Results 1 to 32 of 32
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    GPS Showing wrong location?
    Hey all,
    Are there any solutions to fixing the NAV unit that is displaying the wrong location?
    I have checked to ensure that it is not on DEMO mode. It was working fine a few days ago :(
    When checking for satellites it displays 0.
    I have already tried the reset multiple times by pressing the 3 button sequence and it doesnt seem to have done anything.
    My software version is HN+_US_AU3G-K0942_6, is there anything else I should check before taking it into the dealer? Vehicle is a b8.5 allroad.
    Jul 16 2018
    Atlanta
    Scan for DTCs, see if it knows there's a problem talking to the GPS antenna (part of the roof antenna).
    The R50 GPS antenna in that roof unit runs a direct wire to the back of the J794 information electronics module. The J794 is the unit in the dash with the door and sd card slots and such. You could use the removal keys to pull it out and plug/replug that antenna wire (plug T1n) in case it's simply come loose. My rear view camera developed a problem after years, turned out the plug on the back of the dash unit was loose; unplug replug all good again.
    But it could be the antenna, the wire, the connections on either end, or something broke in the J794 itself.
    Jul 01 2014
    'murca
    Quote Originally Posted by Smac770 View Post
    Just scanned for DTC's and nothing. I tried to connect to the nav module (menu option 57) via VCDS but it said it could not connect.
    I ordered some radio keys off amazon and will try to check the simple things before taking it in later this week.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by erykv1 View Post
    You mean 5F?
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Gunnark100 View Post
    You mean 5F?
    I'd bet he means 37. There is a module 37 - Navigation. The B8 doesn't have that. The Nav is in 5F - Information Electr as Gunmark100 was suggesting. See if there are signal error codes in that module.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jul 16 2018
    Atlanta
    Address 37 (Navigation) is the J401 DVD drive in a MMI 2G vehicle (like mine).
    Address 07 (Control Head) is the J523 "FID Control Head Control Module", called "interface box" in ETKA. Thus the terms you see in a scan of that address.
    You won't have these in a MMI 3G vehicle.
    The functionality of multiple modules, such as the J401, were integrated into the J794, which replaced the J523.
    Address 5F (Information Electr.) is the J794 information electronics control module in a MMI 3G vehicle.
    Jul 01 2014
    'murca
    You mean 5F?
    Quote Originally Posted by mtroxel View Post
    You guys were right, i was scanning address 37 (perhaps this is incorrect). I have a 2015 model.
    I will try to take a look at 5F today and see if it says anything.
    My headunit pulling tools should arrive today and I will at least check the antenna connection before to see if its a simple fix.
    Jul 01 2014
    'murca
    Hmm. Update / question.
    Does anyone know where the GPS/NAV antenna is located for these vehicles? I did install a dashcam recently near the mirror.
    I powered the dashcam on AFTER the car was started (rather than have it start with the car)... and the car picked up 7-8 satellites.
    Coincidence? Or possible interference from the dashcam? Seems like a common spot used by b8.5 installs though.
    Jul 16 2018
    Atlanta
    The GPS antenna is in the roof fin; see second post in the thread.
    Have you repeated the experiment and it seems consistent? Does it lose the satellites after powering on?
    The connection is an single shielded RF wire from the roof fin to the back of the J794. But maybe your device is creating EMI or other noise on the power lines and it's upsetting the J794.
    Did you ever do a scan to see what the J794 had to say about the situation?
    Jul 01 2014
    'murca
    If I power on the dash cam AFTER the car starts, it maintains 7-9 satellites without issue.
    When I scanned it said "could not connect to module." I will do a few more tests before blaming it 100% on the dash cam.
    Jul 27 2017
    2014 A4 Premium+ w/Sport Pack, '99.5 A4 V6 5spd, w/Sport Pack, 2007 Triumph Bonneville T100
    Somewhat of a thread jack, but I've had similar issues with the nav on my car too. It works fine, but will intermittently loose where we're located. Seems like it happens when we get a little ways from home, say outride a 30 or so mile radius from home. Seems as if antennae connection is intermittent. We'll be driving, and all of a sudden nav shows us in some totally nonsensical place. Do the 3 button reset and it just thinks we're starting from home and never finds us.
    I did a fault code scan earlier today and just went back to look at unit 5F. No faults come up. Is there something else easy to check?
    Jul 01 2014
    'murca
    Quote Originally Posted by DeeInSeatown View Post
    when you check to see how many satellites are being picked up in the route menu, what does it say when it loses position?
    Jul 27 2017
    Was looking through options the other day in the navigation screen after you posted the info about # of satellites but I'm not actually sure where to find it. Is that a VCDS thing or am I just missing it in a navigation screen menu?
