Results 1 to 34 of 34
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Another Magnaflow 11385 Review
    I know many have done this exhaust mod before and lots of threads on this topic, but I want to share my recent switch for others that are still on the fence. I always wanted the AWE Touring + Res DP or ECS Valve (not anymore due to quality issue), but both are quite expensive for just sound mod. This mod is simple: Cut off baby resonators to replace with Magnaflow 11385 (resonated X-pipe) and cut off center resonator to replace with straight pipes.
    First sound impression: The exhaust note has much deeper bass than stock. There is no drone, not raspy and sound is very OEM+ like. The sound volume is quite subtle enough while in normal driving and cruising it's close to stock with a deeper note. I would say volume increased only about 10-15% over stock in normal driving. At WOT the volume is maybe 20-25% louder than stock (nothing crazy), but with a nicer/deeper tone throughout the powerband. Highest volume peaks between 2500~2900 RPM. See the video below to hear for yourself. Note: I did turn off the Soundaktor.
    Overall, I'm very happy with this cheap ($250) mod. This is how our S4 should sound like from the factory. This mod is for anyone that wants a little more sound with deeper exhaust note. It's very daily driver friendly and doesn't scream in others' faces. I would highly recommend this mod to those that don't want to spend $1.5K to $2.5K for a complete cat-back system.
    While I was at the muffler shop, I had them cut off my OEM tips and welded in some nice 4" tips. These tips I got are from Different Trend (item#: DT-25101), stainless steel, double-walled, slant cut. They fill up the stock valance nicely. I'm thinking the tips should be a little more flush (about 1" forward) but since they are welded on now, re-doing them will be a pain because getting them lined up correctly with the stock muffler is time-consuming. The tips coming out a little bit makes them more aggressive. What do you guys think? One thing I do notice is that these tips get dirty and turn black within hours of driving, so it's a chore to keep them clean (think daily cleaning).
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    I'd say that sounds pretty damn good.
    Sep 09 2018
    Pennsylvania
    Sounds good, I went with replacing the baby resonators with a borla x pipe and leaving that middle resonator in the car. Then I replaced the rear mufflers with straight pipe and for new 4" tips. My total was around $300.
    I am pleased with the sound. I went with Borla X pipe instead as I read some things about the MF not lasting very long so decided to give Borla a try instead.
    Feb 18 2019
    Quote Originally Posted by ArgCarp83 View Post
    Got any sound clips?
    Mar 24 2014
    Quote Originally Posted by jsh139 View Post
    Sounds good! What was that ticking noise when you were braking?
    Thanks! That sound was actually from my tran belly cover that was ripped apart, so it occasionally flaps. I need to replace it with the ECS metal plate next along with the skid plate.
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Funny you posted this thread.. I just finished throwing my mid-muffler back in after having it straight piped with the baby resonators replaced with a 11385. I started to get super annoyed by the sound at 2-3k RPM when I'd get on it. It was like a loud G35. I also didn't like how the volume was so disproportionate to the rest of the RPM range.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Mar 24 2014
    Quote Originally Posted by agentsmith988 View Post
    Interesting. The sound does peak around 2500~2900 RPM before dropping down, but it's not annoying to me. I kinda get what you are saying tho. Just curious, did you turn off your Soundaktor? The fake sound may interfere with the real sound, like they are out of sync.
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    Sounds good, I decided to take the plunge.
    Thanks,
    Senior Member Two Rings Turbocoop's Avatar
    Jun 08 2014
    Charleston, SC
    Nice writeup and thanks for taking the time to do the video!! If I saw something like this before I went through 4 iterations of exhaust setups I would've saved a ton of time and money... I've still got the 11385 but I paired it up with a CTS turbo exhaust. Yours sounds very similar at 1/4 of the cost
    Fry Sauce, UT
    Quote Originally Posted by AerotusX View Post
    Soundaktor is disabled. It's probably worse having a manual transmission though. I'm guessing the DSG shifts anytime you get on it helping to stay out of the annoying RPM range.
    Also, it definitely got louder after everything broke in as well. After 3 months I couldn't take it anymore.
    - Steve
    NKAWTG
    Sep 09 2018
    Pennsylvania
    Not yet not really, it's winter and not having an assistant to record sucks lol
    Quote Originally Posted by hberg002 View Post
    Sent from Audizine mobile app
    Senior Member Two Rings m1k3d3's Avatar
    Jan 31 2017
    Philly
    Interesting write up and thanks for the video.
    What sort of camera are you using? Videos of my stock exhaust from a go pro 7 sound nothing the video of your stock exhaust.
    2015 S4 Sepang Blue | 6MT | Tech | B&O | Leather | Carbon Atlas | Black Optics | Sport Diff
    ECS Kohlefaser Luft-Technik | Bilstein PSS10 | ECS 10 & 12.5 mm spacers | USP Stainless Steel Clutch Line | Suntek CXP 35% | 034 Drivetrain Mounts | RS4 Grille
    Mar 24 2014
    Quote Originally Posted by m1k3d3 View Post
    I'm using my Sony A7ii camera on a tripod. On the "after" video, I accidentally left my exposure compensation at -3EV, that's why it was so dark. Yeah, I thought the sound was pretty accurate.
