactly what’s listed in the Bentley, but they make no specific mention for automatic transmissions which is where my uncertainty came in. IE: flex plate vs flywheel
    Oct 22 2014
    London, UK
    Sorry I missed the 2.0T bit. This is the spec for the 3.0TDI or ELSAWin has changed spec.
    Make sure they have given you the spec of the flex plate to crank bolts, not torque converter to flex plate.