    Oct 21 2012
    Earth...
    or check in green menu, under navigation.
    Jul 27 2017
    Found it...blue menu? Didn't realize there was another view above the current location address. At the moment, have between 7 and 8 satellites and it know just where I am. Will have to look when it craps out again.
    Oct 21 2012
    Earth...
    Yep in blue(nav menu) or in green menu(engineering)
    Jul 27 2017
    Gotcha, don't have that view activated on my car...or I'm just not able to find it.
    Jul 16 2018
    Atlanta
    That's the green "hidden menu" that you have to enable via VCDS coding. A search will show how to enable access to it.
    Jul 27 2017
    Thanks, knew I saw it somewhere but couldn't remember what it was called.
    Junior Member One Ring
    Apr 22 2018
    Kitchener, Ontario Canada
    Just going to piggyback on this thread you as I have the same issue.
    Decided to get the issue diagnosed by the dealer and said the antenna will need to be replaced. Cost of the antenna is $700 + getting the antenna painted + labour = $1300 + taxes..... (Jeebus...)
    At this point would it be better to find a used antenna and replace it myself (or mechanic/shop how can do it for cheap)? Go with the Aftermarket Android system unit display that comes with NAV?
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Mithrandir View Post
    I looked at the manual, step #1 is to remove the entire headliner. That's a pretty big job. But you could do it in a Saturday. My friends at wolfautoparts.com have some already painted for around $50. Check them out.
    Jul 27 2017
    Just going to piggyback on this thread you as I have the same issue...
    That dealer price is ridiculous! What symptoms are you seeing, and are they intermittent for you as well?
    Apr 22 2018
    Thanks! Will check them out.
    Sent from my Pixel 2 XL using Audizine mobile app
    Apr 22 2018
    I do get a signal but at this point it defaults out to Greenland everytime I start the car but doesn't even show me an exact location. Use to show me before that I was in Memphis (I'm in Toronto Canada) and also show the cursor moving around.
    Jul 27 2017
    I love the Nav showing me driving in the water. Mine's an intermittent failure, and usually just crops up when a little ways from home and outside my normal driving range. Can't tell you how many times I've been bushwhacking across city grids or driving in the Puget Sound, according to the NAV that is. That's not my typical real life driving behavior.
    Jul 16 2018
    Atlanta
    You're a beta tester for that new Audi auto-boat conversion?
    Jul 27 2017
    Yeah, who knew. Quattro really gets it done!
    Jul 01 2014
    'murca
    I'm throwing the towel in. Since I made the thread, I brought it into the dealer... and of course the day I bring it in, it starts working.
    So they found nothing and it worked for a few weeks. Tonight it lost satellites again.
    Looks like I will use this as an excuse to pick up an RSNAV.
    Oct 30 2006
    B8 A4 Avant 6spd
    Before you do that, you most likely may just need a coax wire repair. The coax wire at the antenna connection gets kinked and causes a intermittent open circuit. We cut the wire a couple inches back and crimp on a new connection and then use a short patch cable to introduce slack into the harness.
    When I diagnose these, I generally run my own cable between the 5F and antenna for testing, if that doesn't solve it I then have a tester antenna. There is also a small possibility that the port on the 5F is dying. Statistically it goes Coax repair > Antenna > 5F
    -18 718 GTS
    Jul 01 2014
    'murca
    Quote Originally Posted by Militant-Grunt View Post
    Yep you are correct.
    I bought a $15 antenna off ebay to just test if I would get my satellites back.
    ...low and behold it immediately picked up 6 satellites (I didnt bother putting the reciever in an open location since I was just testing, its just shoved behind the MMI for now).
    I'll keep an eye on it for this week. Thanks for the suggestion.
    How would I know where on the cable needs repair?
    Oct 30 2006
    B8 A4 Avant 6spd
    Most likely right at the antenna, from the factory they are not given sufficient enough slack, though its possible it could be at the 5F as well. 9/10 times its at the antenna. To perform the repair you need a special VAS tool kit, no idea if there's a aftermarket equivalent.
    -18 718 GTS
    Jul 16 2018
    Atlanta
    https://www.ecstuning.com/b-genuine-...4g0035503kgru/
    It's just a FAKRA plug and RF cable. One to the radio (sat radio R170), two to the J794 (GPS R50 and cellular R65). No idea which color goes to which. It looks like there's pigtail leads that attach to the R52 roof aerial and then a join to the longer wire running to the front or rear. Kind of looks like the join for the video cable from the parking camera to its cable.
    Here's an idea of what you're looking at. https://www.ebay.com/i/392064375069
    But if it is the main cable run that has a problem end, yeah, probably better to redo the end. And for that, you would need a FAKRA crip tool.