    Established Member Two Rings Method's Avatar
    Jul 18 2017
    Portland OR
    This is the exact reason why I settled on the 11385 in place of the baby resonators, with the briefcase resonator put back in. The sound peak at 2500 drove me nuts on the freeway.
    I'm old, so the current setup is perfect for me.
    APR Stage 2SP + Intake, Light 11385 Mod, 034 Springs - SOLD
    2018 M3 Comp
    May 05 2015
    United States
    Quote Originally Posted by Method View Post
    Do you have any sound clips your setup?
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Ahh, that makes sense. I was like, WTF is that?
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    That sounds really good for the price! Do you do much highway driving? What is the drone like at 65 - 80 mph?
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Mar 24 2014
    Quote Originally Posted by doughboy17 View Post
    I do about 50/50 (hwy/street). I would say the sound peaks between 2500~2900RPM, but I wouldn't call this drone. There is no drone anywhere else in the powerband. I typically cruise around 75-80mph on freeways when possible, there is zero drone.
    Jul 18 2017
    Portland OR
    Quote Originally Posted by Burndrum View Post
    Not handy - It sounds like stock when cruising around (nice and quiet), but gives a bit of extra growl when you get on the throttle. I've found it to be too subtle for most on here.
    2018 M3 Comp
    Junior Member Two Rings tourbillonnaire's Avatar
    Apr 10 2019
    Montreal
    Did you need to alter the rear muffler in any way to accomodate the 4'' tips side-by-side, or they simply slip on the existing flange?
    Mar 24 2014
    Quote Originally Posted by tourbillonnaire View Post
    The shop added an extension so that the larger tips can move outward from center slightly to provide room and then the end tips would bend slightly back toward the center to align them parallel to each other. Here is what they look like from under.
    Apr 10 2019
    Montreal
    Thank you for the follow-up, much appreciated!
    Sep 30 2020
    Denver, Co
    I’m behind on this but, nonetheless, I appreciate the info due to the fact that the drone from my resonator delete is maddening and a solution minus the battle is a relief.
    Jul 31 2012
    Scotland
    So help me, I thought I was done with exhaust mods, I never found one that actually didn't drone (and it's SO subjective, got the OP saying 'no drone' and other posters saying it got so annoying they changed it back...) but this one sounds like it could work for me.
    With just the 11385 replacing the baby resonators, there really is no increase in sound in the 2-3k range? A 10% bump in volume and a slightly deeper sound I could certainly enjoy. I really like the sound of the OP's setup but couldn't handle the 2-3k volume bump and I think avants 'echo' more.
    Would love a sound clip if you could manage :)
    More on topic, how easy is the baby resonator change over for an exhaust shop? What if I didn't like it and wanted back to stock? Seems like a lot of welding (I've zero experience of getting a shop to weld me something).
    Mar 24 2014
    A decent muffler shop should be able to weld back to stock in 30-min. Very simple job for them.
    Mar 31 2008
    eS-4
    CAL*SO
    nah. should of added a normal xpipe in the middle instead of the individual straight pipes.
    Junior Member Two Rings fowl's Avatar
    Aug 24 2020
    2010 Audi S5
    Cayman
    Quote Originally Posted by Fresh.S4 View Post
    Could you please elaborate why he should have do this?
    Sep 17 2019
    St George, UT
    The purpose of an x-pipe (that he is getting inside the 11385) is to balance the exhaust from both banks of the v6... adding another one doesn't seem to be necessary.
    I have only the large suitcase resonator removed from my wife's S4 and would like to mirror the OP's setup myself but the mrs. likes the exhaust as it is... everyone is different right?
    Established Member Two Rings Skynet3132's Avatar
    Jan 15 2019
    Phoenix, AZ
    did this mod about a year ago. 11385 in place of baby res, straight piped to the stock muffs, added 90mm tips. works great for me. adds a nice subtle growl when getting on it, but quiet when normal driving. absolutely no drone at hwy speeds, but you can still hear it's there. not sure how the Red Star HFC will affect any drone or rasp once installed, but ive been very happy so far. took a couple months for it to finally break in and the sound to fully change to what it is now. well worth the $400 total that it cost to make it happen.
    @HAUDIYALL
    2019 SQ5 P+ » Ibis White » 034 Motorsport Stage 2
    2010 S4 P+ » Ice Silver » APR Stage 2 DP (sold)
    Mar 10 2020
    Salt Lake City
    Been trying to find a forsure answer what’s the inlet on the tips?
    Mar 24 2014
    Quote Originally Posted by natesB8 View Post
    These are the tips I got. 2.5" Inlet.
    https://www.carid.com/different-tren...-dt-25101.html
    Active Member One Ring thadcollier's Avatar
    Aug 01 2017
    98 Jeep Cherokee
    West Fargo, ND USA
    What size piping is your 11385? Looking on amazon vs magnaflow im seeing multiple sizes but listed as the same item name/number
    Junior Member Two Rings Caffeen's Avatar
    Nov 24 2020
    Montana
    Quote Originally Posted by thadcollier View Post
    11385 uses 2.25" piping, the 11386 uses 2.5" piping
    1. 2014 Phantom Black S4 6MT, Sports Diff, B&O, Revo HX, Stage 1 Revo, CTS Downpipes, Drilled & slotted rotors, Stage 3 Ringer Racing clutch, Billet steel flywheel
