Results 1 to 14 of 14
    Mar 10 2015
    Alaska
    ABS sensor ring loose
    This is on the LR of my A4 quattro, the abs sensor ring has come loose from the cv axel, I'm thinking of tack welding it back on do you think it will work?
    Jan 24 2010
    Paramus,NJ USA
    why?? It should be a rather snug fit to keep it from coming off.
    Ziddy Autowerks
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Hardenable steel may not be the best candidate to tack weld. I would clean up the surfaces and put it back on with Loctite stud and bearing mount.
    Jan 24 2010
    Paramus,NJ USA
    Judging from the picture it looks like a aftermarket outer cv to me at least. That could be your issue.
    Ziddy Autowerks
    Mar 10 2015
    Alaska
    Quote Originally Posted by EuroxS4 View Post
    Don’t know why it failed, the wheel bearing is bad perhaps heat buildup from that or maybe heat from hard braking caused the ring to expand just enough to come loose. The outer cv joint is oem as is the entire axel assembly. As for using loctite a couple concerns, the fit is pretty loose from reading about the stuff it will only fill a gap up to 1/4mm, second is I wonder if excess loctite gets in those windows will it be enough to affect the resistance reading from the sensor?
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    I literally just went through this with my sisters driver front CV tone ring. The cause was from a failing wheel bearing, and the tone ring actually chewed into the aluminum upwright, and once it was separated, traction, abs lights were on and the speedo stopped working.
    We smeared JB weld all around the surface of where it mates to and its been good all week. Let it set up for at least 24 hours in a heated garage.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Mar 28 2015
    Quote Originally Posted by akaudicq View Post
    Loctite won't affect the readings and it wont cure in the open windows. The rings are not typically on that tight. Based on the picture and my experience with loctite stud and bearing mount the ring would end up held very well. A freshly sanded surface sets the loctite faster.
    Mar 10 2015
    Alaska
    Quote Originally Posted by Gosser View Post
    Cool. So I assume your abs is working did you get any JB oozing in the ring windows that you had to deal with?
    Mar 10 2015
    Alaska
    Quote Originally Posted by Kevin C View Post
    Thanks that may be the way to go. I think it will withstand up somewhere in the neighborhood of 500 degrees which should handle any braking heat transfer?
    Mar 28 2015
    That part will never see 500°F, more like 140°F max. Its pretty well shielded. If it was getting that hot in that area your CV boots would be toasted. The molding temp for the CV boots is around 355-400°F.
    Jun 05 2013
    Ottawa
    Yes, everything is working. We smeared the JB on the CV axle first, then slide the ring on. A bunch of jb oozed out obviously the back, so we just used out finder to tool it like a caulking joint. Some made it into the windows, but nothing excessive, like maybe 1/8 of the actual window has jb weld in it. If you are really worried, just get a q-tip and wipe them all out 100% clean.
    2007 RS4 Avant
    Mar 28 2015
    My take is that either JB weld epoxy of Loctite will work. Personal experience on slip fitted parts is that both will have good strength but the Loctite will have better toughness. The ring is pretty light and it has a lot of surface area so its not a big deal either way.
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    I have a slightly dented ring and I searched and found that you can actually buy the ring itself, or may be head to a junk yard and get one, just make sure the slots count is the same.
    Still didn’t out mine back so if it didn’t work I will have to visit one of the above options.
    Mar 10 2015
    Alaska
    So I ended up using JB Weld but not before I tested that and the Loctite 680 on a test piece. The JB filed a larger gap much better by virtue of it being a thicker material than the Loctite. On the test of gluing two pieces of flat metal together the JB welded one was much harder to pry apart. I took the car for a test ride today and the ABS worked flawlessly, thanks to everyone for your help!
